Old 12-26-2006, 12:37 AM   #1
Slowsoul
Member#: 126686
2002 Impreza, WRX
World Rally Blue
Default Strange noise on the driver side.
I have just recently noticed a noise from under my hood, and I have been trying to hunt it down over the past couple of days without much success. Nothing in the forum archives has really helped me so I decided to post about it.
02 Wrx
There is a sputtering hiss in the vicinity of, but below the alternator, close to the block...it is not a solid hiss, more like a sputter...psst psst psst psst psst psst psst...like a pneumatic pump. It increases and decreases with idle. It is very distinct and very pronounced. It is not a ticking injector. It sounds like a leaky hose. At idle, the car hesitates very slightly, almost not enough to notice. If I try to hold the revs at around 2k the hesitation is a bit more aparent, but still very slight. There is no smoke from the exhaust, it smells rich, it is not burning coolant. After running the car for a good hour on the freeway the noise had softend quite a bit, but it was still present.
Does anyone have any ideas?
Will a blown exhaust manifold gasket make noise like this
Slowsoul is offline   Reply With Quote
Old 12-26-2006, 02:03 AM   #2
nkx
Member#: 96951
2004 wrx sedan
'10 Outback 6mt-wifey's
possibly, but you should be able to see it with a flashlight if you get under the car after a cold start.
have you done any maintenance to the car in the last few days?
nkx is offline   Reply With Quote
Old 12-26-2006, 02:10 AM   #3
Slowsoul
Member#: 126686
2002 Impreza, WRX
World Rally Blue
No recent maintenance.
What would I look for...fumes? smoke? soot?
Old 12-26-2006, 06:19 AM   #4
golf97
Member#: 129784
2002 Impreza WRX
do you have a bov installed? it sounds like a small vac leak.
golf97 is offline   Reply With Quote
Old 12-26-2006, 10:22 AM   #5
Slowsoul
Member#: 126686
2002 Impreza, WRX
World Rally Blue
Stock BPV. I should double check all of the BPV lines, they are all secured with zip ties, but since getting the car 3 months ago I have removed the IC several times. It really doesn't sound like it is coming from that area...but sound can be decieving.
Listening to it again this morning, the noise is around the AC compressor, the nosie is louder below the compressor, and it happens when the AC is both off and on.
Old 12-26-2006, 05:58 PM   #6
JonR
Member#: 22753
2002 PSM WRX +PPG
OBXT
What about your uppipe?
During an up pipe install I noticed that one of the studs on the exhaust side of the turbo had been broken by a previous owner. I have never broken a stud, how do you get them out and replace them, is it even necessary to replace it, or will the other 4 hold the seal?
Could be an uppipe exhaust leak. Where is your boost gauge tapped?
JonR is offline   Reply With Quote
Old 12-26-2006, 06:48 PM   #7
Slowsoul
Member#: 126686
2002 Impreza, WRX
World Rally Blue
I have not been able to track down the location of the boost gauge tap...the previous owner installed it. Hadn't thought of that, good idea!
Like I said, no RECENT maintenance, that up pipe install is about a month and a half old. One, I have checked the up pipe and there are no leaks, that is why I didn't mention it. Two, it is definately somewhere close to the AC compressor, which is no where near the up pipe. Three, the missing bolt/broken stud was on the exhaust (downpipe) side of the turbo and has since been replaced.
I am going to try to get video and sound of the noise as well as the location.
Old 12-30-2006, 02:09 PM   #8
Slowsoul
Member#: 126686
2002 Impreza, WRX
World Rally Blue
Okay here is some video...it has not been happening for the past couple of days, but it popped up this morning and I was able to shoot some video.
hope this helps.
Old 12-30-2006, 02:20 PM   #9
STYLIN
Member#: 125187
05 STi
Quicksilva
Not giving advice but that is a weird sound almost like a spark plug leaking lol.
STYLIN is offline   Reply With Quote
Old 12-31-2006, 01:00 PM   #10
Slowsoul
Member#: 126686
2002 Impreza, WRX
World Rally Blue
bump, still clueless.
Strange noise on cold star on 09wrx Davpat9467 Newbies & FAQs 14 12-28-2009 11:48 PM
STI..Clanking noise from the drivers side wheel/brake 516_WRX_V2 Tri-State Area Forum 3 10-08-2003 01:53 PM
Strange noise coming from driver's side morrette sdseagles Interior & Exterior Modification 8 12-31-2002 12:34 AM
Rubbing brakes / noise from front driver side/AC buzzing sound Foz Service & Maintenance 3 01-13-2002 01:09 AM
('93-'01) Help! Strange noise from the back of the car. Marc Sawaya Impreza Forum 15 09-21-2001 04:22 PM
