Old 12-26-2006, 12:18 PM   #1
TurboCharged97L
Member#: 71508
1997 Impretzia
Artic Silver Metallic
Default Brembo vs Rotora
Im going to upgrade my brakes in the very near future and i was just wondering what some of you guys thought would be a better upgrade. Rotora 4-piston in the front and 2-piston in the rear VS the stock sti brembo (gold)setup 4-piston fronts and 2-piston rears. thoughts, comments, which would you get? thanks guys
TurboCharged97L is offline   Reply With Quote
Old 12-26-2006, 12:32 PM   #2
GTWORX.com
Member#: 97303
2009 WRX and Boxster
Gray and Black
What kind of driving do you do? Are you overworking your stock brakes? What kind of tires do you have? How much power are you making? What made you choose Rotora and Brembo?
Do you want more questions? Sorry
Personally, I'd have narrowed it down to Brembo and Stoptech.....
- Andrew
GTWORX.com is offline   Reply With Quote
Old 12-26-2006, 03:09 PM   #3
FromageTheDog
Member#: 81095
2005 WRX sedan kid-
bus. OS self-tuned!
After hearing all these nightmares about severe piston knockback with any kind of non-floating caliper (Stoptech, Brembo or otherwise) due to the weak WRX (non-'05+ STi) wheel bearings, I've started wondering if any BBK is worth it.
Ducts, pads, fluid, SS lines and better rotors seem like the safer (from a usability standpoint) alternative. Cheaper too...
FromageTheDog is offline   Reply With Quote
Old 12-26-2006, 03:11 PM   #4
Blue5spdWRXWgn
Member#: 93606
2002 WRX Wagon - WRB
2005 9-2X - SGM
Rotora is not very well respected and the Brembo conversion for a WRX doesn't have the best rear brake setup. Another thing you're going to run into with large diameter rotors with opposed-piston/fixed calipers is piston knockback due to a lack of stiffness in the WRX knuckles. The STIs have beefier knuckles to address the knockback issue and they have a different rear park brake designed for the rotors. A full conversion to STI knuckles is possible but expensive since it involves many other mating parts. The best BBK for the money is probably the Stoptech front which is balanced to work with the stock WRX rear brakes. The most trouble free upgraded front and rear brakes for a WRX are definitely the '06 4 pot and 2 pot brakes from the dealer. All of these choices can be improved with more aggressive linings, stiffer hoses and a stiffening brace for the master cylinder.
Other reasonable alternatives you might consider are TWR and TCE/Wilwood.
Blue5spdWRXWgn is offline   Reply With Quote
Old 12-26-2006, 09:06 PM   #5
kcook
Member#: 78074
2005 STi
what is knockback. and instead of considering brembo or rotora like i was also going to , how reliable and good are wilwoods, they seem to be on the cheaper side
kcook is offline   Reply With Quote
Old 12-26-2006, 09:26 PM   #6
Blue5spdWRXWgn
Member#: 93606
2005 9-2X - SGM
Knockback is Oh my gawwwwwwwwwwwsh there's no brakes!
The knuckle and hub assemblies flex under handling forces and since the calipers are on the knuckles and the rotors are on the hubs, the flexing allows the rotors to push the pistons back in the calipers which results in a long brake pedal displacement on the first application. The stock calipers are floating type with pistons only on one side which allow the caliper to move with the rotor as it flexes, where the Brembo and similar calipers have pistons on both sides and do not float with the rotor. The problem is exacerbated by larger rotors since there is more lateral motion at a bigger diameter. Racers get around this by pumping the pedal.
The Wilwoods are praised for competition use. As for street use, there tends to be more maintenance and noise with this type of system. I have no personal experience with the TCE kits, but they do seem really great for the money. The two piece rotors offer a nice weight savings, but the dissimilar metals in contact tend to corrode faster and they expand and contract at different rates which can cause noises. On the other hand, solid iron rotors tend to cup when they get really hot but the two piece stay flat as they expand under heat. They can also be less expensive to replace since the hat section can be re-used.
I went with FHI 4/2 brakes with upgraded solid rotors and pads.
