Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 12-19-2006, 08:37 AM   #1
shipjumper
Member#: 6307
what I has no car...
am carless
Default 96 2.2l and 01 2.5l (rs) SOHC cam cogs
do they have the same number of teeth?
I would like to drop in the 2.5l into my 96 imp wagoon, using all the wiring and sensors from my car, but im just concerned that the cam cog wheel might have different amount of teef!
I have heard that they "drop right in" but I have done lots of work on subarus where I have been told "yaeh, it bolts right up!" and well, there are differences found and it doesn't bolt right up...
anyone?
shipjumper is offline   Reply With Quote
Old 12-19-2006, 08:22 PM   #2
Subieformance_Guy
Member#: 108716
2004 2.1L, PT 6069
[email protected] Subarus-R-Us
If I'm not mistaken a 96' wiring wont bolt up to an 1. the wiring on ur car is near the battery and an 01 is on the bell housing. different connectors. lots of converting to do.
Subieformance_Guy is offline   Reply With Quote
Old 12-19-2006, 09:53 PM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
Keep your 96 wiring loom, put it on the EJ25.
Extend the cam sensor wires if they don't reach the cam sensor
Transfer the emissions junk and bolt them somewhere on the engine
Change IAC plug or swap throttle bodies
change coil plug
add oil, coolant
start motor......
The cam pulleys will work fine if you keep them with the motor they came from. Note.....you'll be putting the EJ25 cam pulley on the EJ25 motor right? I don't think the EJ22 cam pulley will work on the EJ25 head because the sensor location (and sending pin) is different. You can doublecheck....but I would advise against it personally.
Jay Storm
Old 12-21-2006, 07:30 AM   #4
shipjumper
Member#: 6307
am carless
my wiring loom is on my bell housing... and my motor has NO emmissions junk, you mean the 2.5l right?
all the rest seems like a whopping weekend proj!
2.2L and 2.5L interchange tdhardy Subaru Conversions 1 01-10-2009 12:38 AM
2.2l and 2.5l rs Crizzle Newbies & FAQs 9 10-31-2005 07:45 AM
Alternator Cross Reference 2.2L and 2.5L MYfirst00 Newbies & FAQs 0 03-09-2004 04:49 PM
2.2L REALLY a 2.5L in disguise? Firewire Normally Aspirated Powertrain 8 06-11-2001 11:25 AM
Are the mounts for 2.2L and 2.5L engines the same? >>> KaZ General Forum Archive 2 02-22-2001 08:43 AM
