#1 |
Member#: 10188
Vehicle:2007 Forester XT |
I just bought a '91 Legacy wagon, I believe its a 2.2 16 valve na motor. It has 199,920kms on it [about 120 miles]. The previous owner claims the timing belt was down at 160kms but he only had the car since this July and has no bills to prove so who's to say ?? I've checked with the 2 local dealers and the last service this car saw at a dealer was '96.
In the long run I'd rather sink the money into doing the belt than paying 4x that for the damage it could cause. I know on some cars there is a way to take a peak at the belt to see if its worn... some places say if you can read the lettering on the belt its fine , if its worn replace it. Is this possible on a legacy without tearing it down to the point were I might as well just do the belt ? Also , when replacing the timing belt is there anythign else that needs doing ? For example I've heard on Eagle talons you have to do the water pump as well...
#2 |
Member#: 114
Vehicle:'03 Evo, Rice White '01 Erion CBR 929 |
Remove accessory belts and pullies, cooling fans and timing cover. That's about 20 minutes of work with air tools, up to an hour if you've never done it before and only have human-powered tools.
![]() After removing the timing cover you can see all of the timing belt. If it looks worn or cracked, come back here for advice on how to change it or button it up to take into the shop. |
#3 |
Member#: 4423
Vehicle:'04 08 Tribeca, SVX Gold, Maroon |
'91 Legacy is not an interferance motor, if the T-belt brakes it will not damage the engine. It will however be very inconveniant for you.
The T-belt cover is a three piece cover; left, middle, and right. To just inspect the belt you can remove either of the end cover pieces (left or right) and expose the belt. I would not replace the Water Pump unless it has started weeping Coolant or is noisey. |
#4 |
Member#: 2348
Vehicle:2006 WRX TR Steel Grey Metallic |
are there DIY instructions anywhere on hoe to R&R the timing belt? I need to do it on my RS.
#5 |
Member#: 315
South East
I can walk you through it if you like...
you anywhere near atlanta??? I"ll just do it for you. I've had mine off of my MY98 5 times due to one thing leaking or another. sjd |
#6 | |
Member#: 689
NESIC
Vehicle:2005 Outback 2.5 XT Champagne Gold Opal |
Remember to take note of where all the notches are on the pulleys, as the factory doesn't always line the marks on the belt with the pulleys (my guess is that the assembly line worker was showing off that he/she didn't need to use those marks when building the engine). -WaC Wayhe |
| Thread Tools | |
| Display Modes | |
| thought it was the timing belt, what can it be??? | dallison | Normally Aspirated Powertrain | 10 | 11-22-2006 12:36 PM |
| Wife got a ticket...can it be talked down in court? | -=C=- | Off-Topic | 12 | 02-15-2005 11:26 AM |
| PE super strong timing belt...worth it? | shukes24 | Factory 2.0L Turbo Powertrain | 2 | 12-21-2004 03:58 AM |
| Kingpin is @ it again-JDM V7 STi Tear Down | Kingpin | Vendor 'For Sale' Classifieds | 114 | 02-06-2004 03:12 PM |
| Changing timing belt. How's it come off? | Wellhung | Service & Maintenance | 2 | 02-04-2003 08:46 PM |
