Old 11-21-2001, 02:11 AM   #1
wrxguy
Member#: 12189
2002 WRX sedan
Unhappy check engine light is on
fifteen hundred miles and my check engine light comes on
where do I start? no weird noises happened when i was driving down the road
anybody?
wrxguy is offline   Reply With Quote
Old 11-21-2001, 08:13 AM   #2
Rocky WRX
Member#: 9837
2002 White WRX Wagon
7800 ft
You need to get someone to pull the code from your ECU with a OBD-II scanner. Your dealer can do this, hopefully under warranty. Some autoparts shops can do it too. You can also buy your own scanner, starting at around $100 for a laptop adapter and software. Not a bad investment if you plan on modding your car in the future.
Rocky WRX is offline   Reply With Quote
Old 11-21-2001, 08:53 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
A scan tool is an invaluable accessory if you own an OBD-II car since it's the only way to read and clear codes.
The other day my CEL came on right after I started the car, also at about 1500 miles. I plugged in my scanner (AutoXray) and pulled the code which was a cylinder 4 misfire. I cleared the code and so far it hasn't come back so it was probably a random event and nothing to worry about.
There are just so many things that can trigger the light, from frequent misfire (bad) to a loose gas cap (insignificant but annoying).
Having the scanner made all the difference between being able to read/clear the code and go on my way, and having to find a shop or dealer to get it checked.
Old 11-21-2001, 09:08 AM   #4
NotoriousWRX
Member#: 9026
Start with the obvious; check your gas cap.
NotoriousWRX is offline   Reply With Quote
Old 11-21-2001, 09:16 AM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yeah if the light comes on shortly after filling up then a loose gas cap is most likely the cause. There is even a warning about this printed on the cap itself. It's best to pump your own gas so this never happens but if you use full-service (or live in NJ where you don't have a choice) always check the cap after the clueless attendant puts it back on.
My 2002 WRX check engine light is on and is overheating. SUBY1305 Newbies & FAQs 17 01-15-2010 02:26 PM
My check engine light is on but car is running fine. Ripper Normally Aspirated Powertrain 27 09-24-2001 12:59 PM
Check Engine Light Is On!! Ya its Yellow Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-06-2001 07:35 PM
Uh Oh my check engine light is on Tainted South West Impreza Club Forum -- SWIC 21 07-27-2001 01:18 PM
Need Help-Check Engine light is on AndyHidley Technical Forum Archive 3 05-19-2000 02:35 PM
