Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 12-30-2006, 11:53 PM   #1
Chapel
Member#: 3496
1995 Roadmaster
Beige
Default EasyECU vs AP2
I currently have an ECUtek tuned WRX.
Unfortunately, it's a rather aggressive map, and I'd REALLY like to be able to choose between my aggressive map and a more lean burn map for daily commuting.
I'd originally thought about just going to AccessPort 2.0, but was told that ECUtek sells a program called EasyECU that I can load with my current map and create more maps that I could upload as necessary.
I'd like to hear from some EasyECU owners and what you think of the program.
Chapel is offline   Reply With Quote
Old 01-02-2007, 02:05 PM   #2
Zumble
Member#: 34860
2005 Forester CGM
You cant create maps yourself with easy ecu. You can change the maps with a laptop but you cant create or edit maps yourself.
Zumble is offline   Reply With Quote
Old 01-02-2007, 02:11 PM   #3
Chapel
Member#: 3496
1995 Roadmaster
Beige
so, I can only EDIT them?
Old 01-02-2007, 02:20 PM   #4
Zumble
Member#: 34860
2005 Forester CGM
You can not edit them either. The map has to originate from a licensed ECUTEK tuner. He/she can send you the map via email and then you can save it to your laptop and flash it to your car via the laptop.
If you want to switch maps easily, the AccessECU (Accessport) system is the way to go. Either that or UTEC. EasyECU only allows you to flash premade maps yourself. You can't edit the maps, you can create your own.
The above are the facts..
Below is opinion:
Currently the ECUTEK offerings suck.
Old 01-02-2007, 02:35 PM   #5
Chapel
Member#: 3496
1995 Roadmaster
Beige
So, I'd essentially need to pay $200 per map + $350 for the EasyECU...
Is there sites that offer downloads for maps?
Old 01-02-2007, 05:00 PM   #6
LateApex31
Member#: 135686
Or you could forget all that ECUTek and Cobb noise and go for Enginuity. Many tuners use OpenSource products now and there is sweat over licensing fees and not being able to edit your own maps. Seems logical enough.
LateApex31 is offline   Reply With Quote
Old 01-02-2007, 05:21 PM   #7
Chapel
Member#: 3496
1995 Roadmaster
Beige
yeah, that's a possibility now.
I kinda like the Cobb thing.
Old 01-02-2007, 05:27 PM   #8
Zumble
Member#: 34860
2005 Forester CGM
Open source stuff won't get you the AP module. You still have to lug the laptop along with you if you want to switch maps. Would be nice if you could run the opens source stuff off a Windows Mobile 5 PDA or something.
Old 01-02-2007, 05:31 PM   #9
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
The openecu software and hardware will essentially let you do 90% of what Ecutek will let you do (although if you're reflashed with a later Ecutek version you will have to unlock your ECU). We offer the openecu cables which are compatible with diagnostics or reflashing. Downside is you will have to carry a laptop with you to allow map switching (and it takes about 5-10 min to reflash).
The Cobb AP V2 on the other hand is a handheld device and it allows map switching as well as real-time tuning (as well as a myriad of other features). They are a bit pricey, but if you're planning on spending a lot of time developing custom maps the real time stuff alone is definitely worth it IMO.
Cheers,
Gary
Gruppe-S
Gruppe-S is offline   Reply With Quote
Old 01-02-2007, 06:00 PM   #10
Chapel
Member#: 3496
1995 Roadmaster
Beige
yeah, don't the OpenECU things use Serial instead of USB?
If someone gets OpenECU to work with a Windows PocketPC, I'll seriously get that.
Old 01-02-2007, 06:10 PM   #11
LastResort
Member#: 99289
http://forums.openecu.org/viewtopic....r=asc&start=15
Has some discussion on the subject. Really, it doesn't look insurmountable, it's just going to take someone with the skills deciding they want it.
LastResort is offline   Reply With Quote
Old 01-02-2007, 06:14 PM   #12
Chapel
Member#: 3496
1995 Roadmaster
Beige
well, we have HP Pocket PCs from Acura here at work that do diagnostics
Old 01-02-2007, 06:31 PM   #13
LastResort
Member#: 99289
It's opensource, and you may need to port from one library to another, but it's all there.
Old 01-02-2007, 07:33 PM   #14
LateApex31
Member#: 135686
The Tactrix cable is USB.
As far as ECUFlash being 'open source' it isn't. Many of the ROM editors are open source (Enginuity, etc) but Colby never released the source for ECU Flash so porting that to anything will be difficult. If your PocketPC runs windoze, give it a try!
Enginuity has live tuning actively being tested and in the works, so it shouldn't be too long before you can get a free software suite that does everything the big boys to. Well, almost everything
Old 01-02-2007, 08:16 PM   #15
LastResort
Member#: 99289
hmmm...that's a bummer about ecu flash.
Old 01-02-2007, 08:29 PM   #16
97whitesi
Member#: 70925
2002 S2000
2001 Integra GS-R
yes he did, for the 16bit ecus only.
97whitesi is offline   Reply With Quote
Old 01-02-2007, 09:25 PM   #17
LastResort
Member#: 99289
Can you clarify what would be the 16bit ECU's?
Old 01-03-2007, 11:04 AM   #18
Gethin
Member#: 2998
non DBW ECU's are 16bit. Problem is that most PDA's dont have a USB host controller.
Gethin is offline   Reply With Quote
Old 01-03-2007, 11:10 AM   #19
LastResort
Member#: 99289
Yes, but it would be possible to just use the UART that is present in most (all?) WinCE devices as long as they support the particular baud rates the ECU requires. Hell, I'd buy an iPaq and a Tactrix cable over an AP, anyday. more flexibility.
FS : HRSS/ Cobb AP V2, Bellmouth 3 inch Downpipe lando MAIC Private Classifieds 19 06-13-2010 07:40 AM
Stock STI 6mt Trany mount VS STI Group-n Trany Mount? KiggerSTI Transmission (AT/MT) & Driveline 10 06-04-2010 03:06 PM
Ap1 Vs Ap2 protune burken AccessPort 8 05-29-2009 08:31 PM
06 WRX Tr - Stage I - Ap2 base map vs Dyno Flash Pro Tune Dyno Flash Proven Power Bragging 6 08-12-2007 10:18 PM
