Old 12-25-2006, 04:42 PM   #1
caffee
Member#: 135803
1997 Impreza
Default Help! Differences between 04 & 05 STi ECU
Hi, there. I am working on a swap; but the 05 sti ecu doesn't work with the key anymore because it has been sitting for a while. If I use a 04 sti ecu and reflash it, would there be any difference between the 04 sti ecu and the 05 ecu except the immobilizer? Any performance differences? Thanks.
caffee is offline   Reply With Quote
Old 12-27-2006, 03:21 PM   #2
Freon
Member#: 88322
2009 BMW 135i
There is not much difference (or any difference in most tables) in the actual fuel, timing, AVCS, etc. tables. Yes, the 2005 uses a slightly newer CPU with more memory, though it may not make much difference in performance if any. Probably none, especially after tuning.
It is certainly possible on paper to make a 2004 ECU drive a 2005 car. It's not like the 2005 has a different engine. AFAIK there is no significant difference in the physical configuration. It's probably more trouble than it is worth to work around the wiring and immobilizer issues you are likely to encounter. Just buy a new 2005 ECU if you need one.
The dealer should be able to re-initilize or whatever the immobilizer. Why don't you just do that?
Freon is offline   Reply With Quote
Difference between 04 & 05 WRX motors?? kandys2k Subaru Conversions 4 11-21-2009 05:39 PM
difference between 04 & 05 Sti rotors wuuusaa Brakes, Steering & Suspension 2 09-14-2007 01:25 AM
Help! Differences between 04 & 05 STi ECU caffee Subaru Conversions 1 12-25-2006 08:07 PM
Difference Between 04 & 05 STi Clutches? spoolinsuby Transmission (AT/MT) & Driveline 1 05-10-2005 04:52 PM
Difference between 04 and 05 STI steering wheel? Mopho Interior & Exterior Modification 8 03-28-2005 08:53 PM
