Old 12-20-2006, 12:12 PM   #1
breakfasteatre
Member#: 131662
1996 Legacy LS
Default A few questions about my 96 BG
I recently bought a 96 ls wagon and a few things i have noticed now that werent apparent when i test drove it
1. there is a brutal rattle that can only be heard outside the car, im assuming its a heat shield or something? has it just loosened itself?
2. In drive, the car has a really rough idle, vibrates the car really bad at a stop
now, there is a check engine light for this temp sender i have to install. Could this be the problem?
lastly, the rear window squirter is really weak, not even reaching half way up the window with a full reservoir of fluid. is there anything i can do about it?
breakfasteatre is offline   Reply With Quote
Old 12-20-2006, 12:36 PM   #2
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
1. Most likely a heatshield on the headers. You can either try to strap them down more securely or take a sawzall and cut them off.
2. You probably need a tuneup; plugs, plug wires, etc. I'm sure the temp sender isn't helping things.
3. You can try replacing the pump, or try doing something to clean out the line that goes back to the rear squirter. It's a long run from the pump in the engine bay to the rear of the car.
BTW- it's a BK, not a BG
Wiscon_Mark is offline   Reply With Quote
Old 12-20-2006, 01:34 PM   #3
98_soobie
Member#: 17071
2.2L or 2.5L
most likely the rattle noise is sheilds.. cut the fu**ers off!
or it could be piston slap..
the shaking...maybe some motor or trans mounts are in your future....
as far as the washer... pull the thing out and clean the hose...otherwise, stick a needle in the squirter..
98_soobie is offline   Reply With Quote
Old 12-20-2006, 05:25 PM   #4
breakfasteatre
Member#: 131662
1996 Legacy LS
Its definitely not piston slap, so im pretty sure its the heat shield
a tune up was done literally right before i bought the car, thats when the check engine code was found out to be the temp sender
as well, one last question
when i lock the drivers door from the inside by flipping the lock switch to lock, the rest of the doors lock as well, i get out of the car, close the door and they all unlock themselves again. Is it possible to lock the doors using the inside door lock without having to lock the doors with the keys?
Old 12-20-2006, 05:55 PM   #5
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Yep, hold the handle (on the outside) up when you close the door. It makes it a little harder to lock your keys in your car
If it's an LS, it's a 2.2L
Old 12-20-2006, 07:48 PM   #6
legacy99black
Member#: 52238
2001 Legacy GT LTD
Hummer Black
Originally Posted by 98_soobie View Post
or it could be piston slap...
Going by the OP description of the noise, holy bahjesus, I'd be afraid or the car blowing up (not that it would...) or something if the pistons slapped that much.
I'm gonna say heat sheilds. And like soobie, said, cut the f***ers off.
Rob
legacy99black is offline   Reply With Quote
Old 12-20-2006, 11:40 PM   #7
biggreen96
Member#: 12535
vf39 06 5MT XT
92 Legacy Rally EG33'd
I had wicked heat shield rattle... I took metal wire and secured the heat shields with that.
biggreen96 is offline   Reply With Quote
Old 12-21-2006, 12:40 AM   #8
sha_zapple
Member#: 41012
1998 Legacy L
I took a hammer and a flathead punch and bent the ends so they push up against the tubing
sha_zapple is offline   Reply With Quote
Old 12-22-2006, 09:44 AM   #9
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
2. In drive, the car has a really rough idle, vibrates the car really bad at a stop.
Now, there is a check engine light for this temp sender i have to install. Could this be the problem?
Last year When I bought my used '96 Legacy "L" Sedan (also with 4EAT) I had problems with a significant shake while idling in Drive while waiting for the light to change. I found as an interm step, simpling shifting into neutral cured the problem (Just remember to shift back in to drive when the light changes).
I found dropping a bottle of Cheveron Techron Fuel System cleaner really helped to reduce the shakes, and after using a bottle of this stuff at every other fill up eventually cured the issue after using 2-3 bottles.
At $7.00 a bottle this stuff is not cheap, but a twenty dollar cure is cheaper then actually spending money to have work done on the car.
Jonathan is offline   Reply With Quote
A few questions about my Subaru Famous Last Words Newbies & FAQs 2 08-18-2004 08:05 PM
A few questions about my BE... polski Legacy Forum 12 01-17-2004 08:43 AM
Few questions About My front Lip and a Carbon fiber hood w/my TXS front mount??????? BLUETURBOWRX Interior & Exterior Modification 0 06-02-2003 10:53 PM
ECU needs to be re-programmed- a few questions about my CEL codes Slvrblt New England Impreza Club Forum -- NESIC 6 04-26-2003 03:12 AM
a few questions about my mods ants wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-18-2002 07:38 PM
