Old 12-19-2006, 02:05 AM   #1
theostubbs
Member#: 122286
2007 STi
Default 2.5L Oil Pan on 2.0L WRX
Been searching for what is required to do the 2.0L to 2.5L oil pan swap. Seems almost TOO straight forward... there has to be more to it... so after searching:
http://forums.nasioc.com/forums/show...t=oil+pan+swap
and
I get a seed of doubt as to what exactly is involved in the swap.
Do the following need to be modified?
- Oil Pickup? Does this need to be modified for the deeper pan?
- Dipstick and guide? Will the markings on my old dipstick be accurate with the new pan?
- Anything else I should be aware of?
I sure as heck dont want oil problems because i missed something. Sorry if this is old news, i've just seen some mixed information on a few threads.
Thanks for your help guys!
theostubbs is offline   Reply With Quote
Old 12-19-2006, 05:39 PM   #2
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
The oil pickup is the same but you will need the 2.5 dipstick. Why do you want to change the pans? Headers i assume.
JMK508 is offline   Reply With Quote
Old 12-19-2006, 09:52 PM   #3
theostubbs
Member#: 122286
2007 STi
yuppers
also, what about the baffle? I'm guessing if the oil pickup is ok, the baffle should probably be ok as well?
Old 12-19-2006, 10:35 PM   #4
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
I am a bit confused. When I swapped my 2.5 block in to replace my 2.0 JDM block I had could not use the 2.5 oil pan. I had to use the 2.0 pan or it would not clear. I also had to use the 2.0 oil pickup tube with the 2.0 pan. The 2.5 would not fit.
Clark
AZScoobie is offline   Reply With Quote
Old 12-20-2006, 09:02 AM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
A few have successfully swapped the pan in order to do headers. There was a guy a few months ago with a detail write about it.
2.5 liter oil pan on 2.0 liter, oil pickup cabe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-07-2008 11:31 AM
WTB: 2006 STI 2.5L Oil pan spoolinw00t SCIC Private Classifieds 5 08-24-2008 05:30 PM
WTB: 2006 STI 2.5L Oil Pan spoolinw00t Private 'Wanted' Classifieds 8 08-14-2008 02:00 PM
2004 2.5RS Oil Pan on 2006 2.5i?? Boosted WRX STi Normally Aspirated Powertrain 3 01-19-2007 10:03 PM
2.5L crawford shortblock on 2.0L 2004 WRX heads mistaboosta Built Motor Discussion 11 04-05-2006 06:27 PM
