Old 12-21-2006, 02:37 AM   #1
imprezaRS420
Member#: 35212
2001 Impreza 2.5 RS
Default massive idle problem after violent axle brake??
I am having a massive problem with my 2000 Legacy 2.5L.
The whole problem started after I had a front drivers side ball joint, and axle brake violenty one day. the ball joint completely poped out of its collar, since the bolt had aparently either fallen out or whatever??. this happened when going about 55 MPH and hitting a dip of sorts in theroad. anyway, the wheel slammed into the fender well, locking the wheel while the rest continued to travel 55 MPH untill I could stop.
After replacing everything the next day, I have had a problem with VERY VERY rough idle when in gear (4EAT) while sitting at a light or any time while not moving when the car is in gear. (Any Gear)
The whole car shakes untill I depress the brake, and then the car immediately starts moving without even touching the gass.
"It feels like my car is refusing to sit still while in gear".???!!!!!
Thanks!!,
Bryan
imprezaRS420 is offline   Reply With Quote
Old 12-21-2006, 08:23 AM   #2
b4wantab
Member#: 21293
05 OB Black Bean
1969 W-30
I have a manual trans so someone that knows the 4eat will have to verify but, it sounds like your center diff/clutch packs are dead. What is left of them is engage until you hit the brake and it is stalling the engine but the ECU is trying to compensate.
The auto setups changed a bit over the years and I do not know the specifics nor do I know how to verify. How does it turn in a parking lot/sharp corner?
Peace,
Greg
b4wantab is offline   Reply With Quote
Old 12-27-2006, 07:04 AM   #3
turbo2ner
Member#: 89385
many most all
WRB/blk/blk/blk/slvr/wht
TCC
(Torque converter clutch is locked up, giving the feeling of a manual trans car with the clutch out.)
Why is this?? I don't know.
Maybe a wire got cut on the drivers side?
Sounds exactly like a stuck clutch in the converter. Got to get in there and check the signal from ECU-to-trans, then move on to mechanical problems if that's not it. Like a clogged/broken solonoid for the TCC, maybe from the drivetrain shock of your recent broken parts??
On most cars, you can change the solonoid with the trans still in the car.
Scott
turbo2ner is offline   Reply With Quote
Old 12-27-2006, 10:57 PM   #4
sha_zapple
Member#: 41012
1998 Legacy L
define 'replaced everything'
sha_zapple is offline   Reply With Quote
Idle problem after Tial Q Bov Install fl4tsc Newbies & FAQs 51 05-14-2012 09:21 PM
idle problem after replace radiator??? sum0325 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-12-2009 02:19 PM
Idle Problems after Spec-c intake manifold install wrxwagon253 North West Impreza Club Forum -- NWIC 16 11-03-2007 04:49 PM
Idle problem after blowing SBF5 Annoying Eric Normally Aspirated Powertrain 3 09-07-2005 08:28 AM
Idle problem after ECU reset Spectre23 Technical Forum Archive 1 05-19-2000 12:42 AM
