South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 12-25-2006, 11:10 PM   #1
azscooby
Member#: 115297
2002 ej207 vf34
Default ?'s for AZ emissions....
I'm looking to complete my tbe by adding uppipe and downpipe to my Greddy sp2 (I think, Greddy something, very quiet.)
My question is whether or not you guys have had any emissions problems by going completely catless? I do want to get a catted downpipe, don't want to completely destroy the environment, and I hear they aren't nearly as loud (good thing for me, don't really want increased exhaust volume than I already have.)
Is my exhaust volume going to increase substantially with an uppipe and catted downpipe? What about catless, noise wise, emissions wise?
Any suggestions for brands that won't have emissions issues?
I'd like to take a look/listen to some of your setups before I take the plunge and spend some Christmas dough.
Thanks all...
azscooby is offline   Reply With Quote
Old 12-25-2006, 11:54 PM   #2
taerron
Member#: 75744
2k2 low boostin
evo3, for now....
i'm wondering the same thing too. i'll be up for emissions in jun 07. maybe the people with the engine swaps can help out on this
taerron is offline   Reply With Quote
Old 12-25-2006, 11:58 PM   #3
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
Get a APS system. You can swap cats in and out.
06STi is offline   Reply With Quote
Old 12-26-2006, 12:02 AM   #4
taerron
Member#: 75744
2k2 low boostin
evo3, for now....
i have a catted dp. u think i need another one?
Old 12-26-2006, 12:16 AM   #5
06STi
Member#: 97561
2006 Widebody
WRB/Carbon/Primer
Do you have the catted up pipe still?
Old 12-26-2006, 12:22 AM   #6
wagonmasta
Member#: 52880
GGA Rev.D
+1 for APS
wagonmasta is offline   Reply With Quote
Old 12-26-2006, 04:16 AM   #7
dozer54321
Member#: 116437
i have to go through emmissions in january, i am all catless, so i am going to attempt to take a run through as is, ill let you all know how goes it
dozer54321 is offline   Reply With Quote
Old 12-26-2006, 05:29 AM   #8
ChrisL2
Member#: 1444
It really depends. Since your car is post 96, they might just do the OBDII test. No codes mean you pass.
However, if it sounds loud, etc, they might actually do a check for cats.
Linky to testing information:
http://www.azdeq.gov/environ/air/vei/tech.html
ChrisL2 is offline   Reply With Quote
Old 12-26-2006, 09:07 AM   #9
dubya05
Member#: 91319
2005 05wrbWRX...SOLD
gas sucker yukon
+1 for being able to switch out cats on the APS system but im not that much of a fan of the APS DP. cast iron elbow off of the turbo is way too heavy and a pain. Cast iron (turbo hot side)to cast iron 9APS dp elbow) tends to "weld" turbo bolts together.
<- victim of broken turbo exhaust stud.
dubya05 is offline   Reply With Quote
Old 12-26-2006, 09:07 AM   #10
06 Scooby
Member#: 118474
06 uppipe FTW!!
06 Scooby is offline   Reply With Quote
Old 12-26-2006, 10:40 AM   #11
pudnana
Member#: 89071
2000 Blue 2.5 RS
2004 Java WRX
Thanks all...
If I remember correctly, according to Arizona or Federal law, you're not supposed to change your cats at all unless the current ones on the car are found to be defective. And when they are defective and must be changed, it needs to be with a "OEM quality" cat. There for if you go to emissions, and have a visual check, you COULD get busted. No cats is a pretty big fine too.
pudnana is offline   Reply With Quote
Old 12-26-2006, 11:18 AM   #12
azscooby
Member#: 115297
2002 ej207 vf34
Yeah, that's what I'm worried about. I know my other post '96 cars just get OBDII scanned, no sniffers, no visual checks.
Even when I bought the car with CA plates, the DMV guy never bothered to look at anything other than matching VIN#'s - and it had a catback exhaust, but it was very quiet.
So even if you put a "high flow cat" it might not matter?
Old 12-26-2006, 11:21 AM   #13
azscooby
Member#: 115297
2002 ej207 vf34
from the above link....
Tampering: In addition to one of the above tests, a vehicle may undergo a visual inspection to determine the presence of certain emission control components as installed by the manufacturer. Inspection includes catalytic converter, operational air pump, positive crankcase ventilation system and evaporative control system. These inspections coupled with the evaporative system integrity (pressure) test constitute the tampering inspection.
So is that a +1 for a gutted system? I know the gutted uppipe has similar gains to a manufactured uppipe, what about the dp?
