Old 12-30-2006, 02:15 AM   #1
dumbkid
Member#: 129053
2004 WRX wagon
Default engine knock all gears during WOT
Hi. I recently had engine problems with misfiring and rough idle after I was involved in an accident. It turned out to be a timing belt issue and was fixed at the subaru dealer. Now the car idles fine and accelerates smoothly except when I'm close to or at WOT, usually around 3k-4k. That's when I start to feel the engine buck and the CEL begins to flash. The CEL turns off after a few seconds. I am running on a stock engine with stock ecu.
Things that checked out at the subaru dealer and are okay are spark plugs,
coil packs & wires. They said that cylinder 4 compression test came back "slightly" less then the other three cylinders. They wanted to go and remove the cylinder head to check the valves, but I didn't want to do that just yet due to lack of funds. Also, they said that there is no guarentee that my engine problem is there.
Are there things I can look for myself? If it's fuel system stuff, what are some tests that I can do or things I can change to try and aleviate this? I also have a tatrix cable that I received just a couple days ago so I can do some data logging, but I don't really know what I should log or look for. I've already cleaned the MAF with some MAF cleaner. Looked around for loose vacuum tubes. Used Seafoam. Reset ECU. Tried the Vishnu Reset. Even reflashed my ECU to the newest Stock ECU rom. The car is still drivable. It just bums me out a bit cause I can't really "put the pedal to the metal".
dumbkid is offline   Reply With Quote
Old 12-30-2006, 02:46 AM   #2
zman519
Member#: 118086
2003 WRX
Did sum one Hit you? if so why not just make their insurance pay for the dealer to fix it.
Sorry if i'm not any help but i was wondering about that
zman519 is offline   Reply With Quote
Old 12-30-2006, 08:38 AM   #3
dumbkid
Member#: 129053
2004 WRX wagon
No, I hit someone else going approx 10-15 mph. I didn't want it to go on my dmv record.
Old 12-30-2006, 11:14 AM   #4
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
is it under warrenty?
Old 12-30-2006, 11:32 AM   #5
rkramer
Member#: 118209
2015 WRX Limitec
if it is due to his accident it won't be
Old 12-30-2006, 11:35 AM   #6
anthonyrb98
Member#: 48307
02 bugeye
hbspeed tuned 18g sleeper
what were the actual compression test readings?
anthonyrb98 is offline   Reply With Quote
Old 12-31-2006, 12:04 AM   #7
dumbkid
Member#: 129053
2004 WRX wagon
I'm not sure what the actual compression tests read. I'll probably get around doing a test myself sometime this week. After doing a bit more driving, I've noticed that the misfiring occurs when I have boost greater than 9-10 PSI. The last CEL was a P0303 for a cylinder 3 misfire. Since this is occuring under higher boost levels, is it a possibility of it being related to a faulty hose?
Otherwise, the engine runs nice and smooth at all rpms as long as boost is below 10PSI.
Old 12-31-2006, 12:57 AM   #8
socalwrxf4#15
Member#: 113116
2003 WRX
white
sell it
socalwrxf4#15 is offline   Reply With Quote
Old 12-31-2006, 11:00 AM   #9
dumbkid
Member#: 129053
2004 WRX wagon
Any other bright ideas?
I would love to sell it, but the cars been paid off and it sure is nice not having any car payments. I think it will be cheaper to fix it, even if it costs a grand or so.
Old 01-01-2007, 10:00 AM   #10
blown.2nd.AGAIN
Member#: 136086
99 WRX
WRC Blue
Post
How many miles has the car done? Sounds like an air metering issue, try swapping another MAF and then test.... I had the same issue with some slight pinging under light load, ended up changing to 02 sensor and MAF, problem solved and back to 16psi
blown.2nd.AGAIN is offline   Reply With Quote
Old 01-02-2007, 12:46 AM   #11
dumbkid
Member#: 129053
2004 WRX wagon
The car has 70,000 miles on it. I'll look into swapping the MAF and/or O2 sensor.
Old 01-02-2007, 01:20 AM   #12
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
the maf may just need cleaning..
jigga is offline   Reply With Quote
Old 01-02-2007, 02:43 AM   #13
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
check your plug gap As I had this happen and after a while it throw a rich code. That's where I would look.
