Old 03-21-2007, 05:08 PM   #51
john_tran
Member#: 90516
2007 WRX, R.I.P.06TR
Satin Pearl White
Sweet!! I just picked mine up and was already thinking of options. Awesome job on posting pics too!!
john_tran is offline   Reply With Quote
Old 03-22-2007, 10:16 AM   #52
AlxSti
Member#: 94615
|'06 STi 341/356|
Delaware REALTORŪ
thats looks good.. kinda makes me want a v2.. but not that much..
AlxSti is offline   Reply With Quote
Old 03-22-2007, 12:19 PM   #53
scoobrex
Member#: 135218
2007 STi
CGM
Does the APv2 handle CAN or is it only ODBII data?
scoobrex is offline   Reply With Quote
Old 03-22-2007, 11:49 PM   #54
Dirtyhobo010
Member#: 144170
02 ej207|6 speed
I would post my set up but I need 7 more posts.
Dirtyhobo010 is offline   Reply With Quote
Old 03-24-2007, 04:22 PM   #55
t4nk
Member#: 129905
2005 WRB WRX
2003 F-350SD, 7.3PSD
Originally Posted by El Capitan View Post
Not that complicated. The test mode wires just have good old fasioned spade conectors at thier ends.
Just get (2) 8 inch (+/- an inch) lengths of wire (I just used some green 18GA stranded that I had laying around) and put the required gender conectors at the ends to match the switch and the test wires and vola!
I just used crimp on spades. I didn't see a need to get out the soldering iron. The extra terminal on the switch is to make it light up when on. I didn't really see a need. Off is down and On is up. You will know what position it's in becasue when you turn the ign. to "ON", the fans will start to cycle if it is in test mode.
Could you just connect the connectors together, and interupt the connection by putting a toggle on the actual wires? instead of having to buy connectors and such... I've got tons of toggle switches in the garage, just dont have the connectors.
t4nk is offline   Reply With Quote
Old 03-24-2007, 08:02 PM   #56
El Capitan
Member#: 121261
06 STG 2+ STi
CGM
That's what I did. I just put a toggle between the green wires. The conectors are just spade connectors. You can buy a dozen for like $.99 at home depot.
Besides, you only really need to connect the green wires for the base map.
El Capitan is offline   Reply With Quote
Old 03-27-2007, 11:30 AM   #57
Dirtyhobo010
Member#: 144170
02 ej207|6 speed
Here is my mounting position
Old 03-27-2007, 11:31 AM   #58
Dirtyhobo010
Member#: 144170
02 ej207|6 speed
Old 03-29-2007, 12:44 PM   #59
Rippen Griffen
Member#: 91708
AD Motorsports FTW
06 OBP - Cobb AP Stg 2
As I was walking through Target this morning (diaper run) I noticed this little universal ipod holder that I never noticed before. The more I looked at it the more it looked like it might work well and for only like $10.00, I figured it was worth a look.
Just went to Target and bought one! Perfect fit!!! Looks like was built for the AP2...Oh, and it was only $6.99.
Rippen Griffen is offline   Reply With Quote
Old 03-30-2007, 09:03 PM   #60
STiUnit
Member#: 117000
2005 wrx sti
grey
nice im gonna have to get one for my ap V2
where did you guys get those kits from ?
STiUnit is offline   Reply With Quote
Old 03-31-2007, 05:05 AM   #61
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
Here is how I did it.
15. Done.
That is freaking Hawt I'm going to do mine this weekend thanks for this post and the how to...
dasnowman is offline   Reply With Quote
Old 03-31-2007, 09:21 AM   #62
El Capitan
Member#: 121261
06 STG 2+ STi
CGM
Read the thread, like Ragu...It's in there. (Short version: Home made)
Old 04-01-2007, 10:08 PM   #63
Picard
Member#: 100204
2006 STI (retired)
For any Canadians out there, I bought the same holder at Canadian Tire for $12.99CDN:
I also bought a retractable USB cable from Best Buy so that I didn't have to worry about tieing the extra length together.
One advantage is that the wire itself is really thin and easy to slide through the gap between the dash panels. I taped the wire so when I remove the AP, it just hangs discreetly to the side:
Picard is offline   Reply With Quote
Old 04-02-2007, 06:25 AM   #64
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
+1 haha picard I did the same thing... I'm happy with the placement on the vent for now. The Ap should have come with a carring case for that price though.
