Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 12-22-2006, 02:52 PM   #1
wrx88
Member#: 112611
2006 WRX TR
Default Trouble Logging
I'm having trouble figuring out why i am unable to datalog my 2006 wrx using the latest ECUexplorer. I also don't know which model to select under options>ecuflash>models. Can someone please provide me with some insight? I've searched ocecuroms.org and couldn't find anything that helped. Thanks.
wrx88 is offline   Reply With Quote
Old 01-08-2007, 11:04 PM   #2
wrx>dsm
Member#: 127683
Im in the same boat, i was able to read and save my stock rom i know that for sure, and ingenuity will log my car so i know im hooked up right, but ecuexplorer will not work! It will list subaruv1.3 cable so it recognizes it but it always says ecu disconnected. Ive tried every method i could find including the whole reinstall software and driver thread. Also in enginuity i try to look at my stock map to learn what to look for and if you try to put the maps into 3d mode the whole program shuts down... why would it do that?
wrx>dsm is offline   Reply With Quote
Old 01-09-2007, 04:22 AM   #3
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
I had that problem too, you need to right click on the cable and select SSM Diagnostics .. hope this helps
Chris
criscross79 is offline   Reply With Quote
Having Trouble Logging! bedheadben Open Source Reflashes 4 05-21-2008 03:21 PM
Trouble Logging with Enginuity Soon2BturbodRS Open Source Reflashes 4 01-11-2008 07:10 PM
If you are having trouble logging on to SubaruForester.com ... wallew General Community 5 07-13-2005 11:22 PM
Trouble logging in Uncle Scotty General Community 0 07-18-2002 03:42 AM
Lighten Pulley trouble Log TerenceT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-28-2002 09:51 AM
