Welcome to the North American Subaru Impreza Owners Club Thursday July 2, 2015
Old 12-24-2006, 03:15 PM   #1
-AliasMunky3-
Member#: 57407
1983 02WRX & 14BRZ
WRB & DGM
Default First time changing spark plugs, done in 45 minutes
Hey all,
After reading all the gripes about how much of a PITA spark plugs are on the WRX, I decided to see what all the proverbial 'hub-bub' was all about. And since I was at 64k, even more reason. This is also posted under my name 'Alberto411' on TampaRacing.com in the Subaru section.
With the battery, washer fluid reservoir and airbox removed, it was clear that there wasn't a lot of space to work with. So, with the coils packs removed, a little bit of creative thinking was used to access the plugs. A mechanic/pit chief buddy with little-to-no Suby experience got to thinking and came up with this idea:
Tools used for the plugs themselves:
-5/8" spark plug socket, preferrably with the rubber seat
-3" extension
-3/8" ratchet
-torque wrench
1.) Once coil packs are removed, attach 3" extension to 5/8" spark plug socket.
2.) Seat extension/socket onto plug.
3.) With extension/socket/plug connected, attach ratchet to the extension.
4.) Begin loosening spark plug. Once space no longer allows ratchet/extension/socket/plug, disconnect ratchet.
5.) Hand loosen extension/socket/plug and remove from spark plug well.
6.) Reverse steps for new plugs.
7.) Torque to spec
Replace coil packs. I disconnected them from the wires, but my buddy didn't. Since he's a car guru, he was done way before me on the passenger side as I had the driver's side to work on.
Cliff's Notes...
With two people with novice knowledge to the mechanical workings of Subarus, but one of those monkeys having more extensive automotive knowledge in general, we had the spark plugs changed in ~45 minutes. Conceivably, someone with experience with this 'method' could have their plugs changed in about 30-45 minutes by themselves.
I hope this helps save many-a-knuckle, having to use socket swivels, having to use rubber tubing to pull out the plugs, having to jack up the motor and ultimately having to pay $200+ at the dealership.
-Al
P.S. sorry if this is already common knowledge. And for whoever cares, I went to the NGK Iridiums BKR6EIX / stock heat range on a Cobb v1 Stage 2 setup.
-AliasMunky3- is offline   Reply With Quote
Old 12-24-2006, 06:25 PM   #2
Dutch Scooby lover
Member#: 32452
1998 Impreza Turbo
74F FTW
You can also use a long socket , and a loose 1/2 inch ratchet
(Dont know how to call it, but my dad has a socketset that changes direction not by turning a handle or such, but you can push the entire square thing that holds the socket itself tru, as to reverse direction)
Remove that piece, insert it into the socket, so u have a socket with a 1/2 inch square sticking out, and then use a ratcheting spanner to turn it.
This works best on the nr4 cilinder, as there isnt much room there, nor can u remove something to make room.
Dutch Scooby lover is offline   Reply With Quote
Old 04-14-2008, 09:07 PM   #3
DDScooby
Member#: 161876
02 Impreza WRX
This was by far the best DIY thread. IMHO anyway. It took me a lil longer than the OP but this was the best help for someone that had never backed out a set of plugs on a H4 engine. Thank you.
DDScooby is offline   Reply With Quote
Old 04-14-2008, 09:33 PM   #4
SC2000
Member#: 162421
what's the proper torque (lbs/ft) for the spark plugs anyway? are the motors interferance motors or non-interference motors?
SC2000 is offline   Reply With Quote
Old 04-14-2008, 09:44 PM   #5
wrxnoel18
Member#: 156582
05 WRX STI
WRBLUE!
i've done 30 minutes! its wasn't bad..i hate lifting and working under the car...but this its ok..!
wrxnoel18 is offline   Reply With Quote
Old 11-05-2009, 03:09 PM   #6
R7MR7M
Member#: 86570
2007 STi
Urban Gray
Cool This is a great write-up
I followed this the first time at around 60K. Now I have almost 120K and plan on following it again
This is a knuckle masher though... The frame rails are so close to the block that the plugs are almost impossible to get out and back in again.
R7MR7M is offline   Reply With Quote
Old 11-05-2009, 03:22 PM   #7
R7MR7M
Member#: 86570
2007 STi
Urban Gray
Thumbs up Torque specs for 2.0L Turbo
According to the 2002 WRX Service Manual:
For the 2.0 DOHC Turbo-
Tightening torque: N-m (kgf-m, ft-lb)
Plug: 21 (2.1, 15)
Ignition Coil: 16 (1.6, 11.7)
Old 11-05-2009, 06:56 PM   #8
bubba8000
Member#: 185051
01 RS
Plug: 21 (2.1, 15)
Just changed the plugs for the first time on our newly aquired '95 2.2L sedan. (among other issues)The plugs were torqued in at least 70 lbs. I don't know how I didn't pull some thread out with the plugs, darn lucky. I hope the previous owner wins the lottery in his next life -- then blows it on a Yugo dealership.
Anti sieze lubricant. It comes in a tube for those who havn't tried it. I always coat my spark plug threads with it. It really aids in removal, especially in tight spots. Cheap insurance.
bubba8000 is offline   Reply With Quote
Old 11-05-2009, 07:33 PM   #9
R7MR7M
Member#: 86570
2007 STi
Urban Gray
Holy geez!
