Old 12-30-2006, 11:20 PM   #1
STi_v4_Wagon
Member#: 120368
04 Forester XT
Default Power steering pump, STi V4. Any other pumps fit?
My power steering pump is making noise (has been since I got it) and is starting to weep fluid around the bearing. Does anyone know if any other models of pumps will fit my application?
Thanks
STi_v4_Wagon is offline   Reply With Quote
Old 12-31-2006, 11:13 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
no idea but post the part numebr if you find it
Old 12-31-2006, 11:44 AM   #3
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
is it the one with the remote resivior or all 1 unit, like most of the N/A's?
subbyspeed is offline   Reply With Quote
Old 12-31-2006, 01:59 PM   #4
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
You can use a NA 98-20 RS pump . You have to switch over the resevoir. Never compared yet, but not sure if the relief spring is higher than the NA one.
Ver.III is offline   Reply With Quote
Old 01-01-2007, 01:41 PM   #5
STi_v4_Wagon
Member#: 120368
04 Forester XT
Awesome, thanks for the info. I did alot of searching it looks to me like the dohc 2.5rs pumps should fit. My current V4 resevoir will fit on the 2.5rs one? Does it need any mods?
Also I read somewhere that I may need to swap the PS pump bracket because supposedly the JDM pumps don't fit the USDM brackets, but the USDM bracket will fit the JDM motor. I don't see why this would be the case, and worst comes to worst I'm sure the bracket could be easily modded to fit.
FS NY:00RS oem full interior, STi V6 cluster, 04 WRX steering wheel, STi V4 LE seat garface Interior/Dressup/Audio & Security 40 02-08-2009 10:22 PM
Power steering pump, STi V4. Any other pumps fit? STi_v4_Wagon Brakes, Steering & Suspension 0 12-30-2006 11:19 PM
Power steering pump for STi v4, any usdm models work? STi_v4_Wagon Subaru Conversions 0 08-01-2006 01:35 AM
any other gauges fit in oem pod? trbo-4 Newbies & FAQs 16 03-20-2006 01:59 PM
Driving an STi (or any other car) offset Newbies & FAQs 3 05-12-2003 06:39 PM
