Old 12-19-2006, 10:55 PM   #1
jason2004STI
Member#: 43340
2004 STI
Java Black Pearl
Question Accessport Maps, how often should I reflash the map?
Yes, I sux @ interweb.. I tried searching, but it turned up bubkiz... I am nOOb hear me fail @ interweb....
Anyway, I'm running a '04 STi, COBB full TBE & AP Stage II Map, K&N Typhoon my question is ...
With the ECU learning in our subi's, how often should or would I need to reload the AP map? every month, 3 months, 6 months? once a week? never?
Thanks for any info you can provide!
Peace
Jason
jason2004STI is offline   Reply With Quote
Old 12-19-2006, 10:58 PM   #2
hondaeater69
Member#: 60324
unless cobb changes the map for the better, never.
Old 12-19-2006, 11:01 PM   #3
jason2004STI
Member#: 43340
2004 STI
Java Black Pearl
Thumbs up
Oh really, that's cool... i figured the Learning ECU would "overwrite" or change some things after some time.. Good to know, thanks for the info!
Thanks!
Jason
Old 12-19-2006, 11:05 PM   #4
hondaeater69
Member#: 60324
The ECU is always learning, every second it's running. it does this in stock format, as well as any 'stage' of cobb's tunes. Because the AP uses the OEM's learning capabilities...
only reason to get rid of learning is if you incur some 'bad' learning, and you have since fixed the issue that had caused said bad learning. At that point i would suggest you reset your ECU however, not relfash the base map.
Your ECU will not learn 'around' the accessport. Your ECU will always be trying to hit the parameters reset by your flash, unless some bad learning/experiences are telling it otherwise.
Old 12-19-2006, 11:07 PM   #5
jason2004STI
Member#: 43340
2004 STI
Java Black Pearl
Talking
Oh, that so makes it make more sense.. and connected some very far apart dots for me.. Thanks again Hondaeater69
Jason
Old 12-19-2006, 11:51 PM   #6
scoobysnack69
Member#: 40558
2003 WRX
SRP
I just re-set the ECU like once every other month to re-learn
And also re-set it when the temp changes so it learns around the temp...not sure if it helps, but it cant hurt
scoobysnack69 is offline   Reply With Quote
Old 12-20-2006, 12:18 AM   #7
rkramer
Member#: 118209
2015 WRX Limitec
actually it can! the ecu isn't meant to reset, you can be fairly sure subaru designed it to accomodate temp changes just fine. after you reset it will run default parameters which might be leaner then your engine likes, so yes it can hurt.
unless you have a need, don't reset just for the fun of it.
Old 12-20-2006, 12:21 AM   #8
hondaeater69
Member#: 60324
actually yes it can hurt. say your engine sees knock and retards timing as a result. if you keep resetting the ECU this could in turn be restoring the DAM to a higher value than your ECU likes and keep your engine detonating.
On the flip side, maybe your ECU has advanced timing past the base map's original DAM and you now seeing more timing advance and more power over time. if you keep resetting it the ECU will keep forgetting (for lack of a better term) this 'good' learning and thus revert back to the lower original timing map.
please understand i'm not saying your engine is doing this, the only way to know for sure what your engine is doing is datalog the ECU. However, resetting the ECU for no real reason 1 a month is NOT a good idea.
If your ECU is happy, let it be. if it is not, find out why and fix it. Either way, resetting your ECU or reflashing your ECU all the time is no solution to anything.
Old 12-20-2006, 01:52 AM   #9
Engmus
Member#: 115645
Heres another question.
Before changing anything with the basemap or anything should you reset the ECU to start with to give it a "clean slate"
And then go to stage x?
Engmus is offline   Reply With Quote
Old 12-20-2006, 10:17 AM   #10
hondaeater69
Member#: 60324
when you flash a new base map, learning is reset so no need to clean the slate as it will already be clean. if you were to do a small mod (like say IC hoses) after the flash, then i would suggest an ECU reset so your ECU can now learn the new mod.
Old 12-20-2006, 01:47 PM   #11
05_STi_WRB
Member#: 78126
05 WRX STi
WR Blue
qiuck question. if i reset the ecu do i need to reload the real time map? i know the answer is yes if you are running a different real time from the base, but what if you are using the same maps. example my base map is the stage 2 91 octane map, if i plan to run the real time to be the same as the base do i need to reload it after a re-set?
Thanks.
05_STi_WRB is offline   Reply With Quote
Old 12-20-2006, 02:05 PM   #12
hondaeater69
Member#: 60324
Thanks.
if you plan to run the same base as realtime, no need to flash the realtime. the realtime data is automatically loaded on the base map.
Old 12-21-2006, 08:02 AM   #13
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
If you're concerned about getting the most out of your setup, just get a tune and be done until your next mod.
Spenk is offline   Reply With Quote
Old 12-22-2006, 12:35 PM   #14
Danny d
Member#: 132903
2004 sti
Default ingen map
anyone have a stg2 ingen map they can send me thks in advance im running a stg2 safetly put i have a ingen intake i would like to get full potential out of .....please help a protune would be nice but you know the holidays and all
Danny d is offline   Reply With Quote
How long should you let the map learn before adjusting and reflashing ? joe-6STi Commercial ECU Reflashes 9 11-17-2007 04:36 PM
How often should I change my boost fluid? Projekt Off-Topic 49 01-21-2003 03:39 PM
How often should you stop on a long trip? Valdar Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 08-16-2002 01:29 AM
How often should I replace differential fluids? WRXVII Warranty Issues & SOA Problems 1 03-17-2002 02:28 AM
how often should I change my manual tranny fluid? 96Lconversion New England Impreza Club Forum -- NESIC 6 05-30-2001 01:18 AM