Old 04-06-2007, 01:16 PM   #65
wrx_tj
Member#: 136103
2003 Impreza WRX
Man, alot of good idea's here. I will have to keep these in mind when mine comes here in a few weeks!
wrx_tj is offline   Reply With Quote
Old 04-06-2007, 03:57 PM   #66
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
What do you do with the wire coming out of the OBD2? Mind hangs way down between my legs when I drive around with it????
medamullet is offline   Reply With Quote
Old 04-06-2007, 04:05 PM   #67
poupoulol
Member#: 145559
thanks
poupoulol is offline   Reply With Quote
Old 04-06-2007, 04:58 PM   #68
Picard
Member#: 100204
2006 STI (retired)
It bumped my leg a bit, too, so what I did was pop the OBDII plug out of the dash and tucked it in behind the panel with all the wires. The plug is held in by two clips and all I have to do when I go in for servicing is pop it back into the plug holder.
Old 04-06-2007, 05:40 PM   #69
Picard
Member#: 100204
2006 STI (retired)
What I did was go to the mall and buy something that I could slip the AP into and protect it from being scratched by the keys in my jacket pocket. It only cost me $2 and comes in a variety of styles and colours:
A newborn baby sock, 86% cotton :
My V1 actually fits in the sock, too .
Old 05-14-2007, 10:04 PM   #70
Jcrite8987
Member#: 139604
2010 WRX 5 Door
Well i did the same set up the other night with my APV2. I got a holder that is made by the same company but its different. I will post up some pics and how i mounted it in a few days when its light out and i have some free time all at the same time of day.
Jcrite8987 is offline   Reply With Quote
Old 05-24-2007, 03:55 AM   #71
jyang
Member#: 145165
can you show photos of how you hooked odb2 ? I tried this and it gets cluttering and i sometimes hit th eusb cable and it comes off.
jyang is offline   Reply With Quote
Old 05-24-2007, 12:13 PM   #72
Picard
Member#: 100204
2006 STI (retired)
I popped the ODBII plug out of the dash and tucked it in behind the panel. Then I zip tied it so it wouldn't fall out. When I take it in to the dealer for service, I'll just cut the tie, and put the plug back. I took some pictures of it, but I won't have access to them until tonight.
Old 04-28-2008, 12:18 PM   #73
CyborgX_CZ
Member#: 145351
0000 RIP 2006 STi
04 FXT / 89 SE30
Here is my ...
V2 looks so nice it is almost impossible throw that think in glove box. So I was thinking where to put my AP and also how. My criteria :
Easy removable
No drilling or gluing
No wires/cables visibility
After 4 hrs of thinking and walking around store and 30min of work here is the result.
You need:
Retractable mini USB Cable … $ 20.00 BestBuy
Universal Swivel Belt Clip w/Dash Mount … $9.00 AutoZone
I think this is the best and clean solution. Climate control is of course fully functional those knobs have a clearance few mm. Just a perfect fit.
First I unplug OBDII connector…
Then I relocate that under dashboard…
Then I plug new USB cable and hide behind plastics and run through center console through ashtray.
Last thing I place double side tape cell phone holder in right place and that’s it.
CyborgX_CZ is offline   Reply With Quote
Old 04-28-2008, 03:08 PM   #74
shakur45
Member#: 165106
2008 WRX Stage 1
Obsidian Black Pearl
Here's my setup, it's a Sirius radio mount
shakur45 is offline   Reply With Quote
Old 05-01-2008, 08:57 PM   #75
jsmoke
Member#: 156541
2004 WRX Wagon
just got my ap v2 today. flashed my ecu, everything is all good. now i need to mount it somewhere.. some great ideas here. one thing though, my ap will reset(turn off and on) itself by the slightest touch of the obd connector. anytime I hit a bump in the road it will reset therefore i can only see boost pressure or any live data on smooth roads. is this happening to anyone else? i don't know if its just mine and it has a weak connection somewhere. I want to mount this thing but if i have to keep selecting and scrolling live data everytime i hit a bump then theres no point. i just want to enjoy this thing already!
jsmoke is offline   Reply With Quote
FEELER: APV2.0 for 2.0l Dirtyhobo010 Engine/Power/Exhaust 5 07-10-2007 10:41 AM
FS: WA: 2002-2005 Cobb APv2.0 301wrx Engine/Power/Exhaust 3 02-14-2007 10:00 PM
FS: 2002-2005 Cobb APv2.0 301wrx NWIC Private Classifieds 1 02-14-2007 02:50 AM
How will any future APv2.0 updates be released? El Capitan AccessPort 7 02-05-2007 10:34 PM
New turbo and a new APV2.0. Street Tuner Help? nicholam AccessPort 3 12-12-2006 01:28 PM
