Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 12-24-2006, 11:05 PM   #1
Member#: 123103
2003 WRX
Full 07 STI trans
Default Manifold remover and TGV deletes
two questions. I have read up on intake manifold removal and the tumbler deletes and i have searched...
1.) when i remove the intake manifold is it necessary to drain the coolant or can i just plug lines and slide the overflow out of the way?
2.) For the tgv deletes I was going to do one of two things. Either just remove the butterfly plates and leave the rods, OR remove everything and tap the holes so i can plug them. I know that removing the rods will cause a cel, but if i leave the rods will it cause a cel that cant be tuned out on a utec? I have also seen something about that you need to port them when you do the tgv deletes so they match up correctly. Do i need to do this?
rexspeedmaster is offline   Reply With Quote
Old 12-25-2006, 09:09 AM   #2
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Go to scoobymods.com for the complete write-up.
1. Plug them.
2. UTEC may or may not remove the CEL, check with TurboXS FIRST. You don't NEED to port them to match the block inlet, but since you are in there anyways, it seems like a no brainer. Use the old gasket as a pattern, overlay it, scribe, and port to the scribe mark. Use spray paint if you don't have a scribe.
FS:JDM V7 int manifold, JDM V7 TGV deletes, UR 1600cc inj, Perrin fuel rails,more jigga Engine/Power/Exhaust 26 02-14-2010 05:59 PM
FP Red and TGV delete question MaxPSI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 10-22-2006 04:07 PM
FS: APS Turbo inlet AND TGV deletes AZRally SWIC Private Classifieds 8 08-12-2006 06:21 AM
Hp from APS Inlet and TGV deletes quickscooby Proven Power Bragging 6 04-10-2006 03:43 PM
JDM v.7 sti intake manifold risers. oem TGV Deletes 100 shipped psyber_0ptix Private 'For Sale' Classifieds 2 09-18-2005 11:07 AM
