Old 12-24-2006, 09:57 PM   #1
purplepickle
Member#: 77032
Default what size T and vacuum line for tubo gauge
Hi. I bought a used OEM turbo gauge, but it didn't come with the T connector or vacuum line. What size T connector should I buy and where can I get it? Also, what diameter vacuum line should I get to connect the T connector to the gauge?
purplepickle is offline   Reply With Quote
Old 12-24-2006, 11:12 PM   #2
sixtsix
Member#: 114261
2016 sti limited
white
If I remember correctly the vacuum line is 1/4".
sixtsix is offline   Reply With Quote
Old 12-24-2006, 11:13 PM   #3
sixtsix
Member#: 114261
2016 sti limited
white
would have to look at it again for the T fitting. I believe the line you splice into was 1/4 also. not positive on that though.
Old 12-24-2006, 11:52 PM   #4
Psybin
Member#: 112719
2014 Evolution X GSR
06 STI & 05 9-2X = Sold
If you are near a dealership you can get an install kit for about $6. I used to have the part number but deleted the PM by mistake.
You've been on the boards two years and havent filled out your profile?
http://forums.nasioc.com/forums/prof...do=editprofile
Psybin is offline   Reply With Quote
Old 12-24-2006, 11:54 PM   #5
bluestonepath
Member#: 123641
'04 WRX Wagon
Platinum Dirty Metallic
yeah and you can get a "hardware kit" (i think its the same thing), from subarugenuineparts.com for about 5 bucks, but with shipping I'm pretty sure it's more. up to you. here's the part number anyway H5010FE037
bluestonepath is offline   Reply With Quote
Old 12-25-2006, 04:17 AM   #6
uathatis
Member#: 117300
i think the right size for the T for standard hose is 3/16's....
o .. damn i wish i knew about that install kit lo.. well all i needed was the T luckiyl
uathatis is offline   Reply With Quote
Old 12-25-2006, 10:39 PM   #7
kihbolo
Member#: 131297
2003 Evo 8
Black on Black
i just went to napa and spent about 2 bucks for a t fitting, hose, and clamps. i don't know the sizes though. they allowed me to take them out and try them on the car itself.
kihbolo is offline   Reply With Quote
Where do I mount vacuum line for boost gauge? Kahn23 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 07-24-2008 08:24 PM
Vacuum line for boost gauge? dougkmcse Interior & Exterior Modification 0 03-16-2008 12:19 AM
Size of factory vacuum lines and restrictor? Force[FED] Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 03-01-2003 02:49 PM
What is the vacuum line for on a W/G milkman Normally Aspirated with bolt-on Forced Induction Powertrain 6 08-23-2002 03:24 PM
Important: what size feed and return line is everyone running ? zaidallas Normally Aspirated with bolt-on Forced Induction Powertrain 5 06-16-2002 10:15 PM
