Old 12-22-2006, 06:55 PM   #1
clbd39
Member#: 104078
2013 WRX
Default My NEWLY ported box project
I made a ported box over the summer and I was really unhappy with it, it was big, bulky, looked bad, and slid around a lot.
So I decided I'm going to build a new one and put it on the back side of the trunk. I'm debating on a slot port or 2 circular flared ports, if I can get them to work lol.
So today I made a mock set up in cardboard, trimmed, and put it together to make sure it went in and out with no problems, and it works well comes in and out nicely lol
So I'll be running my Directed Audio 2400D amp with my RE SX12 (Resonant Engineering, www.reaudio.com) tuned to 35 Hz with 2.0 cu ft after sub displacement
here's the mock setup, hopefully it will turn out just how I want it, the majority of it will be made out of wood, with the corners and walls made of fiberglass, and i will probably add a few thin layers of bondo for curves and smoothness
I'm wanting to have this done by Sunday evening so if all goes well it'll be done for Christmas yay
clbd39 is offline   Reply With Quote
Old 12-22-2006, 07:07 PM   #2
BOOST3DWRX
Member#: 96454
2012 STi Stage 2
Looks good so far!
BOOST3DWRX is offline   Reply With Quote
Old 12-22-2006, 07:39 PM   #3
clbd39
Member#: 104078
2013 WRX
i'm running into port fitment issues, my debate now is to use the 2 4" flares and combine them into one which I will construct for inside the box but keeping the same cross-sectional area, or just doing a slotted port... decisions decisions....
Old 12-23-2006, 12:32 AM   #4
02BlueSuperRoo
Member#: 78290
2011 WRX 5-door
SSM
Dude, you make a new box every 2 months
Lookin' good. Keep us updated!
02BlueSuperRoo is offline   Reply With Quote
Old 12-23-2006, 03:09 AM   #5
clbd39
Member#: 104078
2013 WRX
lol i was unhappy with my last ported box lol so it was only in for about a week and a half so much work, for so little love
but this on fits better, looks better (hopefully) and it's out of the way
i'im going out of town tomorrow morning, so i guess it won't be done by Christmas oh well it'll be done soon lol
Old 12-25-2006, 01:27 PM   #6
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
so did this get done or what?
Chp_Stix is offline   Reply With Quote
Old 12-25-2006, 02:31 PM   #7
Daishi00
Member#: 78952
2005 WRX
CGM
Did you even read the post above yours where he says it won't be done by Christmas?
Daishi00 is offline   Reply With Quote
Old 12-25-2006, 09:11 PM   #8
02BlueSuperRoo
Member#: 78290
2011 WRX 5-door
SSM
roffle
Old 12-26-2006, 02:23 AM   #9
clbd39
Member#: 104078
2013 WRX
lol my brother came home today so he's going to help me figure out the port tomorrow
Old 01-01-2007, 12:33 PM   #10
clbd39
Member#: 104078
2013 WRX
Alright, I've been very busy, and I finally had a chance to work on MY box I have a few pics I took from last night, it's not much, but it's shaping together and some better pics will be posted later today!
so here are a few...
This is the back and bottom...
And here is the back, bottom, front and two 2.5" supports to hold the front to the back, for extra air space (have to have 2 cu ft of inside volume, which means a total of 2.42 total outside volume, taking into consideration wood thickness, sub displacement, port displacement)
I'll be adding more pics later today, hopefully i'll get the sides done, and the port nearly completed, or better yet, hopefully all but the final fiberglassing done!
Old 01-01-2007, 01:04 PM   #11
Daishi00
Member#: 78952
2005 WRX
CGM
looking good. Can't wait to see the finished product.
Old 01-01-2007, 02:00 PM   #12
clbd39
Member#: 104078
2013 WRX
Thanks Daishi
Got it pieced together finally, got the inside siliconed well and now I just need the sides and the part for my pass through which I'm going to be fiberglassing, so while the silicone is drying I'm going to get lunch
then I am going to bust out the Plunge Router and get my port hole ready and cut out my sub and amp pieces so they can be raised up
Port Info Compliments of WinISD
Old 01-01-2007, 05:46 PM   #13
clbd39
Member#: 104078
2013 WRX
whew, it's been a long day lol
So I cut the circle out for my flare to go into (still need to get the adapter for the flare to the PVC) and I got the circle for my sub to go through, routers are the best thing to have!
so here are some updated pics
Checking again to make sure it fits!
