Welcome to the North American Subaru Impreza Owners Club Wednesday September 2, 2015
Old 12-22-2006, 12:36 PM   #1
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
Default Is the BPV for an 06 STi the same as an 02 wrx?
I had bought a sway bar from another member on here and he threw in his brand new stock 06 STi BPV in for free. I'm running the stock one on my 02 wrx right now with a p/p vf22 hitting around 19-20 psi. I was wondering if STi bpv would hold boost better or are they the exact same. To me if you push against the spring it feels like the STi is stiffer. I get a little flutter coming from the stock 02 bpv when I shift. I have 88,000 miles on the car and thought that the 02 bpv might be leaking a little but I'm not sure.
breathinez is offline   Reply With Quote
Old 12-22-2006, 12:48 PM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
IIRC they are exactly the same, I think it says so in the BPV/BOV faq by unabomber.
Old 12-22-2006, 12:56 PM   #3
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
Yeah it does. I just looked over that thread and that seems to be what is being said. But the part numbers are different on the top of bpv. One ends in 5 and I think the other ends in 6 but other than that the numbers are the same. My stock 02 bpv maybe be just a little weak sine it has 88,000 miles. I think I might crush the top on the old stock bpv and see what that does.
Old 12-22-2006, 02:12 PM   #4
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Not to hate, and only for future reference:
Part Number FAQ
Part numbers denote part, part manufacturer, part manufacture date, the company that makes the box the part came in, the hair and eye color of the delivery person that brought the part off the boat from Japan, etc.....
So....you can never rely on part numbers for ANYTHING at ANYTIME EVER, from now until when the earth blows up.
So you can have two identical parts with two different part numbers.
Old 12-22-2006, 02:19 PM   #5
02REX4LIFE
Member#: 98865
2006 Legacy 2.5i
"Now its 06LEGGY4LIFE"
Excuse my ignorance but what do you mean by "crush" the top on the stock bpv? im confused.
02REX4LIFE is offline   Reply With Quote
Old 12-22-2006, 02:20 PM   #6
Force
Member#: 123515
2005 vette c6 z51
LeMans Blue
The 'cap' on the bpv is 'crushed' inwards to stiffen up the spring so it holds more boost.
Force is offline   Reply With Quote
Old 12-22-2006, 02:32 PM   #7
02REX4LIFE
Member#: 98865
2006 Legacy 2.5i
Oooooooohhhhhh! ok gotcha! thanks man
Old 12-22-2006, 02:49 PM   #8
02REX4LIFE
Member#: 98865
2006 Legacy 2.5i
so if i were to get an 05 sti bpv and put it on my 02 wrx would there be a boost psi difference or no? just curious.
Old 12-22-2006, 03:55 PM   #9
Force
Member#: 123515
2005 vette c6 z51
LeMans Blue
nope, I'm pretty sure they are all the same
Old 12-22-2006, 06:21 PM   #10
WikdRX
Member#: 76795
Too Low For Nasioc
#007 SOLD- now "11 Legacy
IIRC the parts are the same, but the SOA part numbers for the two are different, if that helps at all.
'02 WRX BPV - 14471AA120
'06 STi BPV - 14471AA143
WikdRX is offline   Reply With Quote
Old 12-22-2006, 07:17 PM   #11
Magnum626
Member#: 62856
MBP SQC#197
Stockpiling parts...
Just to throw this in the mix:
Is the JDM BPV the only one that's different?
(in case this comes up in a search. )
Magnum626 is offline   Reply With Quote
06 sti lower control arms onA 02 wrx kimo in sd Brakes, Steering & Suspension 2 08-14-2009 09:02 PM
06 sti struts and springs on 02 wrx? theguy Brakes, Steering & Suspension 12 09-29-2008 06:03 PM
what from an 06 sti will fit on an 05 leg gt ltd jason bouchard Legacy Forum 3 02-25-2008 12:37 PM
06 STI struts/spring on a 02 WRX stanghater Brakes, Steering & Suspension 5 06-09-2007 12:26 AM
04 Rear STi tophats same as 04 Rear WRX tophats? JeffrWRX Brakes, Steering & Suspension 3 04-24-2007 01:15 AM
