Old 12-20-2006, 09:47 PM   #1
boomerboy
Member#: 135465
Default Torque Specs for 1990 Legacy
I have a 1990 Legacy, and I need to know the torque specs for the cylinder head bolts. I have a Haynes manual, but I used the specs it suggested and ended up breaking the first bolt I tightened.
I also need to know if I should replace the head bolts with new ones. Is that recommended?
Thanks, folks.
Boomerboy
boomerboy is offline   Reply With Quote
Old 12-20-2006, 10:12 PM   #2
Sneeky Pete
Member#: 97745
2005 OBXT 5spd red
05 OB Lmited Black
Are you sure your tq wrench isn't broken?
I dont know the exact specs but 70-90lbs shouldn't break bolts...ever
Replacing the bolts isnt required but could be a good move.....speacialy if their breaking off at 85lbs of torque
Goodluck hope I helped a bit
Sneeky Pete is offline   Reply With Quote
Old 12-20-2006, 10:48 PM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Breaking a head bolt is pretty unheard of, and I have torque many above and beyond call of duty.... double check that damn torque wrench!
Old 12-20-2006, 11:21 PM   #4
ivwarrior
Member#: 100610
MBP
Note, this is from a 99 manual, I don't have access to a 90. If this is the same as what your Haynes manual says, get a new torque wrench.
Tighten cylinder head bolts.
(1) Apply a coat of engine oil to washers and
bolt threads.
(2) Tighten all bolts to 29 N·m (3.0 kg-m, 22
ft-lb) in alphabetical sequence.
Then tighten all bolts to 69 N·m (7.0 kg-m, 51
(3) Back off all bolts by 180° first; back them off
by 180° again.
(4) Tighten bolts (a) and (b) to 34 N·m (3.5
kg-m, 25 ft-lb).
(5) Tighten bolts (c), (d), (e) and (f) to 15 N·m
(1.5 kg-m, 11 ft-lb).
(6) Tighten all bolts by 80 to 90° in alphabetical
sequence.
CAUTION:
Do not tighten bolts more than 90°.
(7) Further tighten all bolts by 80 to 90° in
CAUTION:
Ensure that the total “re-tightening angle” [in
the former two steps], do not exceed 180°.
Bolt layout
<---Front of head that direction
C A F
E B D
ivwarrior is offline   Reply With Quote
Old 12-22-2006, 09:13 PM   #5
boomerboy
Member#: 135465
The Hayne's manual suggested 132 foot pounds. I checked it three times before I torqued it. I'll try the ideas suggested here.
Thanks.
want short ram for 1990 legacy jim747 Legacy Forum 3 03-27-2006 10:26 PM
WTB: Clutch for 1990 Legacy Ehawley Private 'Wanted' Classifieds 0 04-24-2005 07:34 PM
fuel injectors for 1990 legacy MBPEJ20 Private 'Wanted' Classifieds 0 06-07-2004 09:19 PM
Torque specs for Legacy!!! Flexy Service & Maintenance 2 11-07-2003 02:56 PM
KYB AGX for 1990 legacy? d4d4d4d4 Brakes, Steering & Suspension 4 07-10-2003 06:52 PM
