Old 12-19-2006, 03:52 PM   #1
wagonmasta
Member#: 52880
GGA Rev.D
Default calling all wagons with coilovers
WAGONS ONLY PLEASE
who is running equal spring rates f/r ?
how do you like it ?
have you experimented with other spring rates, or just equal f/r ?
this will be for a daily driver with some auto-x action and some track time when the funding allows.
thanks for the input
phil
wagonmasta is offline   Reply With Quote
Old 12-19-2006, 06:52 PM   #2
wagonmasta
Member#: 52880
GGA Rev.D
nobody?
Old 12-20-2006, 01:10 PM   #3
GTWORX.com
Member#: 97303
2009 WRX and Boxster
Gray and Black
I'd say it depends. You may not like it depending on your driving style, alignment, front and rear sway bars, other mods, etc.
But if done correctly, it can be great.
Are you running stock sways?
- Andrew
GTWORX.com is offline   Reply With Quote
Old 12-20-2006, 01:39 PM   #4
canyon runner
Member#: 108081
05 rs wagon
cgm
I'm running the tein basic which have 280 f/r. I also have the 20mm rsb, steering rack bushings, rear strut bar, and alignment. It's my daily driver as well. I like the balance of the car in sweepers but initial turn in needs improvement. I can get the rear loose with abrupt throttle or braking; which is a nice option due to the lack of initial turn in.
Overall I like the balance of the car, the stiffer springs, (compard to stock, espically in the rear) rsb, and upper rear strut bar really help reduce the understeer in the car. I'm happy with the setup and minimal price paid for neutral handling. Hope this helps.
canyon runner is offline   Reply With Quote
Old 12-20-2006, 03:19 PM   #5
drf
Member#: 72873
2008 Evo X GSR
2002 M3
Not to get off topic, but a front sway would help with turn in.
drf is offline   Reply With Quote
Old 12-20-2006, 03:27 PM   #6
GTWORX.com
Member#: 97303
Gray and Black
It's true....
Old 12-20-2006, 03:48 PM   #7
meld
Member#: 91217
06 Evo IX / 04' R1
Tarmac Black
I have the Megan racing track series with 10k rear and 12k front with dampning little sitffer in the rear, whiteline sway bar front and progress sway rear, noltec end links front and rear, front and rear strut bars, H brace, and the turn in I think is awesome. I am pretty sure it would be better with an ALK.
meld is offline   Reply With Quote
Old 12-20-2006, 07:49 PM   #8
wagonmasta
Member#: 52880
GGA Rev.D
thanks for the info guys..... GTWORX..... i have a perrin RSB w/ endlinks
plan on doing a front sway, bushings and mounts all around, and an ALK (i dont know why their called that..... i know that they increase caster qand aid in initial turn in.... but it seems silly to call it an anti-lift-kit)
Old 12-21-2006, 04:13 AM   #9
Rexwagon03
Member#: 127429
2006 Legacy GT Limit
I have Tein Basic Dampners. Lowered all the way and love it. a little stiff but not too stiff. I think they are perfect
Rexwagon03 is offline   Reply With Quote
Old 12-21-2006, 11:42 AM   #10
Rallyroo
Member#: 67994
Tein RA
8f/6r
Ride comfort is fine with me. At slow speeds like 1-2 mph in traffic it's a little bumpy, but that's a given because of the spring rates. At speed it's not an issue. Non-car enthusiasts think it's rough, car enthusiasts say it's comfortable.
Handles well all around.
Rallyroo is offline   Reply With Quote
Old 12-21-2006, 06:49 PM   #11
REDrum
Member#: 61536
WRX' 04Road02gravel
www.ToltecRally.com
I'm running DMS 40s w/ DP 280# springs F & R.... but what are you looking trune in or out of your suspension?
If you want better turn-in get fender braces and adjustable FSB/end links. Then play with tire presure, toe/camber, and SB adjustment.
REDrum is offline   Reply With Quote
Old 12-21-2006, 06:54 PM   #12
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
The Whiteline Anti Lift Kit is named such because its primary purpose deals with anti-lift geoemtry, respectively reducing both the anti-lift and anti-dive geometry of the stock chassis. The extra caster is just that, an extra side benefit they built in, but is not the primary purpose of the component. The stiffer bushing and extra static caster aid steering precision by reducing dynamic caster losses on turn in, acceleration and braking.
