Old 12-21-2006, 04:22 PM   #1
bobko
Member#: 64646
1995 Legacy wagon
Green
Default Abnormally low idle on a 1995 Legacy
My 1995 Legacy suddenly started dropping its idle speed to 500 RPM or less on the tach -- it usually idles at 700-750 RPM. The car will now occasionally stall when it drops to ultra-low idle. It does not do it from a cold start or after the car has been driven for 15 minutes or so, but it will do it if I have to come to a stop during the first 15 minutes -- which is almost everytime I use the car.
The car has 160k miles and has a manual transmission. It is a 2.2-liter engine. I fussed with all the electrical connections and grounds in the engine bay to make sure things were connected properly, and this did not make a difference. The car runs fine otherwise.
What should I look for? Is this an IACV (idle [something] control valve) problem? Should I clean the IACV? Any suggestions?
--Bob
bobko is offline   Reply With Quote
Old 12-21-2006, 05:46 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
The IACV (idle air control valve ) is probably a good suspect to start out with. It could very well just be gunked up after 160,000 miles, but once the engine's fully warmed up it's OK? I dunno. Can't hurt to pull it off and clean it out, though, and see if that fixes the problem.
Pat
Old 12-21-2006, 06:13 PM   #3
sha_zapple
Member#: 41012
1998 Legacy L
check out the vacuum lines too
sha_zapple is offline   Reply With Quote
Old 12-22-2006, 08:25 AM   #4
bobko
Member#: 64646
1995 Legacy wagon
Green
Thanks for the tips!
--Bob
Old 12-22-2006, 09:12 AM   #5
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Try dropping the contents of a bottle of Cheveron Techron fuel system cleaner down the fuel filler and mixing with a full tank of gasoline, and see if that improves the situation some.
I have a '96 Legacy "L" with the 2.2 Litre and a "4EAT" Automatic that used to shake pretty bad idling at a traffic light, that seems to be behaving much better after 2-3 treatments of this stuff.
Jonathan is offline   Reply With Quote
Low idle speed when a/c is on hybrid gti 2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-22-2008 10:10 AM
Low idle in '92 Legacy SS shemoves Pre-2002 Factory Turbo Powertrain 12 03-28-2007 12:56 AM
low/rough idle on warm starts raginbull74 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 01-23-2006 06:23 PM
Low RPM idle on stock WRX? subynube Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-06-2005 08:30 PM
WRX Wheels on a 1995 Legacy Wagon DF WRX Legacy Forum 12 01-21-2003 07:43 PM
