Old 12-25-2006, 03:04 PM   #1
RWS_BajaTurbo
Member#: 51520
2004 Baja Turbo
Regatta Red
Default Changed my oil, now car won't move, help!
I have an '04 Baja Turbo. Got tired of paying for high priced oil changes, so I decided to change the oil myself.....maybe this was my first mistake.
Anyway, I drove the Baja up on ramps (just in the front) and drained the old oil and changed the oil filter. While the Baja was still up on the ramp, I put the new oil in. Here's the really dumb part....I didn't read the manual and instead assumed that it took 5 quarts of oil. After I finished putting in the oil, I started up the Baja to back down off the ramps. When I put it into reverse, nothing happened. I reved the engine and slowly the transmission kicked in. After coming down off the ramps, I put it into drive and the car barely moved. When I checked the oil level, it was way to high....I know...DUH!
Here's the really weird part....with the Baja on level ground, I shimmied underneath to drain the excess oil When I pulled the plug, NO OIL DRAINED OUT.
What's going on....I put 5 quarts in, and no oil comes out?
What should I try next? Is it time to call a wrecker?
RWS_BajaTurbo is offline   Reply With Quote
Old 12-25-2006, 03:15 PM   #2
PltsilvREX
Member#: 66406
did you pour the oil in the right hole???
PltsilvREX is offline   Reply With Quote
Old 12-25-2006, 03:17 PM   #3
imaaaron
Member#: 74047
Did you drain the right hole?? Check your dipstick, make sure you didn't just fill up oil that you never drained.
imaaaron is offline   Reply With Quote
Old 12-25-2006, 03:18 PM   #4
imaaaron
Member#: 74047
What color was the stuff that came out? Brown? Red?
Old 12-25-2006, 03:18 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You may have drained the transmission by mistake instead of the engine. Are you sure what came out was oil and not transmission fluid?
Old 12-25-2006, 03:36 PM   #6
Gfunk720
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
Sounds like you drained the trans fluid, especially if your car is reluctant to go into gear...
Gear Oil smells a lot worse than enginel oil so that is an easy way to tell the difference. But I would bet thats probably what you did
Gfunk720 is offline   Reply With Quote
Old 12-25-2006, 03:42 PM   #7
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
The OP says he "put it in drive" which means it's an automatic. If so, and he drained the transmission, the car will run (though it's WAY overfilled with oil) and yet not move when put into drive. And he even MAY be lucky and cause no real lasting harm once he drains the engine oil, and refills both the transmission and the engine properly.
Alan is offline   Reply With Quote
Old 12-25-2006, 04:27 PM   #8
RWS_BajaTurbo
Member#: 51520
2004 Baja Turbo
Regatta Red
Thanks everyone for responding so quickly....especially on Xmas.
Here's where I drained it...
Here's where I filled it...
I checked my tranny fluid (w/ engine idling). No fluid appears on the stick which might explain why the Baja won't budge. Where do I put more transmission fluid in? The manual doesn't say...
Old 12-25-2006, 04:35 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yep that's the transmission drain (and filter too). I'm not that familiar with the Baja but I'm guessing there is a cover plate under the engine which may hide the oil drain plug and filter and explain why you didn't see them. If so take that cover off and it should be obvious what you did.
Once you find the engine drain plug you need to drain all the oil out, have a good sized pan under there because there will be about 10 quarts of oil assuming the engine was full and you added 5 qts on top of that.
If you still have the original filter you took off the transmission get another one or put that one back on. It may not be the same as the engine filter even though it fits.
Get the necessary quantity of the correct transmission fluid (check your manual for the fluid type) and fill the trans through the dipstick hole. You may need to get a transmission funnel.
You probably didn't do any lasting damage as long as the engine was only run overfilled for a short time and the trans didn't have time to overheat. You'll find out when you drive it.
Old 12-25-2006, 04:37 PM   #10
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Looks like you drained the transmission, then added oil to the crankcase - oil went in the right place, but you took oil out of the wrong place. You need to drain the engine oil (it's waaaaay overfilled which will cause the oil to foam, etc.) - the tranmission is very low on fluid, which is why it isn't working properly... as for damage, the engine is fine, and as long as you didn't drive around, the transmission is probably ok as well. You really don't want to drive it until you fix this. (the oil pan is further forward - under the engine, rather than the transmission )
Old 12-25-2006, 04:48 PM   #11
RWS_BajaTurbo
Member#: 51520
2004 Baja Turbo
Regatta Red
Awe...crap! I'm an idiot!
