Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 06-17-2008, 03:43 PM   #701
mattminer
Member#: 90642
WKD Everything
Originally Posted by sleepyfu View Post
^^^ are you using any spacers at the rear? my rear sits quite a bit lower.
It actually settled a little in the back. new pics coming right up. today i measured the from the arch to the wheel center as best i could. i only had a mm measuring tape.
FL = 346mm (13.6")
FR = 344mm (13.55")
RR = 350mm (13.78")
RL = 352mm (13.85")
my OD of my tires is slightly smaller then stock, I imagine this slightly affects the measurement.
-M@
mattminer is offline   Reply With Quote
Old 06-17-2008, 03:55 PM   #702
BIGSKYWRX
Member#: 7958
09 GH B+
tire diameter won't effect measured ride height- that's why it's prefered to measure from the center of the hub -> wheel arch- takes out the differences in overall tire height
Old 06-17-2008, 04:11 PM   #703
mattminer
Member#: 90642
WKD Everything
oh ok then, then my measurements are accurate.
heres a pic
-M@
Old 06-19-2008, 09:55 AM   #704
BIGSKYWRX
Member#: 7958
09 GH B+
here's a pic of the set we installed last weekend, pretty nice stance- he'll be giving the setup a go this weekend at an event (I'm hoping we have time for some fun runs so I can give it a go )
Old 06-19-2008, 11:07 AM   #705
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Love the painted skirts on wagons, and that stance/drop looks perfectly even. I'm hoping my STi takeofs (springs/struts) is a nce even drop to rid a small bit of front fended gap. Will I need the rear butt spacers? I've got them, but not sure if they will be necesary.
Superorb is offline   Reply With Quote
Old 06-19-2008, 01:51 PM   #706
BIGSKYWRX
Member#: 7958
09 GH B+
^ more than likely as sedan springs tend to drop a wagon more in the rear vs front- you can always install them and see, if you think the butt sits too low, add the spacers to the rear
Old 06-22-2008, 11:58 PM   #707
BIGSKYWRX
Member#: 7958
09 GH B+
another plus for the RCE's- we installed a front sway bar this evening and it was able to run up my rhino ramps (I have to use 2x4's in front w/ my Tarmac springs)
Old 06-23-2008, 08:38 AM   #708
thorongil
Member#: 58797
2011 Legacy 2.5i
Steel Silver
That's interesting. I checked out my ramps after installing my RCE wagon springs and my Rhino Ramps will not fit under my front bumper without me using some sort of pre-ramp (though, I'll probably use 2x8s or 2x10s ). Perhaps the MY2004-2005 front bumper is slightly lower than that of the bug-eye WRXs.
thorongil is offline   Reply With Quote
Old 06-23-2008, 10:24 AM   #709
BIGSKYWRX
Member#: 7958
09 GH B+
^ that's very possible- this was a bugeye
Old 06-23-2008, 10:27 AM   #710
mattminer
Member#: 90642
WKD Everything
mine hits the ramps, but then kind of scrapes up onto them. I know use a piece of wood pre-ramp.
-M@
Old 06-23-2008, 11:04 PM   #711
sleepyfu
Member#: 124219
2004 W(agon)RX
I just shove the ramp under the bumper till it meets the tire
sleepyfu is offline   Reply With Quote
Old 06-24-2008, 06:49 PM   #712
mmiller2002
Member#: 159286
2002 WRX Wagon,Com-C
RCE wgn sprngs/Konis/H6
I just ordered them today with Konis!
mmiller2002 is offline   Reply With Quote
Old 06-24-2008, 08:16 PM   #713
TurbojonLS
Member#: 38772
2 Cars, No Bling
With my RCE lowering plates and sedan springs there's no way this would work on my car.
