Old 12-27-2006, 11:20 PM   #1
zippydoc
Member#: 80988
Default Hard Shifting into 1st from dead stop
I have a 2004 WRX with 5sp. manual tranny. At 53k miles, shifting into 1st is getting harder. Replaced gear oil with Redline 75W-90 NS with none of the usual improvement. Dealer says the tranny is working fine. If that's so, why didi Subaru go to double cone syncros in 1st this past year? Any solutions?
zippydoc is offline   Reply With Quote
Old 01-02-2007, 11:50 AM   #2
crynow82
Member#: 118396
03 WRX
Yea, I have the same issue too. I also have a short shifter which makes it even worse. I noticed if the car has been sitting in the cold it seems harder too.
crynow82 is offline   Reply With Quote
Old 01-02-2007, 12:22 PM   #3
JonR
Member#: 22753
2002 PSM WRX +PPG
OBXT
Try Uncle Scotty's cocktail...it has worked for many. This is a common problem.
JonR is offline   Reply With Quote
Old 01-02-2007, 01:02 PM   #4
akira02rex
Member#: 82612
2015 WRX STI
Ice Silver Metallic
Either that or GM Syncromesh.
Shifting into 1st from a slight roll for me is painless and smooth
akira02rex is offline   Reply With Quote
Old 01-02-2007, 01:44 PM   #5
crynow82
Member#: 118396
03 WRX
What is that?
Old 01-02-2007, 03:01 PM   #6
JonR
Member#: 22753
2002 PSM WRX +PPG
OBXT
2 bottles of Castrol Hypoy C 80w90 (Pepboys)
1 bottle of Redline Lightweight Shockproof (Check your local performance shop or online shop like summitracing.com)
1 bottle of Pennzoil Synchromesh (Autozone)
prepare to be impressed
Old 01-03-2007, 12:55 PM   #7
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
I started double clutching when stopping to get into 1st. But it would still get on my nerves. I installed(i had someone else install for me) STi RA's and now can shift to first on a roll, even at 10 mph. But I had never tried Uncle Scottys cocktail, some on here like it alot. Its alot cheaper than new gears.
breathinez is offline   Reply With Quote
Old 01-03-2007, 06:18 PM   #8
dmcmahan12
Member#: 50370
2008 STi
Default RA Gear set
That is just what I had installed in my 04 WRX after exploding 2nd one time and 3rd one time. Love the RA Spec C gearset!!! Alot more shifting but I feel confident about my tranny now.
dmcmahan12 is offline   Reply With Quote
Old 01-16-2007, 09:16 AM   #9
crynow82
Member#: 118396
03 WRX
On the uncle scotty's mix, do you have to premix all the fluids or just poor one bottle in at a time? I finally got all the ingrediants and will prolly do it this weekend. I have no idea if the guy before me ever changed it and now I have 51k on it, bought it with 48k. I have all his records from the dealership he took it to, but they stop at 35k and have nothin about tranny fluid. So how much of a difference will I notice after changing this?
Old 01-16-2007, 02:01 PM   #10
RayO
Member#: 42329
2002 WRX sedan
Add all of the shockproof, all of the synchromesh, and top up with the 80w90. Don't overfill.
Some people imply that it takes a few miles to feel the difference. My trans felt better right away.
RayO is offline   Reply With Quote
Old 01-16-2007, 02:01 PM   #11
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
No, no need to pre-mix. For mine, it was like a new tranny. Couldn't compare. Actually made it quieter. It still occasionally grinds going into first, but only maybe 1 out of a hundred downshifts. I can live with that!
drivin blind is offline   Reply With Quote
Old 01-16-2007, 03:07 PM   #12
crynow82
Member#: 118396
03 WRX
coo, can't wait till try it out.
Old 01-16-2007, 04:35 PM   #13
Knightmare69
Member#: 25039
2005 CGM Stage 2 WRX
SQC 275
I can't either, getting mine done this sat, looking forward to better shifting.
Knightmare69 is offline   Reply With Quote
Old 01-23-2007, 08:30 AM   #14
crynow82
Member#: 118396
03 WRX
well I did it and it works a little better. I honestly was expecting more, so maybe it could also be a combo of my b&m short shifter also.
Old 01-23-2007, 08:36 AM   #15
Jakes02
Member#: 129234
2002 Finally stage 2
hmmm I'm in the same boat as you, I also expected more and I too have the B&M shifter.
Jakes02 is offline   Reply With Quote
Old 01-23-2007, 08:42 AM   #16
Tenacious Bee
Member#: 96452
So, what to play
with next ?
I have the same problem. I had a used transmission installed around Thanksgiving and that is when it started. I am pretty sure the tech at the Nissan dealership I work at used Nissan gear oil instead of Subaru gear oil. A friend adjusted my clutch and a lot of it went away. He feels with more adjusting and better gear oil it can be eliminated altogether. I want to express that this is my friends opinion. He is not a transmission tech.
Tenacious Bee is offline   Reply With Quote
Old 01-23-2007, 09:11 AM   #17
Knightmare69
Member#: 25039
SQC 275
Well I had my fluid changed to Uncle Scotty's cocktail this past weekend and while I cannot notice a HUGE difference, there are slightly better differences but then again my mechanic also told me that it would take about 100 miles for all the fluids to properly start working together. I still kinda have a problem getting into first and reverse without forcing it so hopefully by my next gas fill up, the fluids will start to sync with my gears.
Old 01-23-2007, 10:52 AM   #18
crynow82
Member#: 118396
03 WRX
Yea, hopefully it starts to mesh together better later.
Old 01-24-2007, 06:10 PM   #19
-AliasMunky3-
Member#: 57407
1983 02WRX & 14BRZ
WRB & DGM
Default Redline 75W90NS boo-hiss
I too am having the 1st AND 4th gear issue with my newly added Redline 75W90NS from Motul synthetic gear oil; not happy with it at all. I'll be going to the Uncle Scotty mix soon.
Do the components have to be ordered seperately or is there a single place to order them online? Possibly a retail store on the East Coast to buy all of them at once?
-Al
-AliasMunky3- is offline   Reply With Quote
Old 01-24-2007, 06:33 PM   #20
Knightmare69
Member#: 25039
SQC 275
Google the synchromesh and it should come up with a company called midway something, that's where I got the synchromesh and amsoil
Old 01-28-2007, 01:11 PM   #21
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
After changing to Motul Gear300 75w90 I can shift into 1st almost as easily as any other manual trans I've driven. You can still tell it's a Subaru trans but it's a lot easier to shift.
slowmike is offline   Reply With Quote
Quiet "clunk" shifting into 1st from a stop, car moves forward mighty_hank Transmission (AT/MT) & Driveline 6 09-28-2007 01:29 PM
Hard to shift into gear from a stop, just did an RA swap... K2Skier Transmission (AT/MT) & Driveline 6 05-28-2006 10:47 PM
Hard time shifting into 1st at stop Lever2ooo Transmission (AT/MT) & Driveline 25 08-03-2004 08:15 AM
WRX: gear grinding when shifting into 1st at a stop Zaid Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 01-07-2002 08:14 AM