Old 12-26-2006, 11:58 AM   #14
racingfish
Member#: 60976
1969 LGT
FATURBO
i know someone who went to get their wrx tested... he has no cats and passed.
hope that answers your question....
1. they dont do a visual
2. they dont do a sniff
3. your allowed 1 ready light
4. they only check if your have a cel showing
5. they will spot check a car by throwing it on the dyno (2wd)
racingfish is offline   Reply With Quote
Old 12-26-2006, 02:41 PM   #15
pudnana
Member#: 89071
2000 Blue 2.5 RS
2004 Java WRX
my understanding is that "by law" even a high flow cat is a no-no, but whether or not its enforced is a different story. I think the Random Tech cats are considered "carb" legal so those would be acceptable. In reality thats what you're looking for on any aftermarket part is if its "carb" legal, with the numbers to justify it. Most downpipes on the market that have a high flow cat are only 1 cat therefore you're elimating one cat which is altering the system. My personal opinion, I wouldn't try getting a car tested with out at least one cat in the system.
Old 12-26-2006, 02:44 PM   #16
dozer54321
Member#: 116437
again ill let you know come january some time
Old 12-26-2006, 09:37 PM   #17
pajak
Member#: 95992
08 E92 335i
Grey
How do they put it on a 2wd dyno? Isnt that bad?
pajak is offline   Reply With Quote
Old 12-26-2006, 10:23 PM   #18
Valhakar
Member#: 39514
2003 WRX 2.5L Hybrid
Mostly Blue
I just got My emissions done last week, I still have my Virginia plates. I run with 2 cats removed and a Custom Protune on an Accessport.
ODB2 port test and out the door. The only inspection I got was everyone gawking at my MRT TMIC.
Valhakar is offline   Reply With Quote
Old 12-26-2006, 10:24 PM   #19
Black-Falcon
Member#: 106318
16 Cadirrack
ATS-V
You don't, and thats why there is no dyno test for subaru's.
Black-Falcon is offline   Reply With Quote
Old 12-27-2006, 04:31 AM   #20
pajak
Member#: 95992
08 E92 335i
Grey
When he put "they will spot check a car by throwing it on the dyno (2wd)" i knew that they dont do that, i said that so he could fix it, i think he was confused.
Old 12-27-2006, 11:32 PM   #21
05blkoutWRX
Member#: 96679
2006 WRX
i work at a emissions place. let me know when you guys come in and ill hook you up. with all cars 96 and newer we just hook it up to our computers and as long as your check engine light works properly you will be fine. but thats it. we dont do a visual check for our cars. so yea basically everthing that racingfish said
05blkoutWRX is offline   Reply With Quote
Old 12-28-2006, 12:13 AM   #22
dozer54321
Member#: 116437
ill be letting you know fairly soon then, you are off of glendale yes?
Old 12-28-2006, 10:06 AM   #23
racingfish
Member#: 60976
1969 LGT
FATURBO
i dont think im ever confused... and they do throw it on a 2wd dyno... i thought that you would put 1 and 1 together and relized u have bought a awd car, hence making it exempt... guess i was wrong for thinking that u'd have the brains to figure it out...
Old 12-28-2006, 02:30 PM   #24
pajak
Member#: 95992
08 E92 335i
Grey
Yeah makes alot of since thowing our awd cars on a 2wd dyno ill tell the emissions place to **** off unless they want to pay for what they break.
Old 12-28-2006, 02:34 PM   #25
Valhakar
Member#: 39514
Mostly Blue
They will NOT Dyno an AWD car on they Dyno. AWD is exempt. If you are Pre1996 they will still sniff you at 2-3 different throttle positions. If you are 96+ then you have ODB2 and they simply hook up the ECU to their check station.
Anyone with an AccessPort is fine. Anyone that is reflashign their own with OPEN ECU tools should be fine. Anyone with a UTEC is BONED. Piggybacks FTL.
CA Reintroduces Bill for ANNUAL Emissions Tests for Vehicles 15-Years & older VincenzoL Southern California Impreza Club Forum -- SCIC 7 03-13-2009 04:16 PM
AZ emissions Aaron05sti South West Impreza Club Forum -- SWIC 21 04-01-2008 07:53 PM
Passing AZ Emissions..... WRX-PLOD South West Impreza Club Forum -- SWIC 9 12-13-2007 07:41 PM
question about AZ emissions... Blindeye_03 South West Impreza Club Forum -- SWIC 12 09-24-2004 04:55 AM
NM, AZ - Emissions Laws in either state??? mykrrrr South West Impreza Club Forum -- SWIC 27 05-19-2004 08:39 PM
