Old 12-19-2006, 12:16 PM   #1
Nactos
Member#: 133920
06 STI
Default no heatshield after DP installed
since the stock turbo heatshield was screwed on to the stock cat....after the DP was installed... there weren't a way to fit the shield back on.... is that alright? The place where I got it installed said since the cat is gone... I loose some back preasure so the turbo wont get as hot...and I'll be fine.... true?
Nactos is offline   Reply With Quote
Old 12-19-2006, 12:34 PM   #2
Legba
Member#: 88589
2005 STI
the best one
If you cut away some of the stock turbo heat shield so you can fit it over an aftermarket downpipe. The turbo's heat shield is not entirely attached to the downpipe. There are other mounting locations too. That's what I did with my catted helix DP. I used a good pair of tin snips, or dremel tool with a cutoff wheel might work.
Legba is offline   Reply With Quote
Old 12-19-2006, 12:38 PM   #3
hondaeater69
Member#: 60324
trust me your turbo still get's PLENTY flippin hot. I would personally get some heat wrap, wrap the hot side of the turbo, and the first foot or so of the DP (the part in the engine bay), and then either modify the stock HS and reinstall, or buy a cheapie AM HS>
Old 12-19-2006, 01:09 PM   #4
brettm
Member#: 35107
2003 WRX WRB
2006 LGT Silver
There should be about 3 bolt holes up top that are reusable and 2 down on the side that are a real pain to get to. STI may be slightly different but you should still be able to get it on (after trimming of course). You definitely want it on there.
brettm is offline   Reply With Quote
Old 12-19-2006, 01:13 PM   #5
waktasz
Member#: 86356
2015 s1000r
wheelie monster
There is a bracket that you reuse that the heat shield bolts to. Heatwrap anyway FTW.
waktasz is offline   Reply With Quote
Old 12-19-2006, 02:03 PM   #6
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
There is a trimming guide somewhere. Check scoobymods.com as a start. I know Cobb sends a trim guide with their DP's. Maybe they can send you a copy. It'll show you where to cut so you can fit it over the new DP, but still retain 4 or 5 of the stock mounting points.
Scooby921 is offline   Reply With Quote
Old 12-19-2006, 02:05 PM   #7
CatfaceType-R
Member#: 81102
yes you will be fine....
CatfaceType-R is offline   Reply With Quote
Old 12-19-2006, 02:45 PM   #8
Nactos
Member#: 133920
06 STI
thanks for all the help.... I'll try to find that instruction.... but I'll be fine in the mean time I guess.....
Old 12-19-2006, 02:50 PM   #9
BlowDro
Member#: 112116
2006 WRX
if someone could take a pictuer of there modded heat sheild and which holes u use to mount it, that would be great.
BlowDro is offline   Reply With Quote
Old 12-19-2006, 02:54 PM   #10
Nactos
Member#: 133920
06 STI
+1 on that one.... still searching....
Old 12-19-2006, 03:03 PM   #11
Pee_Sack
Member#: 98266
2003 WRX Cobb Stg 2
Same as the sky
if there isnt any pictures I will get one when I go home tonight, mine is cut to fit
Pee_Sack is offline   Reply With Quote
Old 12-19-2006, 03:06 PM   #12
Ft_Laud_wrx
Member#: 32405
2014 BMW M235i
Dinan
I just got the cusco heat shield. I would check it out, perfect fitment...
(not my pic but you get the idea)
Ft_Laud_wrx is offline   Reply With Quote
Old 12-19-2006, 04:31 PM   #13
rexhio
Member#: 97834
i have a 4" bellmouth turboxs dp and i was able to fit the stock heatshield with some cutting
rexhio is offline   Reply With Quote
Old 12-19-2006, 04:36 PM   #14
burritotown
Member#: 121031
1999 RHD Legacy Wgn
Green
I rolled w/o a heatshield for a month or so. I noticed after driving for 30~ minutes the heat soak would set in and my power would drop significantly. So I got a plyers, bent and cut my stocker..(took about 2 minutes) and since I replaced it (and heat wrapped my UP but that's another story) it continues to pull hard all night long.
burritotown is offline   Reply With Quote
Old 12-19-2006, 04:38 PM   #15
Nactos
Member#: 133920
06 STI
what part am i cutting?
Old 12-19-2006, 04:43 PM   #16
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
I have one cut^^^^just trade me..if you want and buy me a number 2 at mc donald
subaru222 is offline   Reply With Quote
Old 12-19-2006, 08:40 PM   #17
Nactos
Member#: 133920
06 STI
not a bad deal..... but you're in 909.. that's far.... prob better off cutting my own....thanks tho
Old 12-19-2006, 11:30 PM   #18
bluestonepath
Member#: 123641
'04 WRX Wagon
Platinum Dirty Metallic
if no one posts a pic up soon, i'll take a picture of mine tomorrow.
bluestonepath is offline   Reply With Quote
Old 12-19-2006, 11:36 PM   #19
Psybin
Member#: 112719
2014 Evolution X GSR
06 STI & 05 9-2X = Sold
I put a Cobb heat shield on when I installed my TBE. It was only $50.
[IMG][/IMG]
That is the only pic I have handy. Its a nice product, not too hard to install.
Psybin is offline   Reply With Quote
Old 12-19-2006, 11:42 PM   #20
brettm
Member#: 35107
2003 WRX WRB
2006 LGT Silver
Old 12-20-2006, 12:42 AM   #21
Junglist
Member#: 110035
2002 Built Hybrid
MBP
Psybin...heat wrap and a heat shield? I know that's probably the safest route, but wouldn't the wrap be good enough. I went from nothing to the heat wrap, which was pretty easy btw, and I noticed the difference immediately. Although the smoke from the sealant made me nervous for a minute cause I thought I was on fire.
Junglist is offline   Reply With Quote
Old 12-20-2006, 01:47 AM   #22
Nactos
Member#: 133920
06 STI
you can actually notice the different immediately?
Old 12-20-2006, 01:53 AM   #23
Junglist
Member#: 110035
2002 Built Hybrid
MBP
I wouldn't say immediately as in instantly, but you should be able to notice it after a little while as the exhaust heats up. If your going to wrap the exhaust you'll probably notice the new smell too.
Old 12-20-2006, 02:08 AM   #24
Nactos
Member#: 133920
06 STI
how much of the DP should I wrap?
Old 12-20-2006, 02:12 AM   #25
Junglist
Member#: 110035
2002 Built Hybrid
MBP
I'm not sure if there's a set length, but probably at least a foot off of the turbo. I just wrapped my whole DP. It's not hard at all and considering your going to have to take it off the car you might as well wrap the whole thing, but that's your call.
heatshield or not? after DP install pro2cer604 Vancouver Impreza Club Forum -- VIC 24 06-22-2005 09:59 AM
Grinding noise after dp install Jelphree Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 05-17-2005 10:13 AM
White smoke during idle after DP install GoFast ReX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-17-2004 04:07 AM
No CEL after DP install wrxpeed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-22-2004 12:00 PM
Low/slow rising boost after DP install 03WRX83 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-11-2003 05:36 PM
