South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 12-24-2006, 04:56 PM   #1
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
Default flagstaff people - may need help quick
well apparently my bad luck is still following me. seems my turbo took a crap this afternoon in flagstaff and I need to be back to work in chadler on tuesday. the car won't boost past 5psi and has black crap coming out of the exhaust. I had to fill up with crappy gas on the way here because there were no shell stations so could I have gotten bad gas? no cels. any help would be greatly appreciated. thanks guys!
v8eaterWRX is offline   Reply With Quote
Old 12-24-2006, 04:59 PM   #2
schooby
Member#: 89387
2005 RS
i don't know anything on turboed cars or i would help you out.
schooby is offline   Reply With Quote
Old 12-24-2006, 05:41 PM   #3
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
well I just got back to my hotel and checked my oil. no metal shavings and at a good level. had my girlfriend start the car with my hand at the exhaust and no more black junk. reset the ecu and changed my realtime map to stage II 91 octane but stll only boosts to 5psi. added some octane booster too, but I'm sure that isn't gonna help any. car feels a little sluggish but I don't know that its because of this or if its just the different altitude. it had a really rough idle this morning when I started it, but I think that was due to the heavy oil. any ideas? I can't decide whether its safe to drive home or if I should have my buddy bring the car hualer up.
Old 12-24-2006, 05:52 PM   #4
pudnana
Member#: 89071
2000 Blue 2.5 RS
2004 Java WRX
i run cobb stage 2 on my 04 wrx and i just use the gas from the fry's grocery store. No trouble at all. Most if not all gas in arizona comes from the same refineries, so it really doesn't matter where you buy it from. i think if you have a problem boosting, you either have a turbo problem or a vaccuum line off somewhere.
pudnana is offline   Reply With Quote
Old 12-24-2006, 05:54 PM   #5
dozer54321
Member#: 116437
i personally would use a car hauler, at least you know you cant hurt anything else by putting it on a hauler
dozer54321 is offline   Reply With Quote
Old 12-24-2006, 10:14 PM   #6
pimpininaz
Member#: 88362
2007 WRX Limited
SATIN WHITE PEARL
what up hommie? the sluggishness is from the altitude one of the drawbacks to flagstaff, do you have an egt gauge? if you have black crap coming out then there is obviously a oil or fuel issue. pm me if you need a mechanic at a cheap price. id help but am off my feet with a broken ankle
pimpininaz is offline   Reply With Quote
Old 12-24-2006, 10:58 PM   #7
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
well I checked my boost with the ap and it has been 13-14 psi, so I guess my mechanical gauge is just off? the black crap I have determined to be my cat cleaning itself out from my injector cleaner I ran cause its not doing it now. I'm still a couple psi low, but not as drastic as I thought. seems like I'm good, guess ill know when I get back to the valley. thanks for the help guys!
Need help quick on springs g7run Brakes, Steering & Suspension 0 06-03-2010 03:57 PM
may need help with aem wideband a/f gauge install 005sti Mid Atlantic Impreza Club -- MAIC 3 05-10-2005 06:07 PM
amplified road noise, may need help auricom Mid Atlantic Impreza Club -- MAIC 11 03-06-2003 09:36 AM
need help quick trojan9x Normally Aspirated Powertrain 4 05-21-2001 10:39 PM
('93-'01) Need HELP quick please... kaos200 Impreza Forum 2 04-21-2001 09:22 AM