There are many stages of brake upgrades and it all depends on what your goals and budget are. Check out Alcons for big budget beauties. The WRX brakes have quite a bit of potential and for most applications are more than adequate.
Old 12-26-2006, 10:35 PM   #7
Daishi00
Member#: 78952
2005 WRX
CGM
Out of curiosity, what is needed to convert over to the STi knuckle? I see they have different part #'s between the WRX and the 04 STi, but other than that I have no clue.
Daishi00 is offline   Reply With Quote
Old 12-26-2006, 11:29 PM   #8
FromageTheDog
Member#: 81095
2005 WRX sedan kid-
bus. OS self-tuned!
Upgraded bearings/hubs started with the '05s. The '04 STi had weaker (WRX) hubs. And yes, the latter apparently had knockback problems on the OEM brake hardware.
If you're really interested in doing this, talk to LiC Motorsports -- they specialize in this sort of thing and would almost certainly be able to get you sorted.
Last edited by FromageTheDog; 12-29-2006 at 12:17 PM. Reason: knuckles are the same -- I should have said hubs.
Old 12-26-2006, 11:38 PM   #9
FromageTheDog
Member#: 81095
2005 WRX sedan kid-
bus. OS self-tuned!
To clarify (and assuming we're talking about the gold STi Brembos): while the Brembo fronts are a bolt-on affair, the rears require quite a bit of supporting hardware. Installing just the fronts leads to even more front brake bias on an already heavily front-biased setup (this is bad).
I can only assume that the Brembo "Gran Turismo" kits which go for nearly $3k have pistons that are matched to the stock rear brakes, but who knows?
TWR is one big question mark for me. Does anyone have any meaningful track experience with their hardware?
Edit: clearly my memory of searching for TWR reviews was a fantasy. As Dave below points out, there are a couple very positive reviews floating around out there:
http://forums.nasioc.com/forums/showthread.php?t=710051
http://forums.nasioc.com/forums/showthread.php?t=525109
Wilwood is another mystery. Clearly the company is capable of making world-class hardware, as the Mosler 900 supercar uses Wilwoods, but I haven't seen any accounts of how these perform on our humble WRXs in the DD/recreational tracker context.
Edit: and while searching for the TWR info, here's a thread that speaks well on the Willwoods:
I wonder what oldmansan's experiences were...?
Last edited by FromageTheDog; 12-27-2006 at 08:53 AM. Reason: SEARCH, N00B!!! (OK)
Old 12-27-2006, 03:55 AM   #10
David Glasscock
Member#: 25033
06 sti my $$ pit
05 xt my DD
i had twr on my wagon and loved it. i didnt track the car but i've talked to people who have and they said they were awesome. i now have a 06 sti and to this day i feel the twr brake harder and faster then my stock brembos. it twr offtered bbk for the o6 sti, i would take them over my stock brakes and stoptechs...
if you do a search there were some people who did writeup after tracking their cars..
dave
David Glasscock is offline   Reply With Quote
Old 12-27-2006, 08:40 AM   #11
TCE
Member#: 100868
Can't speak for the TWR parts. The Wilwoods are worth a look but don't carry quite the wow factor in terms of name recognition with the tuner crowd. (oddly enough in Europe the Wilwoods are often the choice I guess because you can't get them as easy! Go figure) Their plus comes from both the affordable price point and wheel fit over other similar designs.
The TCE/Wilwoods are simply modified versions of the smaller LBK for the 15 and 16" wheel market. If you're running 16s now you may find the LBK to be a fine balance of price, durability and fit for you. And without the need for wheels. If you're running 17s then clearly taking advantages of any larger kit is the wiser investment. Step one is wheel fit, step two is price, step three is defining what's best for your use.
General info:http://www.tceperformanceproducts.co...s.pl?record=19
Local info: http://forums.nasioc.com/forums/forumdisplay.php?f=114
Knockback issues would be there still with any kit and the larger the rotor the more effect it will have.
