Old 12-19-2006, 04:43 AM   #1
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Thumbs up Oil Analysis: 8400mi on M1 5w30 - WRX
8400mi on M1 5w30, most miles from 22 mi each way daily commute. Looks like I can go farther. My wear numbers are the same or better than the universal averages which average about 4000mi if I remember correctly. I'm going to run out to 9k mi this interval. It's nice to drive 20k mi/year and only have to change the oil 2-3 times a year.
Link to discussion on BITOG: http://theoildrop.server101.com/foru...?Number=776545
Link to previous UOA: http://forums.nasioc.com/forums/show....php?t=1019073
drees is offline   Reply With Quote
Old 12-19-2006, 08:13 AM   #2
bluesubie
Member#: 767
04 FXT
Ok, time to confess. Did you add the make-up oil on the same day you did the UOA?
Simply amazing, and proof that M1 5W30 works perfect for some people and that it can last over 8,000 miles.
-Dennis
Old 12-19-2006, 02:21 PM   #3
hondaeater69
Member#: 60324
nice report for those miles on M1. Yea it seems our cars either hate the stuff or love it. I think the consumption issue is more a function of slight variances in build quality and tolerances than anything else...
also dress how do you drive the car? i see you do some commuting, but do you regularly get into full boost? and what mods/level is your car at?
Old 12-19-2006, 08:20 PM   #4
Gunner
Member#: 36540
04 GGA
Cobb Stage 1 EQ Tuned
-Dennis
Ya, the 440 flash point is the highest I've seen with fuel diluted M1 5w-30 in a WRX for 7500+ miles
Gunner is offline   Reply With Quote
Old 12-20-2006, 02:54 AM   #5
drees
Member#: 25905
2003 Silver Wagon
LOL, no, make up oil was around 6500 mi or so.
I agree. My car seems to burn less oil now than it did 30-40k mi ago when it seemed to go though about twice as much oil. I ran Amsoil for one interval and it didn't seem to consume any oil at all, but the Amsoil is a bit more money, at ~$7/qt vs the ~$4.50/qt M1 costs me by the case and didn't lower wear numbers any in my car. If you pay the $6/qt retail for M1, I would probably opt to run the Amsoil especially if you had any oil consumption issues.
Well, of my 22 mile commute, the first and last 2-3 miles are city streets so if it's warm out, the the oil has warmed up enough for me to feel comfortable doing a 2nd/3rd gear run onto the freeway. On the freeway it's usually 70-80+ depending on how much aggression I need to let out. On the freeway it's mostly in vacuum or 0 boost if going up a slight hill. Usually don't need more than 5-7psi boost to pass traffic if I need to. I might hit full boost again in the last 2 miles depending on traffic.
Overall I think I'm pretty easy on the car.
Only engine mod worth mentioning is IC hoses. Had Cobb Stage 1 flashed on it a while, but with the fuel here and my car it would ping under load so I ditched it. Now I'm working on a conservative map (Tactrix cable/Enginuity/Ecuflash) which leans it out a bit under higher load but also has more conservative timing.
Not really any fuel in my oil, my commute does a good job of avoiding fuel build up. But typically the flash point has been 395F +- 20F.
Old 12-20-2006, 04:18 AM   #6
FD777
Member#: 84820
2005 WRX Sedan
Crystal Gray
Off topic here, but
Were you using the CA 91-octane map or the regular one?
FD777 is offline   Reply With Quote
Old 12-21-2006, 02:02 AM   #7
drees
Member#: 25905
2003 Silver Wagon
CA 91 map. Didn't make much difference over the regular 91 map.
Old 12-21-2006, 12:22 PM   #8
Feign
Member#: 68604
06 STi
Nice numbers!
My iron and lead shot up like a rocket this past time for some reason on ~7500, so they told me to drop it back down to ~5000 and see what happens. M1 Syn 5w-30 here too!
Feign is offline   Reply With Quote
Old 12-22-2006, 02:48 AM   #9
drees
Member#: 25905
2003 Silver Wagon
Got a link to your report?
Oil Analysis: 8400mi on M1 5w30 - 03 WRX drees Service & Maintenance 51 12-19-2007 05:31 PM
UOA: 7745 miles on M1 5W30 T&SUV JBark Service & Maintenance 7 11-10-2006 10:29 AM
Oil Analysis: 7500mi on M1 10w30 - WRX drees Service & Maintenance 14 06-21-2006 11:30 PM
Oil Analysis: 7600mi on M1 5w30 - WRX drees Service & Maintenance 3 03-02-2004 12:39 AM
Oil Analysis: 7,247mi on Mobil1 5w30 (WRX) drees Service & Maintenance 18 10-23-2003 01:12 AM
