Old 12-20-2006, 01:40 PM   #1
doubledribble
Member#: 42912
2003 Outback Sport
bird **** & door dings
Default quick question on rs to wrx front brake conversion
i know all you need are caliper brackets and rotors to do the swap. my question is about the differences between the wrx and rs calipers. are they roughly the same? if they are different would there be a benefit to swapping in the wrx calipers/pads for more bite? thanks.
doubledribble is offline   Reply With Quote
Old 12-21-2006, 02:23 AM   #2
neko
Member#: 46500
Now with 200% more
room 4 girl-on-girl fun.
yup, need those bigger rotors (the reason for the swap), and caliper brakcets to locate the caliper further out. But the caliper from an early 02/03 wrx is the same as your RS, and so is the pad. the late 03 thru 05 wrx's have a different bracket (same caliper i think) and hold a slightly larger pad.
neko is online now   Reply With Quote
Old 12-21-2006, 05:13 PM   #3
doubledribble
Member#: 42912
2003 Outback Sport
thanks.
upon second thought, i think i'll need to take the calipers apart to verify that they are the same FMSI #'d pads as the ones listed on stop tech.
http://www.stoptech.com/tech_info/faq_wrxcalipers.shtml
RS to WRX front brake swap problem SubyMass Brakes, Steering & Suspension 3 05-20-2009 01:04 PM
2.5rs to wrx front brake conversion, what is up?? qualityracer Brakes, Steering & Suspension 3 05-22-2008 03:15 PM
FS: RacingBrake RS to WRX FRONT brake caliper monting brakets tkturboh4 Suspension/Brakes/Handling 0 01-27-2008 04:43 PM
OBS to WRX front brake conversion....moving the front discs to rear chri3 Brakes, Steering & Suspension 6 12-19-2003 03:32 PM
RS--> WRX front brake conversion- small questions Concillian Brakes, Steering & Suspension 8 08-27-2003 05:48 PM