TCE is offline   Reply With Quote
Old 12-27-2006, 05:15 PM   #12
David Glasscock
Member#: 25033
06 sti my $$ pit
05 xt my DD
Old 12-27-2006, 08:06 PM   #13
Daishi00
Member#: 78952
2005 WRX
CGM
Originally Posted by FromageTheDog View Post
Upgraded knuckles started with the '05s. The '04 STi had weaker (WRX) knuckles. And yes, the latter apparently had knockback problems on the OEM brake hardware.
I know that the 05+ have lots of redesign (still kicking myself for not get the STi instead of my WRX), but when I was fooling around on www.subarugenuineparts.com yesterday I noticed that the 04 STi has a different part # for the knuckle compared to the WRX. I wonder what the difference is.
Thanks for the info on who to talk to. It's something I might consider in the future if I have a knockback issue when I throw my Prodrive BBK on this spring.
Old 12-28-2006, 12:07 AM   #14
Flaroc01
Member#: 115390
Platinum Silver Metalic
If the FHI 4-pots are a fixed caliper design why don't they get knockback. Is it only with larger rotors? Also you should consider Racingbrake brake kits as well.
Flaroc01 is offline   Reply With Quote
Old 12-28-2006, 09:03 AM   #15
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
The knuckles are the same. Many of the part numbers are different between the wrx and sti even the part is the same.
Old 12-28-2006, 09:03 AM   #16
Turn in Concepts
Member#: 93646
Many Track Records
Been there, done that. Doesn't work well for tracking the car.
Old 12-28-2006, 09:14 AM   #17
TCE
Member#: 100868
I have to agree. Regardless of brand.
You can't add mass and efficiency with OEM enhancement parts. Firmer pedal; check. Grippier pads; check. Slots, holes, dimples...; sure.
In the end you're still "rotor challenged".
You might push the duty cycle of the stock part up a bit with all this and the cooling ducts. You're still better off operating at a lower cycle with more capacity.
Old 12-28-2006, 09:46 AM   #18
Turn in Concepts
Member#: 93646
Many Track Records
Couldn't agree more.
I find that my wrx on track power wise is faster than most of the other cars in my groups, but when it comes to braking...not so much. I give up so much by simply not being able to trust them when I need to. Coming down the end of a straight at 125+ and not being able to trust your brakes is nerve racking!!
Old 12-28-2006, 10:07 AM   #19
FromageTheDog
Member#: 81095
2005 WRX sedan kid-
bus. OS self-tuned!
Well I totally agree that it's not ideal, but I have yet to see a convincing solution that's DD-friendly, well-supported and effective. For my purposes (90% DD, ~4 HPDS-style events per year), I've just learned to live with having Coopers outbrake me into oblivion...
TWR: well-recommended, but TWR haven't posted anything here in years. They still exist, yes, but how interested are they in the Subaru market? I'm very reluctant to drop thousands on a product from a company that may or may not be around 5-10 years from now.
Wilwood: LBK? Maybe I should look you guys (TCE) up. How are these balanced with the rears? Would it be possible to upgrade just the fronts? Haven't heard much from folks that track these (vendors don't count; sorry TCE).
Stoptech: I wish, I wish. Seems like the perfect brake kit from the perfect brake company, but for whatever reason they clearly have some significant compatibility issues (they suffer from absurd amounts of knockback).
I understand that going to a fixed-caliper, larger-rotor system will almost inevitably lead to some pad knockback, but I'd like, at least in the low-key DD context, for my brakes to "just work" without any theatrics. Double-pumping is not something I want to be thinking about during a real emergency.
Seems pretty hopeless. TiC, TCE -- what do you run? I'd love, if nothing else, not to have to replace my front bearings every year.
Old 12-28-2006, 10:24 AM   #20
Turn in Concepts
Member#: 93646
Many Track Records
I am switching to an OEM sti brembo kit front with 06 wrx 2 pots rear sometime this winter for next season. Not sure on the pads I will be running yet, but most likely will start with HP+'s as they wil work on the street and go up from there depending on performance on track.
I will be running, and do now, Motul fluid with Galpher SS lines, Cusco MC brace and home made brake ducts. I will not be using the dust shields front or rear. My fronts are off already.
