Alaskan Impreza Club
Old 12-27-2006, 03:17 AM   #1
EvolvedAK
Member#: 100354
2002 Chevy2DLevee
AKLGT's Living Accessory
Default Mounts and movement
Originally Posted by 00Maddog View Post
well most of us would never try this, but the damage occurs when you are rev-limiting in 1st and attempt to engage 2nd before the wheels stop spinning, and in the process grind the holy hell out of 2nd. i think alot of this has to do with stock engine/trans mounts flexing under load/no load, which in turn ruins your shifting accuracy. this is due to the mechanical linkage shifter subaru utilizes. if i could show you the difference on a lift between stock and group n/cusco mounts you'd buy in a second. grabbing the driveshaft at the trans end, i can make the trans shake up and down and side to side 2-3"s with just a little tug/push! with the group n's, both hands barely move it, and with the cusco's, good luck haha. the onroad result is better then any shifter/bushing mod you've ever done for shifting. plus the car shakes at idle...
I have to definatly look at those cusco ones in the future when I get another Subie. Help keep weight from being unevenly distributed thus being able to take a corner much more correctly and precise. Just overall not having the weight of the car all over the place. How much do they cost ?
EvolvedAK is offline   Reply With Quote
Old 12-27-2006, 03:37 PM   #2
GrinderAK
Member#: 87551
97 OBS, 01 RS
2014 SWP FXT
has nothing to do with the weight of the car...
aaaa this is jerry....
GrinderAK is offline   Reply With Quote
Old 12-27-2006, 04:30 PM   #3
EvolvedAK
Member#: 100354
2002 Chevy2DLevee
If the engine has constant movement it will slightly push the car a particular direction. Hense gravitational movement. That movement is what im talking about. I'm not talking about like the mounts will cause weight reduction. But more along the lines of sparaticle movement. With heavy gas applied and partially let off that engine will move. That movement will apply a weight causing the car to be thrown off in a corner when more or less gas may be used.
My question though is that you say it with less movement you will have more precise shift points. So this allows to go into gear after rev matching for example easier correct?
Old 12-27-2006, 04:58 PM   #4
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
wheels move the car, they are bolted to the knuckles, knuckles do not move regardless if you even have engine mounts. also the engine twists/rotates, which will not change center of gravity in a measurable amount.
one end of the shift link hooks to the trans, the other the body. the shifter attaches in the middle of this link. when the trans moves at the rear, everything does. if engine is under a load and moved one way, when you clutch and grab the next gear it will shift to center, and your shift gate will move mid-shift. ever bump into the gate going from 2nd to 3rd wot? i used to...also with mods/drag use this becomes much worse with the stock mounts. 04+ sti stock mounts are just as crappy, except the trans mount is a little beefier.
00Maddog is offline   Reply With Quote
Old 12-27-2006, 05:07 PM   #5
EvolvedAK
Member#: 100354
2002 Chevy2DLevee
But going downhill things increase(especially the motion of weight and movement). The engine twists but goes back to it's regular position. Right? It's like having a passenger go to the left and snap the body to the right as I see it.
-Btw you better come to the party...last time we were at eklutna I was in a trance from all the info coming from you. You must tell me more about subaru mechanics/build
Old 12-27-2006, 05:12 PM   #6
00Maddog
Member#: 62410
2004 wrx w/o engine
psm/carbon
ok i see what you're saying, kinda like the trunk monkey that transfers weight at critical moments... i still can't find one of those....
Old 12-27-2006, 05:15 PM   #7
EvolvedAK
Member#: 100354
2002 Chevy2DLevee
No my trunk monkey is for this Jerry... This is the Chevy version...but the Subie version is just as good.
http://video.google.com/videoplay?do...k+monkey&hl=en
Old 12-27-2006, 05:16 PM   #8
EvolvedAK
Member#: 100354
2002 Chevy2DLevee
'04 wrx driver seat noise and movement sjw Service & Maintenance 1 07-05-2006 11:09 AM
match, mount and balance, or just mount and balance? CletusTheDwarf Tire & Wheel 2 06-26-2006 02:06 PM
STI Engine mount and stock tranny mount vik New England Impreza Club Forum -- NESIC 1 02-19-2002 04:16 PM
Question or the difference of top mounts and upper pillow mounts C_Rambo Brakes, Steering & Suspension 2 02-09-2002 08:51 PM
Difference between STI tranny mount and STI WRX RA tranny mount... can any1 explain? MrP0nch0 Brakes, Steering & Suspension 4 11-07-2000 07:19 PM