And it does, phew
Drew my guides to make sure I'm going to be cutting on the right place
Holes are cut with my flared port inserted and it fits well, and my mount and trim ring sitting next to the sub hole
Old 01-01-2007, 06:07 PM   #14
Fail Wagon
Member#: 133584
looks good
o cant wait to see the finished product
Fail Wagon is offline   Reply With Quote
Old 01-01-2007, 07:36 PM   #15
clbd39
Member#: 104078
2013 WRX
Thank you, Well I stretched the cloth over the front and got some resin slopped on it so this will be all for tonight, hopefully I can finish the other 2 boxes I'm working on (for someone else) tomorrow and finish glassing mine at the same time!
then it'll be paint time for me!
Old 01-01-2007, 07:51 PM   #16
Fail Wagon
Member#: 133584
damn your in missouri too far away to help me with my box
Old 01-01-2007, 07:53 PM   #17
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
nice design I bet it will hit nicely
djerickd is offline   Reply With Quote
Old 01-02-2007, 06:58 AM   #18
stlb5
Member#: 107700
2007 STI
CGM
not bad rookie. You might want to try and use a drill that's younger than you are. I'm really interested in how the pass thru comes out. I may be doing something very similar to this with mine. Once you've got it trimmed down, get that thing back in the car a get a pic!
stlb5 is offline   Reply With Quote
Old 01-02-2007, 10:15 AM   #19
clbd39
Member#: 104078
2013 WRX
LOL /\ /\ my older brother
yea the drill I'm using is my father's... that he won at bingo probably over 20 years ago, but it still works perfectly lol
I'm going to be trimming the corner around the pass through part so it's not a 90 degree angle so hopefully it will look smooth and come out nice
Old 01-02-2007, 11:58 PM   #20
clbd39
Member#: 104078
2013 WRX
got a lot of glassing done today so hopefully i'll have my sub and amp in tomorrow
Old 01-03-2007, 02:16 AM   #21
lowranger
Member#: 124370
03 wrx stg 2.34159
Pro tuned by Cobb Tooning
by the looks of it.. its a good design. but looks like the sub isnt going to have much control due to the jsut reg. port hole. like its jsut a box with a hole. its always good to have port length.
lowranger is offline   Reply With Quote
Old 01-03-2007, 02:32 AM   #22
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
What you see on the box is just the flare that a PVC port will attach to. If you look at the WinISD plot he posted above you can see that the port will be 10.62" long.
khail19 is online now   Reply With Quote
Old 01-03-2007, 02:41 AM   #23
lowranger
Member#: 124370
03 wrx stg 2.34159
doh i didnt get to that part in detail.. well in that case. .
ive never really liked the sound of round ported boxes, way more port noise
Old 01-03-2007, 05:06 AM   #24
couchflambeau
Member#: 102145
'04 STi/Cobb St. II
18L Java Black Pearl
a. it's a four inch port.... large diameter ports generally have little noise associated with them.
b. it's in the trunk, if it was venting into the vehicle directly might be an issue.
I doubt port noise will be an issue.
couchflambeau is offline   Reply With Quote
Old 01-03-2007, 05:01 PM   #25
clbd39
Member#: 104078
2013 WRX
lol wow a little debate
In the WinISD if the number is RED then the program says there will be port noise, I was trying out various rectangular ports and decided to try the circular one, and got a length and diameter that fit well
The number for "vent mach." is 0.16 and it is green meaning (according to the program) there will be no port noise, the flare is also going to help with reducing port noise
lol thanks for clarifying that, if someone jsut looks at the pics they think i'm just doing a hole lol, i'm not that dumb lol I have the pvc with the attachment for it to fit the flare and the exit to the pvc
should be done tomorrow!
I'm just going to paint the whole thing flat black because I'm gonig back to school this weekend and won't have time to make it look BA so that will be spring break project or a summer project to get it looking better, but the sub and amp will be the main focus so it shouldn't look horrible lol
I'm currently making two side pocket boxes for someone else so those are my first priority now and then while they are drying I go and work on mine
thanks for the comments
My head porting project VTsuby Built Motor Discussion 8 05-10-2007 06:58 PM
Project: Started my new ported box :) clbd39 Car Audio, Video & Security 49 07-22-2006 11:21 AM
Ideas on my head porting project... posted in 2.0 too... bonzai Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 12-22-2005 03:34 PM
my wagon sub box project dayphotog Car Audio, Video & Security 26 09-28-2004 07:01 PM
check out my newly started project davewrx Member's Car Gallery 8 02-25-2002 05:54 PM
