Old 12-30-2006, 05:37 PM   #1
SilencedImpreza
Member#: 33019
10 wrx sedan
Default Obd2
Is there a reason I cant get any OBD2 reader to work on my 06? Did something change in 06 models? The reader will read up to 03, so says the reader. I havent tested it on other cars besides an 03 forester. Does that matter? Any help is great.
SilencedImpreza
SilencedImpreza is offline   Reply With Quote
Old 12-31-2006, 09:50 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
It does matter for some testers. Some for example, won't work on Subarus for some reason. I also think that some testers won't work with some 04+ models as sometime late 04/early 05 the VIN is embedded into the OBDII code, but that's just a guess. If you want another one, Actron is really THE brand to get as it's relatively cheap and drop dead easy to use.
Old 01-01-2007, 07:31 PM   #3
SilencedImpreza
Member#: 33019
10 wrx sedan
I know you posted about actron, but I was wondering if you have had any experience with it. I dont want to buy something even if its below 100 bucks if its not gonna work. Thanks for your reply unabomber.
SilencedImpreza
Old 01-01-2007, 08:19 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Two suggestions- buy the unit from someplace that will take it back if it doesn't work, and before buying contact the mfr. directly and ask them to confirm whether it will work on your specific car.
Old 01-02-2007, 01:14 AM   #5
z&cobb
Member#: 12344
2002 2JC
blue
Stop at a place like Autozone and read the stuff on the package the Actron comes in. That's a start, then ask one of the reps about your remaining questions, including can I return it if it doesn't work on my car? He should be confident enough to say yes.
z&cobb is offline   Reply With Quote
Old 01-02-2007, 01:24 AM   #6
bluetwo
Member#: 70802
08 Civic Si
Grey
I have an Actron CP9125. It cost around 69 bucks if I remember right (bought it at Advance) and the only thing problem I've had with it, is that the booklet included with it doesn't have all the codes.
My buddies Rolls for instance, threw some codes that I had to look up on the intergnat.
bluetwo is offline   Reply With Quote
Obd2 amelnikov Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 09-18-2001 09:53 PM
need obd2 scanner phast Rocky Mountains Impreza Club Forum -- RMIC 6 08-27-2001 11:23 AM
OBD2 Hookup location Stavros g Normally Aspirated Powertrain 2 06-19-2001 11:28 PM
TEC2 / OBD2 output question R Diamond Technical Forum Archive 0 06-23-2000 10:38 AM
