Old 12-19-2006, 10:00 PM   #1
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Default AWIC Fluid Mixture
So I'm curious what those of you running an AWIC setup are using for your heat transfer medium. Pure water, water & water wetter, anti-freeze, etc...?
I'm bringing up the issue because I'm not confident on the ability of the water wetter alone to provide enough corrosion inibitor for the aluminum and for the pump seals, plus I think the thermal expansion of just water alone is higher then that of a water & anti-freeze mix.
From some of the info I have read at work, a minimum of 25-30% of ethylene glycol is needed to maintain corrosion & bacterial growth protection, as well as inhibitor stability over the operational lifecycle of the fluid.
I'm going to do a little more research, but what I'm probably going to do is mix up a gallon mixture of distilled water with 25% EG (anti-freeze), and the appropriate water wetter for that quantity.
Any comments?
Josh
Legacy777 is offline   Reply With Quote
Old 12-21-2006, 10:24 AM   #2
Legacy777
Member#: 4800
Nobody?
I'm going to do what I mentioned, run 25-30% anti-freeze & water mix with water wetter.
Old 01-02-2007, 02:27 AM   #3
hotrod
Member#: 14141
2002 Impreza WRX
I have run a little bit less than 15-20% antifreeze and water wetter at normal concentration, in the summer without significant issues. On examining the car when I went back to normal mixtures for the winter there were very slight indications that 15%+ is not quite enough. Further research leads me to believe you are correct on choosing 25%.
The high water content mix does improve heat transfer and I would recommend it in very hot weather of a high power car.
Larry
hotrod is offline   Reply With Quote
APS wahser fluid tank (sold) 3oost Engine/Power/Exhaust 34 06-26-2010 02:23 PM
tranny fluid change polarisboy385 Newbies & FAQs 8 06-03-2010 08:25 PM
Brake Fluid/Steering Fluid/Diff. Fluid/Transmission Fluid Jasno999 Brakes, Steering & Suspension 11 09-27-2002 11:22 AM
Anyone else having rich mixture on startup? ratpaws Canada Region Forum 2 06-29-2001 01:20 PM
o2 sensor problems, lean A/F mixture. Help me! Quart2000 Normally Aspirated Powertrain 0 02-07-2001 07:29 PM
