Old 12-21-2006, 07:05 PM   #1
07blacktr
Member#: 134458
Default hks fcd
hey im new to the forums and to subaru i have a 07 wrx tr with tbe,injen short ram and a walbro 255 fuel pump and in 3rd gear and on it is hitting fuel cut so i bought a hks fcd and wanted to know wat to set it to cause first and second it is hiting 14 psi and right before it cuts out its at 16psi....what should i set the fcd too?
07blacktr is offline   Reply With Quote
Old 12-21-2006, 08:59 PM   #2
Nuke209
Member#: 108089
2003 WRX
NF Performance
oh no, injen intake...that's a no no
fuel pump, i think stock's good on stock turbo
they use the stock one on the vf39 upgrade too
Nuke209 is offline   Reply With Quote
Old 12-21-2006, 09:19 PM   #3
qoncept
Member#: 44762
2013 BRZ
With the catless exhaust, you're most likely getting boost creep you shouldn't be (or it wouldn't be so much higher than stock), and the real solution would to be to get some sort of engine management to hopefully tune it out rather than raising the boost limit with the FCD or you're very likely going to see det.
qoncept is offline   Reply With Quote
Old 12-21-2006, 10:31 PM   #4
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
(US)d00000000000000000000000d.........you gonna blow yo engine! (/US)
Get some engine management before you put a rod through the block.
Old 12-22-2006, 01:03 PM   #5
07blacktr
Member#: 134458
would the cobb accesport work or better off getting a unichip and protune?
Old 12-22-2006, 01:55 PM   #6
Turbo_Mike
Member#: 130276
2004 STi 40R RWD
Rootbeer
AP should take care of things
A custom tune would be the best.
A protune is done with an AP.
This forum is for none of that. Reflash using a laptop.
Turbo_Mike is offline   Reply With Quote
Old 12-22-2006, 01:55 PM   #7
07blacktr
Member#: 134458
does the accesport adjust fuel cut?
Old 12-22-2006, 02:23 PM   #8
Ziggyrama
Member#: 53665
2011 STI Stg2 w/EBCS
2012 Tribeca Ltd.
AP will adjust your fuel cut threshold. I am not sure what the stock fuel cut is set at on 2.5L WRX but you're most likely hitting the fuel cut because you're running higher boost than the stock ECU thinks is safe. Based on your post, it's probably around 16psi which makes sense to me. This is a safety feature of the ECU to prevent accidental uber-overboosting. It's funny because I just answered a similar post where a guy was running an MBC and was hitting the fuel cut and didn't know what was going on. This is why you should really run EM given your hardware: open source reflash, cobb, UTEC, etc, etc.
Ziggyrama is offline   Reply With Quote
Fs: Ihi Vf39, Hks Fcd, Hks Sld firstHKS Private 'For Sale' Classifieds 22 02-02-2006 11:37 PM
HKS FCD setting AZScoobie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-26-2002 10:17 PM
need help with HKS FCD slammedWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-12-2002 06:12 PM
Hks Fcd ChrisWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-29-2002 04:48 PM
HKS FCD and Apex S-AFC MBC slammedWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-21-2001 09:16 AM