Arnie is offline   Reply With Quote
Old 12-21-2006, 10:36 PM   #13
wagonmasta
Member#: 52880
GGA Rev.D
do you guys with equal rates find it easier to balance the car through a turn using the throttle now?
how about in the other direction.... is lift throttle oversteer dramatically increased with the equal rates ?
i miss being able to balance a car using throttle like in my buddy's E30..... but im in love with my AWD
Old 12-21-2006, 11:14 PM   #14
siopao2000
Member#: 63247
2014 XV Crosstrek
Desert Khaki
to go off topic again:
how much front negative camber are you able to get with most coilovers?
siopao2000 is offline   Reply With Quote
Old 12-22-2006, 08:33 PM   #15
littlewhitewagon
Member#: 103068
11 STI sedan
enough to get the outer 2 inches of tire off the ground...and fling the back all the way around.
littlewhitewagon is offline   Reply With Quote
Old 12-25-2006, 01:12 AM   #16
wagonmasta
Member#: 52880
GGA Rev.D
so has anybody experimented with alternate rates or no?
im looking for comparisons between some of the equal rate set-ups and something like 7k,5k, or 8k,6k....
any help would be nice... thanks
Old 12-26-2006, 07:16 PM   #17
wagonmasta
Member#: 52880
GGA Rev.D
nobody?
Old 12-27-2006, 04:03 AM   #18
David Glasscock
Member#: 25033
06 sti my $$ pit
05 xt my DD
i had jic on my 03 wagon, i think it was 8-6 something like that. it was a bumpy ride at speeds lower then 50 miles an hour, but the faster you went the smoother it got. great coilovers for roadracing but not the best for dd.
David Glasscock is offline   Reply With Quote
Old 12-28-2006, 11:51 PM   #19
wagonmasta
Member#: 52880
GGA Rev.D
still looking for more info here guys.
Old 12-29-2006, 10:59 AM   #20
jezzy
Member#: 121883
I'm following this also.. interested too.
jezzy is offline   Reply With Quote
Old 01-02-2007, 12:23 AM   #21
wagonmasta
Member#: 52880
GGA Rev.D
i'm really trying to setup my car correctly here guys!
any help would be appreciated
Old 01-02-2007, 11:09 PM   #22
ShiroChanWRX
Member#: 60542
2004 WRX SportWagon
I think that most folks run the rear a little softer than the front because more of the weight of the car in in the front.
The rear is then effectively "stiffened" with a relatively stiffer sway bar relative to the front ...
... but don't jump all over me for the RSB statement above! I know that it is an over-simplification, but I want to let you know that people may not be answering because so few run equal rates front and rear.
d
ShiroChanWRX is offline   Reply With Quote
Old 01-03-2007, 08:16 AM   #23
REDrum
Member#: 61536
WRX' 04Road02gravel
www.ToltecRally.com
Originally Posted by ShiroChanWRX View Post
...people may not be answering because...
The OP is looking for unique info he may have to experience first hand.
Wagons are a small market, very few people run coil-overs on'm, and even fewer fully tune or modify the factory CO set ups they put on their wagon. Hell very people I know actualy align and corner balance COs; wagons or not. They just slap'm on and, yo, I gots coil-overs!
Give it a try and let us know
Old 01-04-2007, 07:41 PM   #24
wagonmasta
Member#: 52880
GGA Rev.D
thanks for the input. i will be getting in touch with wgnwheel when i get back to the desert. iirc his rates are 8 and 6 f/r so i will report back to all wagoneers following this thread.
until then.....
phil
Calling all wagons -whos running 18's quickgtp Tire & Wheel 19 04-01-2013 01:23 PM
Calling All Wagons girl Member's Car Gallery 29947 05-20-2010 11:44 AM
Calling All BC Racing Coilover Owners: Post your experiences S1MPSONS Brakes, Steering & Suspension 18 01-21-2010 01:59 PM
calling all wagons subineer Brakes, Steering & Suspension 11 09-28-2002 01:23 AM
