Old 12-24-2006, 09:19 PM   #1
wrx88
Member#: 112611
2006 WRX TR
Default Can someone help me analyze my log
I just data logged my car in 2nd gear. I'm running Oseuco stage 2 for my 06 mt wrx. I'm not sure what exactly i should be looking for. I know I over shot boost by .427 psi and it didnt seem to be searching, but other than that, i have no clue. I logged engine speed, relative pressure, wdc, knock correction, and ignition timing.
If someone can take a look, please pm me and I'll send you the log. Thanks a lot in advance.
wrx88 is offline   Reply With Quote
Old 12-25-2006, 03:13 PM   #2
wrx88
Member#: 112611
2006 WRX TR
I am overboosting (hitting the boost limit of 18.4psi) in 2nd gear. Would it be ok if i lower max wastegate duty cycles by 5% all around to see if that puts me below target boost to use as a starting point?
Old 12-25-2006, 06:54 PM   #3
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
18.427 means you maxed out the sensor. There's no telling how much boost you hit.
06rexwagon is offline   Reply With Quote
Old 12-25-2006, 09:32 PM   #4
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
If you send over your log and map via PM, I'll take a look.
blkscooby is offline   Reply With Quote
Old 12-25-2006, 11:14 PM   #5
wrx88
Member#: 112611
2006 WRX TR
A member on here took a look at my map and told me what adjustments to make to the wgdc in order to hit 18psi. I haven't logged with those changes yet, but I was told that my car is running strong and safe with no signs of knock. Thank you anyway. openecu is a great thing!
HELP DFW: Can someone help me install my Recaro seat RIGHT NOW ASAP!!?!?!? fatcircles TXIC Private Classifieds 3 01-13-2008 08:42 PM
Post subject: blinking CEL under WOT, can someone help me with my log pls! kschmohl Engine Management & Tuning 5 10-07-2003 07:15 PM
Can someone help me fix my friend's mirage tranny????? Hassassin Tri-State Area Forum 4 12-16-2002 08:26 PM
Can someone help me change my spark plugs ? bigbird Mid Atlantic Impreza Club -- MAIC 3 10-04-2001 03:46 PM
