Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 12-25-2006, 10:37 PM   #1
wrx2k4blue
Member#: 59048
2005 Black S60R
w/ 18" Modas & Sport Body
Default Best place to jack up the car?
I know of the spots behind the front wheels and in front of the rear wheels that only jack up that corner of the car. However, I'd like to find a spot that jacks up the entire front end or the entire rear end.
Anyone have any pics of where I can do this?
wrx2k4blue is offline   Reply With Quote
Old 12-25-2006, 10:42 PM   #2
kihbolo
Member#: 131297
2003 Evo 8
Black on Black
what kind of car?
kihbolo is offline   Reply With Quote
Old 12-25-2006, 10:42 PM   #3
ddunk12
Member#: 116596
2012 STI
Ive never jacked up the whole front. I use the rear diff. to do the whole back of the car, its real easy.
ddunk12 is offline   Reply With Quote
Old 12-25-2006, 10:43 PM   #4
kihbolo
Member#: 131297
2003 Evo 8
Black on Black
you might have to use two jacks for the front
Old 12-25-2006, 11:04 PM   #5
wrx2k4blue
Member#: 59048
2005 Black S60R
I have an '04 WRX sedan. I guess I've heard on other cars, like the TSX, there are spots right under the engine where you can jack it up which lifts the entire front end off the ground.
Tough luck for me I guess...
Old 12-26-2006, 10:05 AM   #6
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
www.scoobymods.com has the answer, search there.
Old 12-26-2006, 11:41 AM   #7
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
There's a front jackplate under the engine and the rear differential is good for, well, the rear.
[i still prefer using the frame behind the front wheels for the front though]
Old 12-26-2006, 11:46 AM   #8
wrx2k4blue
Member#: 59048
2005 Black S60R
Shot in the dark, but anyone have a good pic of the front jack plate? Peaty's tutorial has a good shot but I guess I can't tell exactly where it is (plus his shot was off his Forester). I guess if I get under the car it'll become more obvious.
The rear diff shouldn't be a problem to find
Thanks!
Old 12-26-2006, 01:11 PM   #9
hondaeater69
Member#: 60324
the front jack plate is where the rear of the splash guard bolts into.
Old 12-26-2006, 01:13 PM   #10
wrx2k4blue
Member#: 59048
2005 Black S60R
I thought there was something right in the middle under the engine that can lift up the entire front end? I think some have also referred to it as the front crossmember??? I dunno...
Old 12-26-2006, 01:18 PM   #11
hondaeater69
Member#: 60324
the front jack place IS in the middle under the engine and you can lift up the entire front end of the car with it... what else are you looking for?
Old 12-26-2006, 01:50 PM   #12
Hagbeard
Member#: 40286
'04 WRX Sedan
Platinum Silver
Look under your car. Look at the aft-most place the plastic skid plate connects, there are two bolts there. Directly aft of that is a metal plate, that's what you're looking for.
Hagbeard is offline   Reply With Quote
Old 12-26-2006, 04:22 PM   #13
wrx2k4blue
Member#: 59048
2005 Black S60R
Ok, I will check it out. Thanks for the info!
Old 12-26-2006, 06:18 PM   #14
Hagbeard
Member#: 40286
'04 WRX Sedan
Platinum Silver
Peaty's thread has pictures and even though the pictures are of a Forester, things look remarkably similar on the Impreza.
http://www.scoobymods.com/forums/showthread.php?t=2673
best place to hook up chains to pull the motor soundguy1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-30-2009 06:33 AM
Shifter install, do I need to jack up the car? SubieSubie Transmission (AT/MT) & Driveline 6 06-20-2008 10:39 PM
Do I need to jack up the car to remove sideskirts? soundwave Bay Area Impreza Club Forum -- BAIC 2 10-04-2003 11:46 PM
Is it ok to jack up the car by the rear differential? Maniac Transmission (AT/MT) & Driveline 8 03-01-2003 07:05 PM
Where to jack up my car with a floor jack? Sordid Philosopher General Community 1 11-17-2002 03:52 PM
