Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 12-30-2006, 05:50 AM   #1
Cusson
Member#: 95695
2003 WRX Sedan
ACLASS
Default Synthetic vs Non-Synthetic Oil For Turbo Installation
im installing a new vf34 tomorrow and i need to break it in; ive read mixed things about using synthetic or non-synthetic oil. which is the BEST way to go? i want to make sure this install is done right.
thanks
Cusson is offline   Reply With Quote
Old 12-30-2006, 09:09 AM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
If you go to boostplanet.com and read the install instructions he specifically says not you use synthetic oil for break in. Boost planet is Deadbolt.
Tony
Old 12-30-2006, 09:37 AM   #3
prometheum
Member#: 92003
04 bicycle!
Tony
exactly what i was going to say
prometheum is offline   Reply With Quote
Old 12-30-2006, 09:51 AM   #4
hotrod
Member#: 14141
2002 Impreza WRX
It really should not make any difference to a turbo. The turbos that have journal bearings have no direct bearing contact when they are running (only on start up). Once the turbo is spinning, the shaft and journal bearings float on a dynamic oil cushion.
On the roller/ball bearing styles you have a high percision bearing that should not need any breakin as they are manufactured to very high tolerances.
Unlike an engine, that has wear parts like piston rings, and lots of low precision insert bearings there is really not a lot of breakin required other than to ensure that the turbo is properly primed with oil and not beaten on hard for the first few minutes of run time.
Since synthetic oils have higher film strengths and more resistance to break down, they would give you more safety margin if there is some poor lubrication during the first start up.
I've started rebuilt turbo's on synthetic oil with no problems at all.
Just use the oil you normally use in the engine, and take the time to build oil pressure before you start the engine. A turbo spins at about 20,000 rpm just at idle so any problem with initial oil supply can cause damage quickly.
Larry
hotrod is offline   Reply With Quote
Old 12-30-2006, 02:31 PM   #5
subenerd
Member#: 72630
2004 STi
Thanks Hotrod.
subenerd is offline   Reply With Quote
Old 12-31-2006, 09:27 AM   #6
WRX4eva
Member#: 103343
2004 2.5 Hybrid 6spd
Rotated Manifold/35R
Read the break in procedure from deadbolt, for your own knowledge.
WRX4eva is offline   Reply With Quote
Old 12-31-2006, 03:48 PM   #7
JonR
Member#: 22753
2002 PSM WRX +PPG
OBXT
Larry
As always, good information.
JonR is offline   Reply With Quote
Old 12-31-2006, 05:56 PM   #8
STL WRX
Member#: 88304
05 VF34 Aspen WRX
when i got my new vf34 i used castrol dino oil for 3000 miles then went back to mobil 1 synthetic... runs like a champ
STL WRX is offline   Reply With Quote
Old 12-31-2006, 07:27 PM   #9
scooby1220
Member#: 125129
2004 WRX VF34'd
Every place says something different about using synthetic oil to break in a turbo, good and bad. However, to my knowledge NO company has said that dino oil is bad for break in. I guess its a matter of preference. I always break in motors/internals on dino, so mine will be broken in on dino.
scooby1220 is offline   Reply With Quote
Old 12-31-2006, 07:57 PM   #10
dingobite
Member#: 82391
08 OBP Sti
td06SL2, 20g 299hp 300tq
Yeah im 3k miles on dyno now mostly do to my motor problems.
I could have sworn DB said to use normal dyno for 150-200 miles just as im possitive garret turbos aslo says to use dyno-oil with their turbos.
dingobite is offline   Reply With Quote
Old 12-31-2006, 08:44 PM   #11
Cusson
Member#: 95695
2003 WRX Sedan
ACLASS
will i just put synthetic in the car and everything seems fine; im not worried
Old 12-31-2006, 11:01 PM   #12
kcook
Member#: 78074
2005 STi
if ur car stock is running synthetic , i dont see a problem , ive been running synthetic ONLY in my car even with my new turbo. 7k miles and kickin
kcook is offline   Reply With Quote
Old 12-31-2006, 11:31 PM   #13
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Pre-priming the oil system and turbo are probably FAR more important than the particular type of oil used.
Turbos have been used on everything, running all weights and types imaginable.
Use new oil, prime it, be happy. If it's good enough for your engine, it's good enough for your turbo.
lancelucas is offline   Reply With Quote
Synthetic or non synthetic 4 new WRX wrx05awd Newbies & FAQs 24 03-12-2010 12:34 PM
synthetic or dino gear oil for tranny Sir Punk Newbies & FAQs 8 03-11-2009 07:59 PM
Switching Between Synthetic and Non-Synthetic Oil Slowsoul General Community 16 07-25-2007 08:21 PM
Engine oil for turbo engine differs from regular engine oil? cinemaster Service & Maintenance 9 04-29-2006 03:34 PM
Equal length vs non-equal headers for engine cooling? Optimus Prime Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 05-15-2005 11:26 PM