TurbojonLS is offline   Reply With Quote
Old 06-24-2008, 10:04 PM   #714
BIGSKYWRX
Member#: 7958
09 GH B+
my Tarmacs and lowering plates require the old 2x4's as well- it's damn close not needing them, but close isn't close enough
not sure if you can clearly see it in this pic, but his wagon (RCE springs) is slightly higher than mine
Old 06-24-2008, 10:07 PM   #715
Mind
Member#: 109216
08 STI DGM
76-77 Lancia Scorpion(s)
BS - what rim is that?
Mind is offline   Reply With Quote
Old 06-24-2008, 10:08 PM   #716
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
Nice enkeis bigsky!
EDTI: ^ Enkei RC-T4 i believe
- drew
AndyRoo is offline   Reply With Quote
Old 06-24-2008, 10:09 PM   #717
BIGSKYWRX
Member#: 7958
09 GH B+
^ yup RCT4
Old 06-24-2008, 11:09 PM   #718
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
What grille is that on the PSM bugeye, JDM of some kind?
Old 06-24-2008, 11:20 PM   #719
BIGSKYWRX
Member#: 7958
09 GH B+
jdm STi grill (v7)
Old 06-25-2008, 12:14 AM   #720
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Thanks, looks nice. So hard to find (cheaply) though.
Old 07-28-2008, 10:37 AM   #721
BIGSKYWRX
Member#: 7958
09 GH B+
well they let us do some fun runs yesterday so I got to put the RCE's through the paces
this was a pretty tight course so we had the Koni's up to 1 full turn from full soft (more open courses I prefer ~ 3/4 from full soft)
his car doesn't have near as much front camber as mine (-1.2 vs close to -3.0) and that was fairly evident. the springs and dampers felt good though, pretty similar to my setup (Tarmacs/Koni's), I thought there may be a little lag w/ the progressive springs in the rear, but it took a set very nicely- there were some pretty severe offsets so it would have been pretty apparent. we drove his car to lunch and it was very mild mannered on the street, not Grandma's Buick mild mannered , but mannered enough I think most folks that want a sporty setup could easily tolerate it
I measured the ride heights again and they look they have settled may a mm or two, not much
If you own a wagon and hearken for something sporty, but still need a daily driver- RCE's over Koni's would be a good choice
Old 07-28-2008, 02:25 PM   #722
mmiller2002
Member#: 159286
Cool! That makes me feel good about my choice. I just recieved my springs in the mail last week, and my koni inserts a couple weeks ago. Now I have to make time to do the install.
Old 07-29-2008, 01:28 PM   #723
stan_tichomirov
Member#: 150689
2007 Forester XT Ltd
I though you guys may find this interesting: this is what a Forester looks like on WRX struts with KONI inserts, RCE wagon springs, stock tophats.
Only had these on for a short time so far, but I can tell you -- ride quality is awesome IMO. I have the KONIs set to 1/4 turn from soft.
Stan
stan_tichomirov is offline   Reply With Quote
Old 07-29-2008, 02:43 PM   #724
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
^^ Ground clearance, what ground clearance?
Old 07-29-2008, 03:12 PM   #725
stan_tichomirov
Member#: 150689
Yeah, very low. The downpipe cat (COBB) is the lowest point, a coke can is about 1/2 inch too tall to fit under the cat. These are my stocker 17" wheels and they don't rub, my 245/45/18s rub mostly on the back while cornering hard. I am considering adding 1/4" or even 1/2" spacers.
Stan
front usdm sti springs w/ rear v7 sti wagon springs on bugeye wagon? anybody mixing? fastwrx25 Brakes, Steering & Suspension 15 04-02-2008 10:27 AM
RCE springs on STI without Group N tops? 06STIGO13 Brakes, Steering & Suspension 8 08-09-2007 11:35 AM
RCE springs on a bugeye AllAWD Brakes, Steering & Suspension 4 08-05-2007 11:45 AM
RCE springs on stock struts kennytwrx Brakes, Steering & Suspension 6 04-30-2007 04:01 PM
anyone have pics of RCE springs on 06 STI boostedsti06 Brakes, Steering & Suspension 3 12-31-2006 07:48 PM
