Old 11-20-2001, 12:50 AM   #1
BG5
Member#: 695
Thumbs up NGK copper spark plugs for DOHC EJ25
I'm using these on the DOHC EJ25 which normally wants ($$) NGK PFR5B-11's (double platinum). I've tried regular copper BKR5E-11 and Bosch Platinum +4 4418 / 4419 plugs in the past.
The BKR5EVKB-11 (IIRC) is normally a toyota plug seen mostly on their V6 trucks (Tacoma, et al.) but it's copper and has two large ground electrodes which come up the sides of the center cathode.
Performance is actually very similar to the 4419 Bosch Plat+4 with smoother idle than the stock plugs, but the NGK's pull a little cleaner under load compared to the 4419's which can be a bit weak under transient loads. The Plat 4's also tended to suck a lot of current down the #3 wire.
The bad thing is that these plugs are rarer than most NGK's and the price ($4-$6 each) is high for a copper plug. There's also a platinum version which costs 3x more...
BG5 is offline   Reply With Quote
Old 01-08-2002, 03:51 PM   #2
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Default Denso
Thanks for the info.
It is also possible to use Denso "U-groove" K16R-U11 plugs. I double checked with Denso USA. These are listed specifically for the DOHC 2.5RS and cross-reference with PFR5B-11. Excellent copper plugs, about $1.49 each mail order.
I ordered mine from www.importpartsspec.com. BTW, they also carry Nippon (the old Subaru OEM, pre-Purolator) air and oil filters. They have a screwy online catalog and sent me the wrong stuff. I called and they sent me the right stuff, no problem. So I would recommend you call them and ask for specific parts (i.e., make clear you want Nippon, not the other brand) and use the online catalog only as a guide.
vvk is offline   Reply With Quote
NGK PFR6G Spark Plugs for Version 2 RA JDM_Scobaru Service & Maintenance 0 01-31-2006 11:06 PM
OEM NGK Platinum spark plugs for WRX drees Private 'For Sale' Classifieds 2 01-26-2005 02:56 AM
NGK Copper Spark Plugs gtwagon941 Legacy Forum 7 09-15-2003 07:15 PM
NGK Copper Spark Plugs… BKR6E or BKR5E? Button Service & Maintenance 3 04-30-2003 11:33 PM
NGK Copper Spark Plugs in Orange County? Evan Southern California Impreza Club Forum -- SCIC 2 01-15-2003 04:33 PM
