Old 12-20-2006, 04:12 PM   #1
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Default Keyless remote programming
I searched, but I couldn't find it. I'm sure one of you is going to link to it in about 10 seconds, but...
Anyways, how do you do it for a 98 with the rectangular remote with two buttons. I've done it once before and it was easy, but can't seem to find out how or remember.
All I could find were methods for a WRX, which I'm pretty sure is more complicated than mine will be.
thanks in advance.
Jared
gtwagon941 is offline   Reply With Quote
Old 12-20-2006, 06:21 PM   #2
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
edit:
just found it on cars101.com
Programming or Overriding the Alarm when you have lost the remote
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (button under dashboard)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button
Press lock (left) button the remotes to be programmed. The door locks will cycle one time.
Exit programming mode by releasing Programming button under dashboard and turning key to off.
how to program Subaru alarmCode Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area.
This button must be pressed while programming remotes or if the battery was disconnected and the lights are flashing.
Programming Keyless Remote nester Electrical & Lighting 21 11-18-2007 03:23 AM
programming keyless remote? auricom Car Audio, Video & Security 14 08-27-2005 05:13 PM
will a turbo timer affect programming new keyless remotes? devin Electrical & Lighting 13 07-08-2005 03:03 PM
Help, Keyless remote won't program dbenz Electrical & Lighting 0 06-12-2003 05:38 PM
keyless remote programming??? kalesun Car Audio, Video & Security 1 01-09-2003 03:16 AM
