Old 11-21-2001, 06:53 PM   #1
TurboSub
Member#: 8701
WR Blue Pearl
Question CEL question?
How bad is it if the CEL comes on. It's happen to me twice , I think both times were cause by the gas cap not being on right. Here are a couple of questions I have: 1. If it is a steady light is there still a possible problem 2. Do I have to reset the ECU after a CEL 3. where can I take my car to have someone pull the code, can I do it my self, any mechanic , just subaru? 4. Is it bad to just leave it alone when the light comes on?
Thanks for any help.
James
TurboSub is offline   Reply With Quote
Old 11-21-2001, 10:18 PM   #2
yamarocket630
Member#: 9436
05 Saab 9-5 Aero
The cel means the ECU has detected a problem. It could be minor or major. No way to know unless you pull the code. ANY OBDII scanner will pull the code. Should you reset it? Not unless you know what the problem is... unless you like driving around with a mystery problem that could be major.
yamarocket630 is offline   Reply With Quote
Old 11-21-2001, 10:39 PM   #3
Flesher
Member#: 7921
Sliver
According to a subaru mechanic that I asked the same question, if the light is on steady and the car seems to be running ok it's not an emergency to get it checked; it's just some part of the emissions system not working 100%. If the CEL's blinking then it _is_ a big problem, and you should go to a dealer ASAP.
Flesher is offline   Reply With Quote
Old 11-22-2001, 12:35 AM   #4
wolf8314
Member#: 9185
2012 Toyota Tundra
Default I know what your going through
Let me tell you ....i know exzactly what your going through. I have had problems with my CEL ever sense i bought the car. Most recently the CEL would come for two to three days then go off for a week then come back. Real weird. I noticed no performance loss, but went to the dealer neways. THey suggested since i had no performance loss to reset the ECU. SO i did and ahvent had a CEL in 2 weeks now and have had no problems. Word of advise though.........make sure you dissconnect your alarm or be fore warned that your alarm will go off after your reconnect your alarm. My ears still are ringing and my head still hurts
wolf
wolf8314 is offline   Reply With Quote
Old 11-23-2001, 10:45 AM   #5
TurboSub
Member#: 8701
WR Blue Pearl
Thanks for the help guys. I have no performance loss, the car is running just as good as before, so I'm just gonna reset the ECU.
Old 11-23-2001, 10:50 AM   #6
SubEd
Member#: 717
Default Re: I know what your going through
Wolf, that's bad advice on your dealers' part. They are obligated to pull it to see if there is anything to be concerned about. The light came on for a reason - could be as small as a loose gas cap, but it could be for something more serious.
Sounds like they were being slackers.
Ed
SubEd is offline   Reply With Quote
Flashing cel question mikaust Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-24-2001 02:45 PM
CEL Question... Strafe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 12-15-2001 12:32 AM
exhaust/OBDII/CEL questions 2.0 guy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-03-2001 01:10 AM
