Old 01-01-2007, 03:30 PM   #1
i-max
Member#: 53434
Post Whistling Noise After Installing DP
What is the loud whistling noise that occurs under load? Not heard while idling. Only slightly loud while low reving in place. Is that the turbo noise thru the DP? Anybody know or can shed some light? Does it happens to all DPs!
i-max is offline   Reply With Quote
Old 01-01-2007, 03:55 PM   #2
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
An aftermarket DP really wakes up the turbo sound. If you don't have any leaks, thats all it is. Enjoy!
blkscooby is offline   Reply With Quote
Old 01-01-2007, 05:22 PM   #3
kcook
Member#: 78074
2005 STi
what he said ^
what downpipe is it and if u run just downpipe and rev it or do a few WOT runs , it sounds real nice
kcook is offline   Reply With Quote
Old 01-02-2007, 01:35 AM   #4
Phil4631
Member#: 118016
2004 WRX
Yea, like they said.. Downpipe makes the turbo loud, and it sounds great. Reminds me of a huge truck when it really gets going.
Phil4631 is offline   Reply With Quote
Old 01-02-2007, 02:32 AM   #5
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
check your uppipe as well for good measure.
Old 01-02-2007, 11:47 AM   #6
i-max
Member#: 53434
Thanks guys... seems like the noise is ok and not as loud anymore. It's a Cobb DP. No uppipe yet.
Old 01-02-2007, 11:55 AM   #7
bluestonepath
Member#: 123641
'04 WRX Wagon
Platinum Dirty Metallic
^^yes. unless you have an STI or an 06 or later (i'm assuming you have some kind of turbo impreza here but you should really fill out your profile) then you have an up-pipe cat. And sometimes, when adding aftermarket modifications to your car, and sometimes even NOT, this up-pipe cat likes to let little peices of itself fly into your turbo. So you might want to take care of this:
Originally Posted by i-max View Post
No uppipe yet.
--soon, you can either gut your stock up-pipe, or buy an aftermarket one, that is if you DO have a up-pipe cat--otherwise an aftermarket up-pipe would be in vain.
bluestonepath is offline   Reply With Quote
Old 01-02-2007, 12:54 PM   #8
JonR
Member#: 22753
2002 PSM WRX +PPG
OBXT
Loud noise is definitely normal...
JonR is offline   Reply With Quote
Old 01-02-2007, 08:57 PM   #9
WRX03
Member#: 20744
05 Baja Regal Blue
03 WRX Little Red Wagon
Not if you use a divorce DP with all the stock heatshields. No whistling allowed while driving.
WRX03 is offline   Reply With Quote
Loud whistling noise after downpipe install....leak? AutoSpeedWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 11-01-2008 10:27 PM
New whistling noise after 3000 miles... AndyPants Newbies & FAQs 4 02-07-2007 02:22 AM
06 Stock STi - Sudden Engine Whistling Noise After High Speed SixSigma Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 37 02-09-2006 10:43 PM
Noise after install of up-pipe nyaconis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-09-2002 02:06 PM
Weird noises after install...Help Me Out Here wrx182 Transmission (AT/MT) & Driveline 8 11-14-2001 02:12 AM
