#1 |
Member#: 135259
Vehicle:1995 Legend Gn |
I am intersted in knowing if anyone out there has changed a fuel tank in the 1995 Legacy AWD?
I have a serious leak in mine (read Rust - I live inthe RUST BELT) and it needs to come out. I have the new tank, but it looks like a bear to change. It appears the car was built around the gas tank. The tank hangs over both sides of the rear end and drive shaft. The cradle for the rear suspension forms a cage behind the tank, and the cross member and sway bar make it a pretty impermeable cage to get the dang thing out. I am seriously considering cutting the floor out, as it looks easier than taking the whole rear suspension out. (not to mention disturbing the all the fuel and brake lines, emerg. brake cables, hardware, etc. in the process.) I just don't know if the tank can come out through the top. (width of the Unit body etc. ) Anyone out there replaced one?? Any suggestions? I would appreciate any suggestions for shortcuts or helpful hints on what to / not do to make this easier, cuz it doesn't seem like it will be fun.. Thanks,
#2 |
Member#: 67154
Vehicle:1997 Legacy GT/WRX White |
The FSM has the complete procedure, but basically it comes down to removing the rear section of your exhaust, the rear diff, axles and crossmember, and disconnecting all the hoses.
I would definitely not recommend cutting anywhere around there, as you'd destroy the structural integrity of the car, not to mention cutting + gasoline = bad times. |
#3 |
Member#: 88618
SCIC
Vehicle:1994 Legacy "The Silver Slug" |
The only way that sucker is going to come off is down. Like Dan said, most of the rearend has to be removed, which will be a lot less of a hassle than cutting the floor.
It's just one of the bitch things that you have to do properly. |
#4 |
Member#: 89385
Vehicle:many most all WRB/blk/blk/blk/slvr/wht |
It's been a while, but I thought it was easy.
I did not have to take the axles off the diff. I lowered the diff with the axles still attached, and rocked the tank out. Four boltz for the axle, few more for the shield, maybe six or eight (I forgot) for the diff...hoses and wire connections..remove exhaust. For a first timer....I'd say four hours at the most. |
#5 |
Member#: 4021
NESIC
Vehicle:1999 Legacy GT Ltd Quick Silver Metallic |
Another suggestion would be to perform this procedure when you have little or no gasoline in left the gas tank. If you figure (guessing) that gasonline (in liquid form) weighs roughly 50 to 60 pounds for each gallon, then a half tank of gas might mean, like, 400 pounds.
#6 | |
Member#: 43728
RMIC
Vehicle:2007 328iT Graphite |
#7 |
Member#: 11620
Vehicle:1997 GF4 -STiV3 Saab 93 TX sportcombi |
It's a 4 hour job with a hoist and air tools. If you don't have those then it's going to be LONGER...
You will likely need new straps and hardware to hold the tank because the old ones will not come off in one piece. |
| Thread Tools | |
| Display Modes | |
| How to change transmission fluid and filter in 1996 Legacy LSi AWD 2.5L auto | Lat0 | Transmission (AT/MT) & Driveline | 0 | 01-22-2010 04:48 PM |
| Legacy AWD gas tank | trevitino | Subaru Conversions | 2 | 04-19-2009 01:35 AM |
| 96 AWD Legacy Wagon Gas Tank Quandry | Bullwinkle | Legacy Forum | 11 | 11-27-2007 04:07 PM |
| AWD gas tank question | scoobyimprza | Subaru Conversions | 3 | 05-04-2004 11:19 PM |
| difference between FWD and AWD gas tanks | scobaru | Subaru Conversions | 2 | 08-11-2003 03:44 PM |