Old 12-28-2006, 10:29 AM   #21
Turn in Concepts
Member#: 93646
Many Track Records
Actually, Tony. You might be running something a little different than STi front takeoffs for this upcoming season if I can get some pricing info soon...
Old 12-28-2006, 10:48 AM   #22
PJC1909
Member#: 50274
2004 WRX Wagon
invisible
I agree. Tracked the car all last year on stockers and it always seemed like something was roasted at the end of the weekend, even with ducts.
I've tracked the TCE/WW stage 2 only once, at gingerman. It was a significant improvement. You do need 3mm spacers to run stock rims/stage 2. Todd is great.
I tried the TWR kit, but I had fitment issues that could not be resolved. The kit came poorly packed from Taiwan and there were no markings on the calipers. This was different, but more recent, than others' positive experiences.
PJC1909 is offline   Reply With Quote
Old 12-28-2006, 11:24 AM   #23
ESmooth
Member#: 118082
We sell a very large number of kits for the WRXs and our number of complaints regarding knockback are in the vast minority. The reason you hear so much about knockback with our kits is that there are a few avid posters here on the boards that experience this issue that post about it regularly. The issue is not that our brakes have issues with knockback, but that the WRX has weak hubs that are prone to the condition and our kits are very popular among the more hardcore drivers who are more likely to experience this issue. It would be safe to say that the people experiencing severe knockback would have the same issue with any brake kit from any of the manufacturers with the same size rotors and fixed calipers.
ESmooth is offline   Reply With Quote
Old 12-28-2006, 12:02 PM   #24
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
FWIW, I've never had any issues with knockback either for autox (lots of rapid turns) or on the street with my Stoptechs. I don't know if I have "Wednesday" hubs or what, but it hasn't been an issue. I bought my kit used from mav1c who had tracked his WRX wagon for 3 years (and who liked his brakes). Just as another datapoint
Old 12-28-2006, 01:31 PM   #25
TCE
Member#: 100868
Sure I'm the vendor on this one particular kit. But I'm also more of a no BS kinda guy and prefer you make your own choices based on as much information you can get.
The smaller LBKs (both the factory Wilwood and the fatter TCE version) are targeted towards the smaller wheel market. Period. There's no way I'd hang my butt out in the wind here to tell you either of them are on par with a larger 13" kit. Not so, won't ever be.
On the other hand what they do offer for guys smaller 15-16" wheels is darn hard to beat. And you don't need to fork over more money for new wheels. Will they fit 17s? Of course. Will they be better than stock? Sure. Are they worth the cost? For what you get over the enhancment package purchase I believe so.
Are they track worthy? Personally I don't own or track a Subi so I can only relate feedback. Mostly good. One marginal. A car run with the kit (think it was the factory kit not wide rotor option) was run at T-hill and really burned up a set of pads and scored the rotors. Was it a problem? Not so much a problem as a lesser level of product for the intended use. You simply cannot expect 14" x 1.25" six pot Alcon performance from a 12" x .81 smaller four pot caliper.
In the end the customer ran it hard, used up some pads, put the street pads back in and drove it home. With the intent of running 16s on it as well I'd say it did quite well. I suggested that in the future he look at the cooling ducts and run some higher (yet) Cf and temp pads. While it still won't be Stoptech territory it will fit the smaller wheel and cost half as much.
Regardless of name, you'll never get $3000 braking parts and performance from $1000 parts. It's no different here then other parts.
To fulfill my fetish for BBK? AP, Brembo, Stoptech, Rotora, Wilwood psun786 Brakes, Steering & Suspension 23 07-29-2006 03:14 PM
Stop Tech VS. Rotora 355 x 32mm ChAi Brakes, Steering & Suspension 10 03-20-2006 01:23 PM
To fulfill my fetish for BBK? AP, Brembo, Stoptech, Rotora, Wilwood psun786 Brakes, Steering & Suspension 0 11-11-2005 04:22 PM
Stoptech vs Rotora Frederf Brakes, Steering & Suspension 22 03-02-2003 02:23 PM
Sti Brembos vs. Aftermarket Brembos tifosi77 Brakes, Steering & Suspension 4 02-14-2002 09:35 AM
