South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 12-29-2006, 02:21 AM   #1
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
Default uppipe wont line up
my cobb uppipe still isnt wanting to cooperate. it is starting to leak at the top of the gasket again. it doesnt seem that it lines up correctly. i put the crucial racing gasket between the uppipe and exhaust manifold but it keeps springing a leak at the top. i am thinking about de-catting my stock uppipe and putting it back on. are there any downsides to using a gutted uppipe? is there anything that could have been done to make the uppipe not line up? (i.e. downpipe crooked, etc.)
v8eaterWRX is offline   Reply With Quote
Old 12-29-2006, 02:43 AM   #2
boosted20
Member#: 79576
I had good luck mounting my uppipe with the turbo loose. also, if you gut the cat just make sure you get all the metal out and clean it good so all that crap doesn't go through your turbow. air tools work well for that kind of thing. it really is not worth it though
boosted20 is offline   Reply With Quote
Old 12-29-2006, 02:48 AM   #3
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
i dont really want to, im just tired of wasting money on gaskets. it is all connected and looks fine, even works fine for about a week, but i keep springing a leak at the top of the up to manifold gasket.
Old 12-29-2006, 03:01 AM   #4
Black-Falcon
Member#: 106318
14 Cadirrack
ATS
Tell cobb to send you a new up pipe.
Black-Falcon is offline   Reply With Quote
Old 12-29-2006, 03:21 AM   #5
boosted20
Member#: 79576
are you using a torque wrench? Idk what else it could be. maybe a design flaw
Old 12-29-2006, 04:14 AM   #6
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
is there any indication of oil in your exhaust? I would take it out and compare it the stock one, sometimes exhaust flanges (in general) can bend from being tightened too much or from poor design.
If it's not a good fit, tightening the bolts will pull teh ears of the flange in where they are connected to it, making a gap inbetween where the bolts are.
Also, if you have blow by of some sort and traces of oil get on the gasket, it will cause the exhuast to blwo the material out where it's contaminated.
bobturismo is offline   Reply With Quote
Old 12-29-2006, 10:42 AM   #7
MrMcCrackin
Member#: 89202
I'm # 1 when it
comes to # 2
+1
turboXS had this issue for a long time "in the begining" since they have changed their design completely - i still have an old "leaky" version
also - is that cobb unit a "flexi" one? if not, may consider changing to one.
the stocker had a little flex in it - i noticed that after i busted a motor mount that the egine torque actually cracked flanges and bends in my aftermarket header
with the amount of heat in this particular exhaust system - something has to give!
MrMcCrackin is offline   Reply With Quote
Old 12-29-2006, 11:14 AM   #8
LegacyGt05
Member#: 80074
2007 BMW 335i
Sapphire Black Metallic
Helix UP FTW!
LegacyGt05 is offline   Reply With Quote
Old 12-29-2006, 11:48 AM   #9
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
it does not have a flex pipe in it, just a regular pipe.as far as oil, i didint see anything the last time that i had it off. it seems that it just keeps tightening on one side, and pulls the other side loose. no torque wrench, just tighten till it stops.
Old 12-29-2006, 12:10 PM   #10
MrMcCrackin
Member#: 89202
I'm # 1 when it
comes to # 2
call cobb
if i remember correctly this will be the 3rd set of gaskets - no?
tell them - see what they say
the last time you and jeff did the job absolutely correctly - with everything loose and tightening everything from the header/manifold up to the turbo
also - it might not be a bad idea to take a peak at your lower motormounts - see if the torque side is crushed or not.
Old 12-29-2006, 04:14 PM   #11
intercoolerontop
Member#: 72148
2010 Ford Raptor
RAWR
i hate ur car, let me try and work on it to fix it. Seems like u just need to get a built motor already
intercoolerontop is offline   Reply With Quote
Old 12-29-2006, 04:55 PM   #12
boosted20
Member#: 79576
torquing all the nutz equally can get rid of the gap. I had the same problem even with a flex pipe. if the flange is not torqued flat against the manifold then it can leak on the side that is less tight.
Old 12-29-2006, 05:14 PM   #13
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Is the turbo bracket loose when you're doing this? As in, you have enough slop in the turbo for it to mate up properly with the up pipe? I had the best luck when the dp was off and the turbo was very loose. No leaks since.
Snowphun is offline   Reply With Quote
02 wrx lefthand cams wont line up wrxiting Service & Maintenance 3 04-17-2009 09:34 AM
motor mounts wont line up B00ST_Creep03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-30-2009 10:38 AM
Up Pipe installll helpppp!!! engine mount wont line back up?! WTFJayJay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 02-24-2009 05:25 PM
1995 impreza, 99 Rs front seats wont line up? 98legdriver Subaru Conversions 3 07-17-2007 08:04 PM
uppipe wont line up v8eaterWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-29-2006 12:42 PM
