Welcome to the North American Subaru Impreza Owners Club Friday November 21, 2014
Old 01-01-2007, 05:00 PM   #1
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
Default 05 STi stage II w/ meth question?
as title states above an 05 STi running smc 100% meth kit w/ full turbo back
3" exhaust, utec tuning, VF 39 peak boost at 17.5 lbs. What are other good supporting mods can i perform to maximize the VF 39 and assist w/ additional tuning? thinking walbro pump ? injectors? one step colder plugs?
krambte79 is online now   Reply With Quote
Old 01-01-2007, 05:02 PM   #2
06blksubwrx
Member#: 109084
06 VF39 WRX
12.50 @109.1 Sleeper
I would do walbro fuel pump and turn up the boost using meth.
06blksubwrx is offline   Reply With Quote
Old 01-01-2007, 07:14 PM   #3
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
bump for input
Old 01-01-2007, 07:52 PM   #4
drumr78
Member#: 43449
2015 STi
I'd put the GM boost solenoid in, some bigger injectors, walbro and re tune the car to 21psi. With the meth you should be able to advance the timing some more and get some huge torque numbers. the fuel pump and injectors are for safety and reliability since you will be maxing out the stock ones.
drumr78 is offline   Reply With Quote
Old 01-01-2007, 08:12 PM   #5
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
what injectors should i use for my setup?
Old 01-01-2007, 09:13 PM   #6
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Are you tuning this or is it a tuner? If it is a tuner, you need to ask him before you listen to ANY advice from ANYONE here.
Old 01-01-2007, 09:22 PM   #7
norexyet
Member#: 39149
11 elantra
yea i said elantra
external wastegate
norexyet is offline   Reply With Quote
Old 01-01-2007, 09:36 PM   #8
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
i will ask my tuner tomorrow, but does anyone have suggestions for injectors?
Old 01-01-2007, 09:41 PM   #9
Wylan
Member#: 97854
2005 Impreza WRX STi
PE 850's or Helix 860's, both made by Denso, and will be big enough for almost anything else you upgrade to in the future. I am planning on these when I put my Dominator 1 (same ratings as a FP Green.) I will most likely go with the helixes cause they are a bit lower in price.
Wylan is offline   Reply With Quote
Old 01-01-2007, 10:02 PM   #10
norexyet
Member#: 39149
11 elantra
yea i said elantra
you don't need injectors with the stock vf-39, especially running the meth
Old 01-01-2007, 10:20 PM   #11
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
can i still utilize the walbro and a GM boost solenoid ?
Old 01-01-2007, 10:28 PM   #12
norexyet
Member#: 39149
11 elantra
yea i said elantra
yea you can use a walboro and the solenoid. I have a externally gated vf39 with meth.
Old 01-01-2007, 10:45 PM   #13
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
what plugs do i need to use?
Old 01-01-2007, 10:49 PM   #14
norexyet
Member#: 39149
11 elantra
yea i said elantra
i would run ngk one step colder coppers if you can find a set, if not one step colder iridiums work also
Old 01-01-2007, 11:15 PM   #15
QuickSilverSTi
Member#: 51955
2004 STi - Sold
2008 GT500 650rwhp/630tq
Only injectors you should consider for a stock turbo are the JECS 740 or the 740's from Deatchwerks.
QuickSilverSTi is offline   Reply With Quote
Old 01-05-2007, 09:08 PM   #16
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
what does the gap on the plugs need to be?
05 STi Stage 2 + Meth WOR440 Proven Power Bragging 12 04-11-2008 03:18 AM
05 STi Stage II for SALE etirums SWIC Private Classifieds 8 10-31-2007 09:17 PM
05 STI Stage II 93 Pro Tune Dyno Results IMPORTEDCARS Proven Power Bragging 0 08-24-2007 11:17 PM
06 STI, Stage II, APS Header, APS TBE, METH ChrisSK Proven Power Bragging 10 12-20-2006 12:22 PM
Tweaks to UTEC STi Stage II base map questions. StiDreams Engine Management & Tuning 24 06-19-2004 07:32 PM