Old 11-11-2009, 03:46 PM   #10
kenliu84
Member#: 107618
2006 OBP WRX Wagon
PrecisionTuned/TiCSuspen.
I'm new at working on my own car. What are coil packs?
kenliu84 is online now   Reply With Quote
Old 11-11-2009, 04:14 PM   #11
R7MR7M
Member#: 86570
2007 STi
Urban Gray
Default Re: Coil packs
A coil pack provides the energy necessary to produce a strong enough spark to jump the gap of the plug. In the wrx, maybe not all but on mine, there is one coil pack for each plug (totaling 4) and they are located directly on top of the the plug. It basically replaces a distributor type ignition system.
So basically to take out the plug you have to unscrew the bolt for the coil pack and remove it. You will see that there is a socket-type connector on the coil pack where the plug sits.
Links for more info -
Here is a spark plug change tutorial that shows a picture of the coil packs:
http://www.clubwrx.net/forums/mainte...parkplugs.html
Here is more info on a coil pack:
http://www.blurtit.com/q432989.html
Old 11-14-2009, 07:50 PM   #12
Richbmxer87
Member#: 183707
2005 WRX
BLK
Yea i just did mine today, took about the same time first time aswell by myself. everyone was sayin use the specialty tools and blah blah i didnt use them and it wasnt to bad at all. yes specialty tools would have made it faster but is easy enough with regular tools.
Richbmxer87 is offline   Reply With Quote
Old 11-16-2009, 04:32 PM   #13
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
Did my old WRX at 78,000. I had everything except my 3" extension. That added probably an hour to the job. Son had taken it and put it in "his" tools. Plugs were so tight that I was afraid I was going to twist the threads out of the heads. Mine also had rust on the threads. I think the plugs could have easily gone another 50,000. Looked great. RP
drivin blind is offline   Reply With Quote
Old 11-18-2009, 06:40 PM   #14
protospheric
Member#: 197788
2002 WRX sedan
wrb
Originally Posted by -AliasMunky3- View Post
Hey all,
Good write up, but why'd you change the coil packs? Were yours bad?
./p
protospheric is offline   Reply With Quote
Old 11-19-2009, 10:52 AM   #15
RideHolden
Member#: 207584
2007 STI ltd
UGM
i'm going to be doing this soon but don't know what the gap is on the impreza spark plugs. anyone know where i can find this information?
RideHolden is offline   Reply With Quote
Old 11-19-2009, 12:37 PM   #16
JimBlake
Member#: 82247
2005 Saab 9.2x Aero
satin grey
./p
Maybe he just meant RE-INSTALL them...?
JimBlake is offline   Reply With Quote
Old 11-19-2009, 03:38 PM   #17
bzbuzz
Member#: 116052
2011 STI ( Sold )
stick with stock ngk plugs. you dont need to gap. I would not gap at all.
bzbuzz is offline   Reply With Quote
Old 11-19-2009, 03:40 PM   #18
bzbuzz
Member#: 116052
2011 STI ( Sold )
little advice to you all:
MAKE SURE YOU GET CORRECT SPARK PLUGS. LOOK AT YOUR MANUAL. A LOT OF VENDOR HERE HAVE WRONG INFO.
Old 01-14-2010, 11:50 PM   #19
GreasyJoe
Member#: 112037
2002 WRX Wagon
Red
In the tight confines I had to work in, I was having trouble getting the rear passenger side coil back onto the plug. I disconnected it from the little primary current wire so I could turn it upside down, then it was a straight shot onto the plug. I turned it right side up, plugged the little wire back in, and bolted it down. It was really easy to do, once I went thru fifteen minutes of frustration and finally thought of it.
One of those magnetic wand things for retrieving stuff you drop came in really handy. I used it repeatedly.
A 5/8 inch socket fits on the plugs, not the standard 13/16. I think a 14mm or a 16mm (can't remember which) will also fit. It took some aggravation before I figured that out.
I went to four auto parts stores, none had the original plugs in stock. I ordered them from Kragen, for just under $10 each. I got them the next day. Plan to have to order them.
It's not a hard job, but it's a fussy job.
GreasyJoe is offline   Reply With Quote
Old 01-28-2010, 11:29 PM   #20
mjslive2fly
Member#: 236064
2009 WRX
Great DIY Thread. I just finished for the first time in about 45 min on my '02 WRX. No need for any swivels as others have stated. Use a 3/8 ratchet with a low profile head, 3" Ext and a 5/8 plug socket and you're good.
solid CEL now replaced w/intermittent flashing CEL... Off to Autozone tom to read the codes...
mjslive2fly is offline   Reply With Quote
How to change spark plugs in an 05 Legacy 2.5 Gondi Service & Maintenance 3 12-11-2007 06:48 PM
Anyone change spark plugs in an STi? jmanSTI Texas Impreza Club Forum -- TXIC 14 12-02-2007 11:47 PM
Changing Spark Plugs in a WRX 2.0T wrxnova1 Newbies & FAQs 5 08-23-2006 04:03 PM
When to change spark plugs in WRX? scoobyrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-28-2002 07:49 AM
When did everyone first change spark plugs? SubieRacer Technical Forum Archive 19 05-27-2000 07:38 PM
