Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 01-01-2007, 04:34 PM   #1
em199si
Member#: 70213
2007 TSX
PWP
Default Help! Car will not crank. Sounds like a machine gun.
nevermind
em199si is offline   Reply With Quote
Old 01-01-2007, 05:21 PM   #2
disque71
Member#: 57330
2008 WRX
check your fuses, something may have blown, particularly the IGN fuse.
disque71 is offline   Reply With Quote
Old 01-01-2007, 05:30 PM   #3
rkramer
Member#: 118209
2015 WRX Limitec
Originally Posted by em199si View Post
but when I turn the car over it sounds like a machine gun.
charge your battery up!! that is your starter solenoid bouncing. might also be a bad battery cable.
Old 01-02-2007, 12:14 AM   #4
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
+1 for a weak battery - check the voltage - if it's the oem battery, check the fluid levels, too.
DrD is online now   Reply With Quote
Old 01-02-2007, 05:16 AM   #5
Mustang Raper
Member#: 84388
2002 WRX,FPG,6MT
Sedona Red Pearl, Carbon
+1, had the same problem a couple of days ago, took of the cables and cleaned them real well with a wire brush, put them back on and started right up.
Mustang Raper is offline   Reply With Quote
car wont start? it clicks like a machine gun. DieselClown Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 12-18-2008 05:06 PM
Help! Car will not move 05subylah Service & Maintenance 8 10-18-2008 04:16 AM
Help. Car will not return to idle... LiquidForce Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-10-2005 12:49 AM
need help car will not fire 387hardcore Pre-2002 Factory Turbo Powertrain 2 05-03-2004 01:58 AM
need help car will not run 387hardcore Tri-State Area Forum 20 03-22-2004 02:29 PM