You'd think Subaru would label the drain...making it "idiot" proof.
Well at least now I know what I need to do.
You guys saved me a wrecker trip.
Have a Merry Xmas
Old 12-25-2006, 05:39 PM   #12
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Yea, go buy 5 or 6 quarts of trans fluid, fill it through the transmision dipstick that should be straight back from the oil dipstick you pictured, almost at the firewall, you will need a long funel. Drive it back onto ramps and drain some oil or all the oil from engine and top off.
wrxdrvr is offline   Reply With Quote
Old 12-25-2006, 06:12 PM   #13
AlboWRX
Member#: 37719
2003 WRX
If the car came with a manual, READ IT. It`s there to inform people like you where everything is located or else if you try to do anything else in the car you`ll do something else instead. I know that as soon as I got my rex I started reading the manual page by page the maintenance section. Or if you need a hand, just post this in the Midwest Section and someone, including me will come out to give a hand to a fellow subie owner. Again, if you`re not sure, do reaserching before you start wrenching.
AlboWRX is offline   Reply With Quote
Old 12-25-2006, 06:43 PM   #14
imaaaron
Member#: 74047
Sorry to hear that, but on the bright side, you'll never make a mistake like this again .
Keep us posted. I highly doubt that you did any damage, unfortunately, that's a lot of fluid to dispose of now
Old 12-25-2006, 06:55 PM   #15
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Good luck, let us know how you make out.
FWIW, you are now fully qualified to work at Jiffy Lube.
Old 12-25-2006, 07:02 PM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...do NOT run the vehicle until you have the correct fluids and fluid levels in the appropriate places
Old 12-25-2006, 07:08 PM   #17
jawwadh
Member#: 100594
2008 BMW M3
wow, thank God u didnt break anything!
jawwadh is offline   Reply With Quote
Old 12-25-2006, 07:56 PM   #18
Feign
Member#: 68604
06 STi
Research twice, implement once!
Good luck on getting yourself lined out...
Feign is offline   Reply With Quote
Old 12-25-2006, 08:00 PM   #19
kickitjp
Member#: 60035
Chapter/Region: PRSIC
No shiz. (I was actually scared he put oil into the coolant)
kickitjp is offline   Reply With Quote
Old 12-25-2006, 08:27 PM   #20
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
A girl a work did that and only made it 2 blocks before the car was engulfed in oil smoke. It was hilarious because he boyfriend did it.
silver arrow is offline   Reply With Quote
Old 12-25-2006, 10:14 PM   #21
ivwarrior
Member#: 100610
MBP
Look on the bright side, now's a good time to switch to synthetic ATF
ivwarrior is offline   Reply With Quote
Old 12-25-2006, 10:56 PM   #22
OvrClkdPmp
Member#: 64467
2013 Forester XT
Sage GReen
yea d00d you just topped your motor off with 5 guarts buddy.
tehe i did the smae thing when i 1st got the car... LOL
OvrClkdPmp is offline   Reply With Quote
Old 12-25-2006, 10:57 PM   #23
OvrClkdPmp
Member#: 64467
2013 Forester XT
Sage GReen
Have a Merry Xmas
they kinda did, the filter says trans on it... its ok
Old 12-25-2006, 11:47 PM   #24
strohausii
Member#: 26770
'02 WRX
midnight black
...make sure you changed the correct filter too...
strohausii is offline   Reply With Quote
Old 12-26-2006, 01:40 AM   #25
Matt92530
Member#: 94085
2009 BMW 335i
Cloud Gray
Hey, you should clean up that battery too.
Matt92530 is offline   Reply With Quote
Changed spark plugs..now car won't run KyoSaNim Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 06-18-2010 01:31 PM
changed my oil - now getting smell drifter dave Service & Maintenance 5 10-11-2005 12:06 AM
Rat chewed on a wire, now car won't start ! Help ! 99LegacyGT Legacy Forum 3 07-14-2003 04:16 PM
I unplugged my unichip now car won't start! potouli Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-23-2002 01:17 PM
Should I change my oil now or later? Penphoe Normally Aspirated Powertrain 6 09-03-2001 01:07 PM