Old 01-02-2007, 01:42 PM   #14
dumbkid
Member#: 129053
2004 WRX wagon
I just did a compression test on my engine.
The results are:
1 - 129, 130
2 - 128, 128
3 - 131, 132
4 - 127, 126
I'm not sure how much difference there should be allowed between cylinders. Could cylinder 4 with slightly less compression be the cause of high boost misfiring? I checked the gaps on the plugs and they are all even. They are fairly new and I just recently changed them after the accident, and having just removed them, I checked the gaps again and they are still good. I'll be stopping by my mechanic later to see if he happens to have a MAF around that I can throw on my car.
Old 01-02-2007, 02:36 PM   #15
JeffrWRX
Member#: 48589
2016 WRX 6mt CWP
Those were done on a cold engine right? Its ok that they are off by a few psi.
JeffrWRX is offline   Reply With Quote
Old 01-02-2007, 03:15 PM   #16
dumbkid
Member#: 129053
2004 WRX wagon
Actually, those measurements were taken with a warm engine. I know the numbers are a bit low compared to the normal 150 psi readings. This was measured using a compression measuring tool that you can check out from Autozone, so I'm uncertain about the accuracy.
Also, the only CEL that I get now is the cylinder 3 misfire. Since I was doing the compression test, I went ahead and swapped the cylinder 3 ignition coil. After doing that, I still get a CEL cylinder 3 misfire.
Can this possibly be a faulty cylinder 3 fuel injector?
Old 01-02-2007, 05:56 PM   #17
crazymikie
Member#: 56321
2006 Honda El Camino
Green
What did the plugs look like when you pulled them?
crazymikie is offline   Reply With Quote
Old 01-02-2007, 06:57 PM   #18
dumbkid
Member#: 129053
2004 WRX wagon
All four plugs looked the same in color, like a grayish haze.
Old 01-02-2007, 08:14 PM   #19
blown.2nd.AGAIN
Member#: 136086
99 WRX
WRC Blue
Sound like your running a little on the lean side. I had the same problem at around 80k. Car was running like absolute ****e. Change the MAF, if that doesn't help check your 02 sensor(should be replaced about now) Definantly a fueling issue.
Old 01-02-2007, 09:20 PM   #20
dumbkid
Member#: 129053
2004 WRX wagon
When you talk about changing the O2 sensor, are you referring the front or the rear O2 sensor?
Old 01-02-2007, 09:57 PM   #21
blown.2nd.AGAIN
Member#: 136086
99 WRX
WRC Blue
Check both, go with the rear 02 first. If the front 02 comes from number 3 cyl, then replace it.
Old 01-02-2007, 10:23 PM   #22
dumbkid
Member#: 129053
2004 WRX wagon
Maybe I'm just reading this wrong, but doesn't the exhaust from all the cylinders flow by the front and rear O2 sensor?
Old 01-02-2007, 10:58 PM   #23
blown.2nd.AGAIN
Member#: 136086
99 WRX
WRC Blue
are you talking about the sensor in the up pipe? i think that may be an EGT(exhaust gas sensor). Some subaru's have an 02 sensor located in the front pipe near the radiator, in that case it will only read the left bank of cyclinders.
Old 01-02-2007, 11:11 PM   #24
dumbkid
Member#: 129053
2004 WRX wagon
Thanks for clearing that up for me. I was looking at the uppipe and reading the wrong number in the diagram.
Old 01-02-2007, 11:28 PM   #25
Bolster
Member#: 22290
2002 WRB WRX Wagon
Is your car stock or do you have mods? If so, can you list them for us?
Bolster is offline   Reply With Quote
WOT sputter and CEL, engine knock on 09? bjwk89 Newbies & FAQs 21 02-23-2009 09:49 PM
Why Is The Engine Knocking Like Mad During Cold Snap? williaty Open Source Reflashes 7 01-03-2008 04:51 PM
Does ECU add fuel for high IAT during WOT? root Engine Management & Tuning 4 07-31-2005 09:58 AM
Problem shifting from 1-2 during WOT WarHawk187 Transmission (AT/MT) & Driveline 10 02-17-2005 11:28 AM
my cars front end lifts too much during WOT, any ideas? Electronsmurf Brakes, Steering & Suspension 14 10-21-2002 10:17 PM
