Welcome to the North American Subaru Impreza Owners Club Wednesday April 1, 2015
Old 12-22-2006, 01:05 AM   #1
Jaredm83
Member#: 65816
2014 Forester XT
Default Can someone disect my log?
Drop me a pm with your email and I will email my exel file of a 3rd gear pull to redline. Thanks, Jared
Jaredm83 is offline   Reply With Quote
Old 12-22-2006, 08:56 AM   #2
tachrev
Member#: 115260
04 WRX
205/22E Hybrid w/ VF39
Do you think you are seeing a problem, or just want a second opinion?
tachrev is offline   Reply With Quote
Old 12-22-2006, 09:33 AM   #3
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
PM sent. I will take a look.
blkscooby is offline   Reply With Quote
Old 12-22-2006, 01:40 PM   #4
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Any reason you just can't post the relevant section here?
drees is offline   Reply With Quote
Old 12-22-2006, 08:14 PM   #5
Jaredm83
Member#: 65816
2014 Forester XT
I just couldn't figure out how to do that? Also, I cant seem to be able to jsut log the relevant info. Everytime I try I get everything!
Old 12-22-2006, 09:15 PM   #6
blkscooby
Member#: 44422
2009 G8 GT
Please post your mods.
As far as logging, when you select "Real time data" in ECUExplorer, you should be able to select/ deselect the paramters in the right hand window via the checkboxes. You definitely logged many parameters that you probably don't need to in the log you sent me.
If you have your map, that would be helpful as well.
Old 12-22-2006, 09:56 PM   #7
blkscooby
Member#: 44422
2009 G8 GT
Just based on a quick glance, your KC drops from 7 to -1 which may mean you are having significant knock. I would need to see your map and check the timing correction table to be sure.
Heavy knock = very bad
Old 12-23-2006, 12:57 AM   #8
Jaredm83
Member#: 65816
2014 Forester XT
Well I did another pull and the KC never went below 2?
Old 12-23-2006, 03:11 AM   #9
drees
Member#: 25905
2003 Silver Wagon
Just open the .csv file with notepad or wordpad and then use cut/copy/paste.
Old 12-23-2006, 10:25 AM   #10
blkscooby
Member#: 44422
2009 G8 GT
A positive KC value is necessarilty good either. Your ECU map file has a KC tabel that has a KC value for s specific RPM and engine load. If the KC is below this number then the car is most likely experiencing knock.
Ex- KC in ECU table 4000 RPM, load of 3.0 calls for 8. If you log a KC value of 5 at this load, the ECU has pulled the timing back to correct knock.
I need to see your ECU map file to compare it to your logs.
Old 12-24-2006, 01:01 AM   #11
Jaredm83
Member#: 65816
2014 Forester XT
What would the relevant fields be that i would need to check in ecuexplorer and I will post it here.
Old 12-24-2006, 11:30 AM   #12
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
I personally would log:
Engine Speed
Mass air Flow
Intake Air Temperature
Knock Correction
Manifold Relative Pressure
Possibly Injector duty cycle to make sure you aren't maxing out the injectors
Also a picture of your fuel/timing/timing correction maps could help us identify where on your maps you need to work on.
Old 12-25-2006, 10:57 PM   #13
06rexwagon
Member#: 114730
2006 WRX Limited Wag
9.8@150
Engine Speed
Mass air Flow
Knock Correction
Don't forget engine load
06rexwagon is online now   Reply With Quote
Old 12-26-2006, 07:24 AM   #14
blkscooby
Member#: 44422
2009 G8 GT
Advance Multiplier, Total Timing, Boost, WGDC, Throttle Position, Coolant Temp- all of these also. I sent Jaredm83 one of my lods as an example and helped him with how to log these values also.
Old 12-26-2006, 01:31 PM   #15
Jaredm83
Member#: 65816
2014 Forester XT
Which advanced multiplier and engine loads do I need to make active? I used the ones you sent me blkscooby, and I'm seeing no change in value during a pull? I think they were stuck at 8 and 2.66? Anyone know which ones I needto activate for an 02? Also, thanks again blkscooby. I'm going to sit down today after I get off work and really put to use all the stuff you sent me! Thanks for the help guys, Jared
Old 12-27-2006, 03:15 PM   #16
blkscooby
Member#: 44422
2009 G8 GT
Check out this link for the correct engine loads and IAM
http://www.scoobypedia.co.uk/index.p...emoryLocations
Old 12-27-2006, 07:46 PM   #17
Jaredm83
Member#: 65816
2014 Forester XT
thanks for that info, i looked for it everywhere. Im working with someone and we are using the 20124 address. Is that a problem?
Old 01-03-2007, 03:27 PM   #18
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
wow, no 03 information? i think ive found my correct address for IAM but i'm not totally sure..
druxboyz is offline   Reply With Quote
Old 01-04-2007, 04:45 AM   #19
drees
Member#: 25905
2003 Silver Wagon
On my 03 (A4TC400L) I use memory address 0×20120 for IAM and then just calculate load manually. I added that address to the wiki, too.
Old 01-04-2007, 11:32 PM   #20
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
His ROM is being corrected here.
http://socob.bb/forum/viewtopic.php?t=185
There is a full thread in the Custom Tuned, but it is not accessible until we are finished. I haven't heard from him since Christmas and I hope he is ok.
west_minist is offline   Reply With Quote
Old 01-04-2007, 11:40 PM   #21
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
Originally Posted by drees View Post
On my 03 (A4TC400L) I use memory address 020120 for IAM and then just calculate load manually. I added that address to the wiki, too.
that seems right. My 20120 gives me good IAM numbers. For load, I believe its 200BE. Using the 16bit calculations, the Load numbers are pretty close to what it should be. The most difference i get is .08 from the 200BE address. Is .08 much?
Can someone check this log? ezil71 AccessPort 0 05-08-2010 11:08 AM
Can someone check my logs? CarterMarkham Commercial ECU Reflashes 11 11-12-2007 12:19 PM
Off boost problems, can someone post data logs kahtep Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-02-2007 11:13 AM
can someone post my pics zx2boy Legacy Forum 14 12-06-2001 05:01 PM
Can someone convert my AutoX 8mm video to an .avi or mpg for me? Jessie James General Forum Archive 6 03-27-2001 04:32 PM
