Welcome to the North American Subaru Impreza Owners Club Monday March 30, 2015
Old 12-19-2006, 05:08 AM   #1
september
Member#: 126677
05 sti
perky, pesky
Default my I C sprayer pump LED is coming on- normal?
I have been driving my 05 STI since Oct. The IC sprayer light has never turned on. A few days ago, under hard acceleration ( near redline maybe ) I noticed it blink on for a millisec. At first I cound not recognize the LED. Now today just after my second oil change, I was driving it harder than usual ( heat in turbo ) and it came on for longer periods.
(I don't think the top mechanic changing oil had anything to do with it.
He does me a favor- he has a customers 93 Skyline in his garage. 2.6L SIX twin turbo 500 hp! )
Nearing home, I was NOT "on it" and the LED was kicking in more easily.
I need advice before I bring it to dealer
thanks
september is offline   Reply With Quote
Old 12-19-2006, 09:32 AM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
First guess...Low water warning light.?
wrxdrvr is offline   Reply With Quote
Old 12-19-2006, 09:51 AM   #3
Flipn
Member#: 80011
2004 Subaru WRX STI
IC sprayer light = low water in IC spray Tank (located in the trunk, passenger side)
Flipn is offline   Reply With Quote
Old 12-19-2006, 03:51 PM   #4
september
Member#: 126677
05 sti
perky, pesky
Default distilled or?
Thanks- sorry about the avoiding of Manual. He has really bad breath and teeth too !!
Distilled water a good idea?
Do I need some kind of gauge to actually note the temperature instead of this arbitrary 'spray the pump when the spirit moves you', methodology?
Same with turbo boost gauge- do i need this?
Thanks for your answers
Old 12-19-2006, 04:50 PM   #5
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I find that if you spray the IC a few times about 1 min and about 30 sec before you think you are actually going to "need" it that will get the IC as cold as it's going to get and it will stay that way for a few minutes...Giving it a shot before/just as you park the car will also keep the IC from getting much heat soak. A boost gauge is a must as far as i'm concerned, and if you want to get an inside outside car temp display it works well as a IC temp display if you push the sensor into the top of IC/fins.
Old 12-21-2006, 01:02 AM   #6
WRXDriftR
Member#: 65065
04 WRX/ STi Hybrid
6MT, VF43
^ but that wont really give you a good reading of "heat soak".. just the temperature of the air hitting the top of the TMIC as you drive. Sure at a stop it would work, but while moving it would simply read the temp of the air outside as it blows past.
I found using a digital thermometer inside the car and running the external probe into intake box, below the air filter gives accurate reading for the temp of air entering the turbo. Thats what the ECU will read as well with the MAF.
WRXDriftR is offline   Reply With Quote
Old 12-21-2006, 10:00 AM   #7
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Ahh,.. but it will tell you the IC temps if you push the sensor into the fins at the very edge of IC and tape it down. And when you close the hood the rubber seal from hood scoop goes over on top diverting airflow...As for the air temps going into the airfilter box its nice to know too, I get my reading from the MAF sensor, With the IC temps easily showing much higher temps than the airbox..The best way to know the air temps in/out of IC is a temp probe into airflow before & after IC wich I also have... It's interesting to see the difference temps as a reaction to different driving conditions.
IC Sprayer comes on more often... VR62STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 12-19-2005 08:18 PM
Aida is coming on HDTV CandyO Off-Topic 16 08-08-2005 06:08 PM
War of the Worlds is coming on AMC wolf8314 Off-Topic 2 07-04-2004 02:52 AM
Poltergiest 2 is coming on TNT wolf8314 Off-Topic 0 04-16-2004 03:59 AM
Superman 2 is coming on TNT wolf8314 Off-Topic 0 04-14-2004 02:46 AM
