Old 12-22-2006, 02:31 PM   #1
NITROS
Member#: 41561
04 GT3076 2.1
Stroker = Broken 3rd
Have a Nice Day? Another problem with hybrid thread
So my car started run like **** all of the sudden. I have a P0172 code system too rich and get p0301 a misfire code in cylinder #1.
Now im not making this thread asking for help but if you want o chime in, your more then welcome to. I'm simply making this thread to help others out, say they run into something similar. I will post what I have done to diagnosis the problem.
Things that need to be done or checked?
1) Spark Plugs (Changed to copper with 1000 miles on the block, .30 gap, will recheck gap and for fouling.)
2) Compression Check (cyclinder 1 was at 165 2-3 months ago, the others were 2-175, 3 -180, 4-175.)
3) Pressure Test (to check for leaks, vacuum hoses and what not)
4) Leak down test
NITROS is offline   Reply With Quote
Old 12-22-2006, 08:18 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Did you change the cams when you did the swap?
Tim Sanderson is offline   Reply With Quote
Old 01-08-2007, 08:59 PM   #3
NITROS
Member#: 41561
04 GT3076 2.1
Spark plugs look good double checked the gap.
Compression is good 1-3-2-4 = 160-170-170-175.
I think i have figured out what the problem was. So far its been 4 days and no CEL. I had been running the UTEC in OPEN LOOP from 0 TPS. I have since changed it to 25% TPS and it seems to have cleared everything up. We will see what happens in the upcoming days.
Old 01-10-2007, 10:52 AM   #4
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Isn't the compression on 1 a little low compared to the others?
CoolRex is offline   Reply With Quote
Old 01-10-2007, 11:21 AM   #5
NITROS
Member#: 41561
04 GT3076 2.1
Yes you are right, But it always has been low. It been the same since day one. I think it maybe due to a valve or something. But it still is in a good range.
Old 01-10-2007, 12:48 PM   #6
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Yes it is still in a good range. Can't wait until I do mine but it'll be a while.
Yet another Problem with my aquamist system.. 96convt Water/Methanol Injection, Nitrous & Intercooler Cooling 7 08-22-2009 03:46 AM
Ugh another problem with my Subaru dexion Service & Maintenance 18 04-10-2008 08:03 PM
problem with hybrid sti platinumstar17 Built Motor Discussion 0 12-03-2007 11:35 AM
Another WRX head/STI bottom end hybrid thread Carlito2002WGN Built Motor Discussion 11 04-21-2007 03:11 AM
The "if you have a problem with me" thread Tex-WReX Texas Impreza Club Forum -- TXIC 18 01-22-2005 07:10 PM
