Old 12-22-2006, 12:40 PM   #1
baj
Member#: 127409
Default Differences between '07 2.5i and WRX
I read something suggesting that the 2007 2.5i and WRX suspension and steering are the same. Is this true (spring rates, struts, etc.)? Will a 2.5i handle just as well as a WRX, or does the WRX have a stiffer suspension?
I know the WRX has more power and bigger brakes and wheels, and I think it has a LSD in the rear, but beyond that it's hard to tell from what I can find on the subaru website. If anybody can give me a rundown on the differences between the two models I would appreciate it.
baj is offline   Reply With Quote
Old 12-22-2006, 03:09 PM   #2
Staples
Member#: 132586
:( Subie-less
the only thing you need to worry about is "TURBO"
Staples is offline   Reply With Quote
Old 12-22-2006, 03:29 PM   #3
Wannascooby
Member#: 112992
2006 WRX TR
Crystal Gray
haha, thats kinda true...I'd like to know the difference in suspension bits too. I always see wrx vs sti and what if i turboed my rs threads, first time I've come across a rs vs wrx suspension thread. I would assume that the wrx should have a slightly more aggresive spring rate, and thicker sways.<--assumption
Have you tried a search?
Wannascooby is offline   Reply With Quote
Old 12-22-2006, 04:10 PM   #4
soobiesvx93
Member#: 70782
2006 Impreza 2.5i
I would imagine that the WRX is beefed up all around more than the 2.5i
Not sure about it though.
soobiesvx93 is offline   Reply With Quote
Old 12-22-2006, 04:15 PM   #5
djoye
Member#: 50072
2003 WRX
[email protected] 20psi
I'll be impressed if they started putting better suspension on the WRXs.
The suspension that came on mine (2003) could've been used on a 1986 Oldsmobile, likewise for the brakes.
djoye is offline   Reply With Quote
Old 12-22-2006, 04:16 PM   #6
CatfaceType-R
Member#: 81102
^^^i don't know if i'd go THAT far...
CatfaceType-R is offline   Reply With Quote
Old 12-22-2006, 04:19 PM   #7
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
If you were going at a rate of 90mph and the olds was going 30mph this might be true.
I'm really sick of people knocking on the suspension of the WRX. Bodyroll might be a bit much, but the tires are the real culprit here.
Wiscon_Mark is offline   Reply With Quote
Old 01-07-2007, 11:12 AM   #8
WRXLTD
Member#: 136314
2014 Grand Cherokee
I just traded my 2005 Impreza 2.5L RS for a 2007 WRX Limited...two different animals handling wise.
My new 2007 WRX has a stiffer suspension and wouls easliy out-handle my old 2.5L RS.
WRXLTD is offline   Reply With Quote
Old 01-07-2007, 11:32 AM   #9
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
suspension in the WRX is stiffer than the 2.5i
wrx has a turbo, 2.5i does not
wrx has more expensive insurance, 2.5i is less
wrx has bigger brakes, bigger wheels
wrx has a different exhaust
etc etc
2 different cars
test drive them both, do some research, choose whatever suits you best
Jamie
Old 01-07-2007, 01:55 PM   #10
nemocity
Member#: 98686
2005 Impreza 2.5RS
The dark blue one
The 2005 RS rear sway bar is a glorified coat hanger @ 13 mm. Change this to 20 mm and add good 17" 45 series rubber and voila...big difference, indeed!
nemocity is offline   Reply With Quote
Old 01-07-2007, 01:57 PM   #11
FigNuts
Member#: 125413
Just don't get a 2.5i with the intention of throwing a turbo on it - very bad idea. If you plan to performance mod your car, i say, get the wrx. Otherwise the 2.5i can be made very nimble.
FigNuts is offline   Reply With Quote
Motor differences between a 2.5i and a WRX Jeff Jeff Normally Aspirated Powertrain 29 07-02-2016 10:40 PM
Difference between 2007 2.5i and 2005 RS .50CaŁ General Community 4 03-14-2008 11:20 PM
What is the difference between a 2.5RS and a 2.5i Subaru Impreza? rhinh25 Normally Aspirated Powertrain 50 07-29-2007 12:00 AM
Differences between Legacy 2.5i special ed. & Outback 2.5i Limited? left footed whooten Legacy Forum 2 08-03-2006 07:10 PM
what is the difference between a 2.5rs and the ts with the 2.2 engine for the gc8 bebeGDB Subaru Conversions 8 01-26-2004 11:08 AM
